Old 02-27-2008, 10:42 AM   #26
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Project Revival
Sep for the truck started in 1987/88. If you get a waterpump just make sure it is reverse flow or for a serpentine setup. Anything prior to 87 (pickup) won't work. The pump only runs backwards, it still cools the Block first. LT1's cooled the heads first.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-28-2008, 02:12 AM   #27
spudz
spudz's Avatar
Re: Project Revival
if you get the wrong pump, just unbolt the back and swap the impeller.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 02-28-2008, 03:25 AM   #28
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: Project Revival
You can also use a 88-92 Camaro water pump. Doesn't matter if its for tbi or tpi just as long as its a v8. They both had the serpentine system.
MylilBowTie is offline   Reply With Quote
Old 02-28-2008, 03:38 AM   #29
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
Re: Project Revival
Try Coca-Cola for "unsticking" the 327.....yeah, I'm serious.....
And on waterpumps.....I've had very good luck with the high volume pumps from Summit...
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
Old 02-28-2008, 04:54 AM   #30
85gmcguy
Plays with trucks
85gmcguy's Avatar
Re: Project Revival
For unsticking the motor, I'd try "Kroil", or the CRC knock-off they call "Knock-R-Loose". They work like a champ on most machinery that I work on. Water pump- you might want to check Rockauto.com. They usually have several brands to choose from for most parts and it's hard to beat their prices.
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 02-28-2008, 12:25 PM   #31
84 400
Sb 400 club
84 400's Avatar
Re: Project Revival
Thanks guys for all the input. I got a call today and it looks like i will be going home this weekend
So i am going to take a really good look at the water pump situation. I dought it but it could be that the bolts holding the impeller cover on have come loose. Unlikely but it is possible. If that is the case then I will have her drivable for the march 16 dead line. I hope it is then all i have to do is the tranny gaskets and rear end fluid which would be sweet. I am going to pull the motor and tranny as planned but i need to get my boat over march break (been sitting there for a few years).
On the 327
Well Like i said we tried alot of things and nothing happened so i am just gonna pull it out and drop the pan to see whats going on there. I am hoping to rebuild it some time and reinstall it in the wagon. But i am a broke a$$ college kid so that will be a while.
Thanks for all the help I hope some of this snow melts by friday
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 02-28-2008, 04:02 PM   #32
James McClure
One shot, one kill.
Re: Project Revival
84. Pumps don't actually flow in the opposite direction. Water moves as it always did, from lower rad hose and into the heads. It rotates in the opposite direction, SO, the impeller inside the pump is cast in the opposite direction of the older "V" belt type pump. PAY ATTENTION NOW, take a look at the pulley on the pump. If it doesen't have grooves in it you have to use a reverse rotation pump. IF it does have grooves you can use a regular pump because rotation is the same as the older ones. I have an 86 WITH a serp belt but pump rotation is the same as the "V" belt older pump. To be absolutely sure, watch pump rotation on your truck and compair it to a "V" belt setup. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 04-29-2008, 07:39 AM   #33
84 400
Sb 400 club
84 400's Avatar
Re: Project Revival
Well got an update
Got all my parts together from about 2 months ago and since i was home from school I figured now is time to get this thing going again!
Here is the parts I got... I know just normal tune up stuff I was really happy to be working on the black truck again. (air filter, Trans filter/ gaslket, water pump, tail shaft seal, rear end gasket, Duplicolor motor paint, ultra black RTV, B and M trick shift fluid, Castrol 80/90 gear oil)
Next that old pump came off. I always hate working on cooling system it seems no matter what you do there is always a spill..... yeah with the Serp. belt those gaskets where a PITA to scrape off
Taking a break from the scraping I installed the new air filter. I ditched the old 3 inch and the riser with back port that was on my carb. I like the look alot better and seems to run a bit better too
1985 C10 LWB Sold
Old 04-29-2008, 07:44 AM   #34
84 400
Sb 400 club
84 400's Avatar
Re: Project Revival
My dog took a break to pass out in the sun. Normally she is helping me but with the coolent and her love of "self walking" I decided it was best to tire her up to the Tahoe
To avoid future rust I hit the brand new Water pump with Duplicolor paint. I hope this hold nice and tight for a good while. I thought of using there high temp primer but figured this would be worth a shot: I am not happy that the NAPA pump has an acessery hole. I used the supplied block off placing ultra black on the threads and gave it a light scuffing so my paint would stick
Next it was on to the tranny.........
1985 C10 LWB Sold
Old 04-29-2008, 07:49 AM   #35
84 400
Sb 400 club
84 400's Avatar
Re: Project Revival
This is where things got a little hairy... Once i had the pan off I found this gunk waiting for me................. some kind of stop leak??? Any ideas?
Kinda like a gray coop not too gritty tho
Got it all back together and filled it up. I had a air pocket on first start up that cause the water to rise out of the rad. I thought my pump was wrong rotation but it later setteeled. She now runs right at 180. I added the B & M trick shift and it goes into gear real smooth but how much did the TH350C take? I put in 4 bottles and i think it is still ow.
Belt routing had me confused till a friend of mine sent a diagram
1985 C10 LWB Sold
Old 04-29-2008, 07:53 AM   #36
84 400
Sb 400 club
84 400's Avatar
Re: Project Revival
Well she is a runner!!
That is the boat I built back in high school. It will get fixed up this summer there is a long story behind that skiff. I hope to get new seatbelts in soon get the seat brackets sorted out. I will also be showing the install of the speaker brackets I got off Bigblock73 once i get a chance to install them. So that will be it for a while till i get home some time next month....
And I know I gotta get rid of the glass filter and wash and clean her.
1985 C10 LWB Sold
Old 04-29-2008, 08:38 AM   #37
spudz
spudz's Avatar
Re: Project Revival
thats actually clutch matterial....
Old 04-29-2008, 10:12 AM   #38
SBTork
Garage wrench
SBTork's Avatar
Re: Project Revival
really? there's probably no comfort in knowing that.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 04-29-2008, 03:35 PM   #39
MylilBowTie
Right turn Clyde
Re: Project Revival
Gotta part number for the air filter?
Old 04-29-2008, 05:09 PM   #40
84 400
Sb 400 club
84 400's Avatar
Re: Project Revival
No part number( back at school now) All i did was take a measure of my filter and go to pep boys. When there I looked for the biggest filter I could find. IT is a no name brand. It was the largest they had. Might try Pm gchemist he is knows about larger filters
1985 C10 LWB Sold
