#26 |
C10 Club Tennessee
Re: Smooth Cowl - Who Wants One?
I'd be interested too, don't care what it's made of just needs to be shaved all the way
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
#27 |
Long Fleet Club
With the aftermarket A/C systems this is correct but with the factory system (A/C and Heating) you have inside air and outside air. The outside air comes from the cowling area and is the main setting for most of the newer cars for defrost.
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules Last edited by cameeks; 03-01-2008 at 02:28 PM. |
#28 |
I'll take one with no wiper holes
#29 |
I was the purchaser of the first smooth cowl from the ebay seller. I am very pleased with the product. I am placing vintage air and heat into my project so the vents would not matter. The product is more than I expected, needs minimal work done to it for painting. The seller packaged the item very carefully. I wish more companies would package a product like the seller did. The continued communication that I have received from the seller has been great. If I need more of these I will definitely purchase through him. I have been looking for one of these for the past year and finally found one that I approve of. Would highly recommend the seller of this item.
#30 |
The LuvShack Garage
Good to hear Matt, he is building me one right now
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#31 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
For those of you that think that your non A/C truck draws air from anywhere but the cowl should go look at your truck.
The non A/C trucks get the air for the heater from the cowl vent only. The A/C trucks have the ability to draw air from the cab by closing the flap in the cowl, and opening the kick panel vent on the passenger side. (Does it with Vacuum diaphragms.) If you close off the outside air source, something else has to open to draw the air from. (For A/C trucks it has to be the cab.) The reason the A/C trucks have this ability is because, the A/C system can only has the ability to cool the air about 12 degrees below the ambient temperature. By drawing recirculated air from the cab, each time the air passes through the coils it cools another 12 degrees. That is how the A/C works. If it didn't have that capability then if the outside air temp was 100 degrees, then the coolest that the A/C could get it would be about 88 degrees and that is with everything working perfectly. You do not have that problem when it comes to heating the air, because air heats faster and easier than it cools. Now!! If you install a non vented cowl panel, where will your heater draw it's air from? Answer: Your engine compartment!! Through any place that it leaks air. Nice oily, smokey, and toxic air..... MMMMMMMMM!! So unless you somehow create a different place for the heater to draw it's air from I would reconsider whether or not you really want this modification. I am not trying to spoil anyone's day, or tell you to or not to buy, not buy, or make one of these panels for yourself. Just trying to inform you... Why you ask? Because that's what I do...lol JK... Anyway here is a picture of where your heater fan seals to the firewall. You can clearly see that it draws air from inside the cowl. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#32 |
454 MAKES IT ROAR
Thank God for people who know what they are talking about.
Why not shave the headlights the taillights the grill and on and on
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
#33 |
Anymore word on these? I want one
#34 |
![]() Join Date: Dec 2002
The temperature of the discharge air into the cab is controlled primarily by the temperature of the outside air entering the condenser (mounted in front of the radiator). Referring to the 1971 Chevrolet Truck Service Manual, Heater and Air Conditioning system; page 1A-17:- With the temperature of the air entering the condenser of 100 degrees, engine RPM @ 2000 and high blower speed, the discharge temperature at the right hand outlet should be 41-44 degrees. The specs do call for setting the upper lever for inside air. The inside air setting does supply a faster cooldown of the air for test purposes. If a thermometer was inserted between the fins of the evaporator (located inside cab heater core and distributor assembly box); then the temperature or the air source would be immaterial. I have found that using outside air as a source; the outlet discharge temperature will be about 50 degrees.
Over 15 years ago; I modified my system as follows:- removed vacuum line and sealed the right kick panel inlet; removed vacuum line and the flapper valve from cowl plenum. This enables outside air only to the system. Installed a switch on the dash lip directly under the fan switch to control the compressor. Repaired and checked for proper operation; temperature, air cond/heater floor and the defroster flapper doors. Also replaced the water valve and checked for proper vacuum operation. This modification enables complete control of the heater/airconditioning system. I find it quite useful in this damp Oregon climate to be able to use heated /air conditioned outside air for rapid defrost operation. Heated and/or airconditioned air can be blended and directed to desired outlets. I find that outside air intake to be a must if the occupants are smokers!!!!
