#26 |
Re: HEI coil in cap dizzys
I just put an HEI on my 72 bbc, the only thing I can add other than the simpliest upgrade yet, is watch what plug wire you get I had to go with wires from a 75 with a 454 in it to get the straight plug boots that I needed. I also picked up mine off of ebay 50 bucks
Mike K Friend of Bill W |
#27 |
I just bought one of the Skip White HEI's after reading this post and will be putting it on this weekend. Are there any tricks or tips to look out for with that one I should know of? Also any advice on plugs that will compliment those well?
CARPE CERVASIUM! ![]() 1968 C10 Fleetside LWB Remember Cthulu is watching you! / (@) (@) \ |
#28 | |
![]() Quote:
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride ![]() ![]() 54 caddy 62 series 4 door(younger sons ride, aka 54caddy ![]() 70 caddy 2 door, 89 chevy silverado stepside(older sons rides ![]() |
#29 |
Well didnt get it to this weekend. I had to many things going and not enough time. Hopefully I will get to it sometime this week.
#30 |
![]() Join Date: Apr 2007
I put a second hand stock GM hei distributer in my 69 Camaro Convertible in 1986.22 year,100,000 miles 2 moters,same module no problem!!!!
#31 | |
![]() Quote:
#32 | |
Gone to greener pastures
![]() Join Date: May 2007
If I'm wrong, please correct me.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
#33 | |
![]() Quote:
#34 |
The Older Generation
Just so you don't get coffee logged here is a couple of pictures of the Skip White HEI I just installed in the beater. So far so good. If I had it to do over I wouldn't get the 8.5mm universal plug wires. Putting the ends on them was a pain in the a$$. I would buy a set of ready made 7 or 8mm. LockDoc
#35 |
I bought one and installed it last weekend on my 402. It works great. Idles smoother and better acceleration than the tire GM HEI I had in there.
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
#36 |
You are not wrong. HEI units run best on full voltage, not the reduced voltage used for a points distributor. I typically re-run ignition wiring so that the original 9V-ish ignition wire engages an ignition relay that supplies full battery voltage to the HEI distributor.
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
#37 | |
![]() Quote:
#38 | |
![]() Quote:
#39 | |
It was even better that your young blood found the problem. I've heard that Wyotech is a good trade school, and this goes way back to when you had to go to Wyoming to attend. Yeah. I'm that freaking old.
#40 | |
![]() Quote:
#41 | |
My son built his 1st engine (BB for my flat bottom) when he was 15. (I was looking over his shoulder, every step) I made him end gap every ring & make sure that the rings went back into the same cylinder they were gapped for, plastigage every bearing, etc. When we finally got the boat in the water & putted around for about 1/2 hour, I asked him something like, "You think you did a good job of putting the motor together?" He said, "Yeah." I said, "We'll see." I nailed the throttle and spun that sucker to 6 grand, plus a little, and held it. It was still running good years later. Gotta love the kids.
#42 | |
![]() Quote:
#43 |
I have done every scrap of work on my truck in the past 2 wks, with assistance from you guys, but all of the work done was by me, and i am darn proud of it.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
#44 | |
![]() Quote:
#45 |
And you should be!
#46 |
"Trucks with Class"
![]() Join Date: Jul 2000
I have had several of the modules fail in my HEIs...and it is easy to change, on the road, in the truck. It is a hassle to try & get to an auto parts & back when you break down away from home.
So I always buy a new hypo modulator, install it and put the old/good modulator in the glovebox for emergencies. Run on the good one & save the OK one. There is a new compact elec dist on the market. It uses an external coil and NOT HEI components. There is no history or experience on it, so I would also get a spare module for it. I may look into it later. I hate to be the "tester" for new stuff. |
#47 |
STOLEN
![]() Join Date: Jun 2006
Can a new GM HEI unit be purchased for use on our trucks(if so where?), or do you have to keep an eye out for a reman?
In Search Of |
#48 | |
laying low
![]() Join Date: Mar 2001
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#49 | |
![]() Quote:
#50 |
Get one out of a boneyard and rebuild it.
