Old 02-29-2008, 02:22 AM   #26
edman87
junk collector
Re: My camaro tach cluster-done!
This one is somewhat better
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 02-29-2008, 11:40 AM   #27
rfmaster
rfmaster's Avatar
Edman
Thank you very much for additional info. I'll try take additional photos and draw a proper diagram for future reference sake...
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 02-29-2008, 06:51 PM   #28
edman87
junk collector
that is the kind of diagram I wanted to do, but the pics came up real fuzzy in paint.
'91 camaro rs
'98 jeep tj
'52 willys cj3a
Old 06-15-2008, 10:41 PM   #29
1969stepside
1969stepside's Avatar
i might have miss read but how did u get the oil pressure gauge out of the tach?
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 06-17-2008, 04:38 PM   #30
rfmaster
rfmaster's Avatar
Just unbolt three nuts that secure it to the PCB and slide out from the back of the Tach.
//RF
"The Beast"
Old 06-17-2008, 05:02 PM   #31
COMP
i'm REALLY liken this
COMP is offline   Reply With Quote
Old 07-06-2009, 12:20 PM   #32
spoff99
EDman87 thanks so much for the great info. I have built an instrument setup from your write up but have added an extra temp gauge where the clock used to be for trans temp gauge. I have an 87 Jimmy w/TBI the cluster that is in it has the idiot lights w/only speedo and fuel gauges. when I took the cluster out I noticed the printed circuit boards and 16 pin main harness were wired differently. for example pin 3 in idiot light printed circuit board traces over to oil pres light, in donor it traces to volt gauge location. Only 4 of the 16 pins are the same my printed circuit board to the donor printed circuit board. My question is can I move the pins around so they are in the correct position for my donor printed circuit board cluster? The reason I am worried this will not work is because the on off nature of the old temp, oil pres, volt. They just turned on a light when it reached a high temp, low oil, low volt. I would assume the signal to the gauges is an analog volt increase as temp, oil pres goes up, ect. Do I need a computer out of a vehicle that came from the factory with gauges not lights? If so what year models will work? I would assume only 1987-1989 since after that they went to a electronic speedo and prior to that was carburetor. Thanks in advance for the help. I don't want to hook it up and fry something. I try and post pics tonight.
1987 GMC Jimmy 4x4, mostly stock for now
305ci, 700R4, NP208, 10bolt front and rear 4:10
3" body lift (on it when I bought it) 35" mudders
parts accumulated to build up Jimmy
383ci stroker w/ big block TBI, bowtie overdrive level 3 700R4, NP 205 cast iron gear drive case w/PTO, dana 60 in front 4:56, GM 14 bolt rear detroit locker 4:56, 4 core big block radiator w/ ford taurus electric fan, hydra boost brakes
spoff99 is offline   Reply With Quote
Old 07-06-2009, 02:10 PM   #33
JohnC
JohnC's Avatar
This is a really cool mod. Very subtle. The bad part is I sold my 89 Iroc to buy my truck so now I don't have a cluster readily available like I did! If I don't do aftermarket gauges I may do this. Thanks for all the info, and pics.
JohnC is offline   Reply With Quote
Old 07-07-2009, 08:08 AM   #34
spoff99
Here are a few pics of my cluster with extra temp gauge for transmission. I just welded a 3/8 bung into the trans pan and treaded a one wire water temp sending unit into it, Have not tested it yet but see no reason why it shouldn't work. Found out that the computer does read the engine temp but that the gauge does not have anything to do with that sending unit, and there is another sending unit in the drivers side head that is a one wire unit that sends to the gauge. all I need to do is rewire the 16 pin plug and buy a one wire send unit for a gauge and an oil pressure sending unit for a gauge. and I think I am set. will test it out this weekend.
Old 07-07-2009, 09:28 AM   #35
grinch4om
dang its hot
grinch4om's Avatar
very cool!!
grinch4om is offline   Reply With Quote
Old 07-07-2009, 12:44 PM   #36
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
This is a great mod. Good thinking guys. I like it alot. Keeps it somewhat stock looking but gives us useful gauges. Would the speedo out of the same cars work to keep the fonts the same? I am a little goofy like that.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 07-07-2009, 12:54 PM   #37
JohnC
JohnC's Avatar
Originally Posted by Driveway Dreams View Post
.... Would the speedo out of the same cars work to keep the fonts the same? I am a little goofy like that.
