#26 |
Re: Pics of my adjustable rear control arm brackets
This is what I used last time out. Top hole.. Cut a high 1.6'x low 1.7's.. Issue I had was the front shock was still way too soft in the 70/30 setting. It would top out 7.5" of suspension travel, lift the front left every pass on the motor. As it came back down, it would unsettle the rear and unload the tires.
I am doing a few things to fix this issue.. Changed front shock in the front (9-way adjustable rancho) Adding a 1 3/4" antiroll bar to the rear (hoping to help the roatation) Had I lowered it, it would have made it worse regarding lifting the tire.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
#27 |
Sounds like a deal to me!!
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 Last edited by Ford Assassin; 08-16-2008 at 06:47 PM. |
#28 |
I was asked to bump this too the top..
#29 |
How much to make me a set? I am VERY interested since my 60ft blow at the moment.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
#30 | |
mini truck racer
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 01-29-2009 at 10:09 PM. |
#31 |
Yeah baby!
These are now available from Hotchkis, but not cheap.
http://www.hotchkis.net/c10_truck_re...et_system.html
11.37 @116 |
#32 |
Those are cute but man that is high dollar for what you are getting.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#33 |
Good thing I can help make them some money huh?? Perhaps they should be nice enough to send me a set for the thought of engineering a piece after mine.. Got to love the way big business works, steal someone elses idea and make all the money..
Good thing they don't know it will work on 60-72 ![]() ![]()
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 02-09-2011 at 03:58 AM. |
#34 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#35 |
To be honest, I don't have much time with school right now. Next time I do have time, I'll should make a couple sets to have laying around. Another alternative for everyone would be to take their factory ones, grind the rivits and flip them over. I think Kevins truck is set up this way.
#36 |
![]() Join Date: Jan 2011
Try softening the extension on the rear shock to hit the tire a little harder and tighten up the front to slow the rise. May pick up your 60 foot time.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#37 |
Man.... I need some of these. And a nice sit down with you and your truck. lmao.
#38 |
To the top for the home hobbiest..
#39 |
Rusty but Trusty
Pics aren't loading for me.
Are the links still good? Could you check that out? Please Lee
72 SWB, 454 / th400... hoping the kids don't get all the parts before it gets built |