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
#35 |
WTB this ad
Valid points on the fresh air. However guys running Vintage Air systems wont have that problem. Also guys like 5150 who are building a roadster with no heat or air are obviously not going to have a problem. So why not shave the headlights and taillights? Because we are required by law to have them. There is no law that says we can't customize these rigs by running a shaved cowl and cutting off the supply of fresh air ,IF we're using a factory heat/AC system.
#36 |
C10 Club Tennessee
well said mate
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 Last edited by 5150; 03-14-2008 at 11:05 PM. |
#37 |
Guest
Posts: n/a
same here, if it's steel you got a deal but not crazy on fiberglass. does anyone offer this in steel or do i need to smooth one out myself?
#38 |
Restoring a 68 SWB
What's the weight difference between the steel cowl and the fibergalss one? It's can't be much.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
#39 |
Earlier on someone stated that the kick panel vents draw their air from the cowl vents right? If you close the cowl vent completely then wouldn't the heater just draw it's air intake from the kick panel vents now?
#40 |
Catchy title goes here..
![]() Join Date: Mar 2002
moved to the message board since this has become an interesting discussion and its not a for sale ad.
#41 |
Questionable
Only if the kickpanels are open all the time. If the kick panels are closed, it will be sucking on a vacuum and pull air from anywhere it can - including sucking carbon-monoxide laced air through the windshield washer holes and any other crack it can find.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#42 |
Sheetmetal Psycho
Then we could just make the kick panels permanantly open maybe with a screen similar to a speaker?
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up! Project "Rigginstine's Monster" 1971 C-10 longbed 355/4spd Future mods: 67 front clip Webby's Rigginations - where everything has potential! |
#43 |
Questionable
Or just remove the door, but you still need to consider the fact that you will NEVER be pulling massive amounts of fresh air, so by pulling air from the cab and recirculating it through the cowl area, which has openings to the engine compartment, the longer you stay in the truck, the more exhaust you're going to introduce into your air supply inside the cab. If you had a window open all the time, this probably wouldn't be a problem, but on long road trips with the windows rolled up, I think you're asking for trouble. Any carbon monoxide intake is bad. Constantly trickling more and more CO into your air stream is really, really bad.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 03-19-2008 at 01:14 AM. |
#44 |
![]() Join Date: Feb 2004
yep they are right it does pull air from that round hole, i guess mine has been smoothed so long that i forgot about haveing it, id just make it suck from inside the cab my self, sorry about the miss info i done away with my whole factory set up years ago and smoothed all the holes guss you forget what was there when you cant see it any more, my .02 is that that whole cowl is a sucky system that causes 95% of these trucks to be cancer victims. thats why i did away with it
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
#45 |
someday it will be done!
So why couldn't some ambitious soul shave the cowl and make a new fresh air intake.Maybe cut a hole in the air box behind the fender, and fab up some sort of duct that will lead up to, and pass through or maybe under the core support.Then make some sort of cool screened scoop hidden behind the grill or a real low profile one just under the bumper?Sounds like a ton of work...
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
#46 | ||
Mine don't seal very good anyway, lol. I like the idea of removing the doors and making a screen/cover for the hole. Quote:
How would this be any different than driving without the heat on and the windows up? It's still the same air. I understand what you are saying but I think you're going a little overboard with your above statement. You make it sound like our cabs have ductwork directly attached to the exhaust. |
#47 | |
Questionable
Hey, if inhaling CO is cool with you, fine. I'm just tossing a worst-case scenario out there. It's bad enough I gotta worry about lung cancer and countless other crap from pollution out there. Last thing I want to do is breath in exhaust and smells from my engine bay all day long. I guess some people could be into that.... My whole reason for posting that is to get people to actually think about what they're doing, rather than just blindly hacking stuff because "it looks cool". I don't want one of you guys passing out at the wheel from CO poisoning and plowing into my family or friends.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 03-19-2008 at 06:43 PM. |
#48 | |
Questionable
#49 |
Parts and more parts
I am interested in one that is steel.