I would think it would. They are the same size if I remember correctly, and if you get one out of a IROC you can get a 145mph speedo!
Old 07-07-2009, 12:54 PM   #38
olblue81
olblue81's Avatar
Just curious why neither of you installed the Camaro speedo?
Stu-
1981 GMC Sierra Classic LWB
355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992
700R4-2000 stall with lockup, shift kit, Corvette servo
3.07 open diff- I need a 3.73 posi!
2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me.
olblue81 is offline   Reply With Quote
Old 07-07-2009, 10:46 PM   #39
asphaltburner
asphaltburner's Avatar
Yo! Converted my "idiot light" gauge dash in my '76 Camaro several years ago and hard wired it to eliminate the "floppy circuit" and plug that are so prone to bad connections. This is NOT a difficult conversion. Here's a link of the stepwise conversion with pics:
http://www.cardomain.com/ride/639261/3
Click on the pics for a larger view.
I had to use three Autometer gauges, and a Z28 fuel gauge and tach with the stock speedometer. Hardwiring is easy once you've traced the plug conections.
Sure would like to replace FRANKENTRUCKs' big fuel gauge in a similar manner someday soon,...at least the trucks came with a proper oil pressure gauge instead of an idiot light like the Camaros!
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 07-07-2009, 10:53 PM   #40
dan76
As a side note: Was there a factory tach available in 80's C trucks? If so, anyone have a pic?
dan76 is offline   Reply With Quote
Old 07-07-2009, 11:07 PM   #41
USSkoval
That's what I was thinking too. I have several extra Camaro clusters, so I feel it is my duty to try this, lol.
USSkoval is offline   Reply With Quote
Old 07-07-2009, 11:23 PM   #42
asphaltburner
Yo! Gosh, I can't imagine needing a 130 or 145 mph speedo in a truck,...especially on public roads. Even my 350hp Camaro has only been to 135+ twice,...for a short distance, and only to prove itself just after I built it in 2006.
FRANKENTRUCK has 4.11:1 rear gears, 33" tires, TH400, and engine revs at 80 mph are pretty high. It'll never need more than a 100 mph speedo.
In addition, the 145 mph speedo will be fairly difficult to read at speeds under 50 due to it's sweep,...
Todd.
Old 07-08-2009, 12:08 AM   #43
USSkoval
Yeah, the 145 seems like overkill. The 115 or even just the common 85 would be a good choice.
Old 07-08-2009, 12:36 AM   #44
Driveway Dreams
I have car A.D.D.
To me, the top speed on it would not make a difference. I just, like I said, would have to have matching faces.
-Gerald
Old 07-08-2009, 10:20 AM   #45
N2TRUX
Happy to be here
N2TRUX's Avatar
Actually if you look and compare the fonts do match. It's the register marks that make them look different.
dan76- Yes they did offer a tach in the 73-87 trucks. Here's a pic of mine.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-08-2009, 11:26 AM   #46
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
wait so this means if im real lucky i can go to the junkyard and just find me a complete plug and play tack dash?
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 07-08-2009, 01:53 PM   #47
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
yes poke. there out there. Ive seen a few on craigs too. just never had the money to get one.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 07-08-2009, 03:33 PM   #48
JohnC
JohnC's Avatar
I wouldn't want the 145mph speedo to actually attempt to hit it, just thought it would be cool to have that speedo. You know some people would look at it, and say " Hey that truck is fast it has a 145mph speedo in it"
There is a crew cab at the local Pull-A-Part that has a factory tach gauge set in it. I'm hoping to pick it up Saturday. Don't know if I will be using it, or just hanging on to it until the time is right.
Old 07-08-2009, 05:32 PM   #49
asphaltburner
Yo! I also found that similar year speedos and tachs (and other gauges) WILL look like they go together. They're quite easy to swap back and forth.
Todd.
Old 07-08-2009, 09:43 PM   #50
cjracing15
cjracing15's Avatar
I never thought about doing that with the temp gauge but I really like the idea. My clock has not worked in years so I might just try this mod if it works for ya. Be sure to keep us updated. I will be sure to keep a watch out.
Oh by the way The tach looks awsome to. If I can find one on the cheap I think I might try that also. GREAT work and, thanks for sharing your ideas.
The fleet
94 Chevy 4x4 reg cab
2018 Traverse (wifes car)
1977 SWB stepside
1949 Chevy truck
cjracing15 is offline   Reply With Quote
