#26 |
Re: much modified 48 trik
Yes-it was a lot of work. I worked 5 hrs a day for over 2 yrs. It was just too much. I had to walk away from it for 7 - 8 mos. just to get my head straight again.
I just started to work on it again. Pics. to follow. Don Meyer Last edited by weldvair@embarqmail.; 03-18-2008 at 09:23 PM. |
#27 |
Certified Car Nut
You are doing some nice work there
#28 |
As already mentioned, you have a nice project going. I sure would like to see more progress pictures as it gets further along. Keep up the good work!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
#29 |
It was a lot of work...too much. I made so many mods that the normal 1 yr project is turning into a 2 1/2 yr project. I really enjoy the body work & suspension work, but get bogged dn at the details at the end.
The alignment of the GMC hood that I converted from a Chevy hood, A homemade core support & fiberglass fenders that were 2nds has turned out to be challenging. Don Meyer |
#30 |
Glad to see that your still hangin in there. With so much modification and fab work, there can be lots of challenges. Those two wooden crates that are at the front of your truck, are they still holding up your fenders, or have you got the fenders in their final resting place? Just curious about the alignment and stance. I see a pair of chrome pullies peeking out from the engine compartment. Got any plans yet of A/C and accessory brackerty? Aftermarket serpentine system?
58 Apache short fleetside ona 64 chassis: ![]() |
#31 |
Yes the fenders are finally in there final position. It will sit a little lower when done. It has a Must II w/dropped spindles w/V-6 springs. It looks like I might have to cut a 1/2 coil. It has a Vintage air evaporator & Allen G brackets. Not single belt.
Don Meyer |
#32 |
I took the nose off to change the spindles. I went from 2" drop to stock. I only had 4" clearance.....I will now have 6". I'm using v6 spring & as I remember I cut i/2 a coil.
I found that the ball joints were so tight that I could not move the wheel w/it off the ground so the mfg is sending me new ball joints. I also hocked up the steering. Last edited by weldvair@embarqmail.; 04-10-2008 at 03:47 AM. Reason: pic |
#33 |
Fat Fendered Fleetside
awesome pics of an awesome custom job.
keep it up man |M|
71 GMC lwb 56 Big window swb 93 GMC Sonoma (dd) radiused fiberglass fender project for 67-72 |
#34 |
I'm always fascinated by what some of you guys can do with sheet metal. Very nice.
04 4x4 GMC Ext. Cab lifted 71 2wd GMC / Ramjet 350 ready for sheet metal 49 Studebaker pickup |
#35 |
Thanks...remarks like those makes it seem like it was worth the efford.
Don Meyer |
