#26 |
![]() Join Date: Nov 2007
Re: Driving But So So Brakes??
looks like advance auto stocks all the parts and will let me borrow a bender. Also it looks like stock 3/4 short lines will work from inline tube. I should be set.
#27 |
Cool Let Me Know What You Come Up With Finally Got Mine Better
But Still Not Great |
#28 |
As i recall, in order to properly bleed the brakes on these trucks, the BOOK tells you that you must pull the proportioning valve front pin (while bleeding) to allow for the fluid to flow properly or you are just working against the proportioning valve piston. You might want to check a servce manual. I had the same problem all of the above had and went by the book with the correct 1/2 ton booster. Today my brakes will throw you through the windshield!! Huck
