03-04-2008, 10:46 PM | #26 |
It just doesn't matter
Re: I possibly lowered it TOO MUCH!
Good cover Mondo..... wife was looking wasn't she?
05 Chevy Silverado..... A rogue BMW guy.... If you don't like me- TAKE A NUMBER; There are people ahead of you!! |
03-05-2008, 12:57 AM | #27 |
never know when they'll walk in
03-05-2008, 01:10 AM | #28 |
Looks like you got it just right.
esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) |
03-05-2008, 07:31 AM | #29 |
Insert Title Here
Heres his pics.... it does look to sit lower than most i have seen...but it looks real good to me
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << Last edited by 1LoC10; 03-05-2008 at 07:31 AM. |
03-05-2008, 07:31 AM | #30 |
Insert Title Here
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
03-05-2008, 07:32 AM | #31 |
on my truck I bought the drop spindles and drop coils. disc brakes also. with the 17 inch rims I was super low. to change the height I bought some 20's. It raised it up a little bit. in the rear end I also put some drop coils in the rear. tire rubbing is an issue on the roadways. I will post with this set up and then what I did to make it all better.. after I did the dropping...
03-05-2008, 08:06 AM | #32 |
I wish the front of mine was that low. You may want to go a bit smaller with your front tires though. How did the frame shortening go with the cab on it? Not that I may have that mod planned for my trucks future or anything.
03-05-2008, 08:24 AM | #33 |
It was not a job for the faint of heart. Hard part was making it square again. EVERYTHING moves! If i were to do it again, Id take the cab off.
03-05-2008, 08:46 AM | #34 |
A guy with a truck
My truck sits at exactly the same height up front with 235/75-15s. I have zero rub issues- but(there's always a but) I am running the 7" wide van rallies(look just like the truck rallies- but narrower) up front. This pulls the tires in a little and keeps them from rubbing the fenders.
If you were to use a shorter tire, you would start getting the lower control arms closer to the ground- which if you look under there- does not need to happen. You've got the perfect height right now, tuckin' just a little tire, you just need to swap to a wheel with a little less width and more backspacing. There is also a 6.5" wide van rally found on some of the late '80s fullsize vans. Good luck with your project.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
03-05-2008, 08:56 AM | #35 |
HELL NAW SUHN!!.. as loong as your leavn those wheels an tires on it that ISH is MONEY!!!!...nice. ..color stance everthang!!..hell yeah.
03-05-2008, 09:19 AM | #36 |
its all about the +6 inches
toss the bed on there so you get an idea of the whole picture.
I think it looks bad ass myself. I say finish the truck up... whats the worst that can happen, you have to split a ball joint and slip another spring in there... the same that you'd have to do now. So give it a whirl and see what you think. |
03-05-2008, 09:32 AM | #37 |
Insert Title Here
The frame is cut to a shortbed and the bed is still a longbed...so he cant just toss it on
03-05-2008, 11:54 AM | #38 |
I may go with a van front ralley wheel. I hope to have the floor cut and new short box sides on the bed this week. Hope anyway. Thanks for all the compliments on my truck. The green is going and black is comming. If it blocks out ok Ill go base/clear. If it wants to try and kick my a$$ while blocking, it will go "hot rod black"
03-05-2008, 12:04 PM | #39 |
heres one from a shop by me, KILLER CUSTOMS
03-05-2008, 08:23 PM | #40 |
Questionable
I will never understand why people chop tops. I understand raking a top - that looks classy when it flows with the body lines better than stock. But ugh, that is friggin awful!
To each his own. I know dudes who really love porkers for women (chubby chasers) so I guess everyone has their own thing.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 03-05-2008 at 08:23 PM. |
03-05-2008, 09:14 PM | #41 |
Insert Title Here
hey now... i love me some chubby women
03-05-2008, 09:37 PM | #42 | |
Prestige Worldwide
03-05-2008, 10:28 PM | #43 | |
The van rallies also don't have as deep backspacing so the ywill pull the tire into the wheel well a little more. I think once you get a bed on it and maybe drop the front tire size a bit, you will find that it sits just fine. I think you maybe just are getting a distorted view since it doesn't have the bed on it. It makes it look out of proportion. I think you did just fine personally.
03-05-2008, 11:50 PM | #44 |
What type of bed cover is that on your truck ?
thanks
1955 Chevy 2 door Wagon 1967 Short Wide BAGGED Gone to someone else 1953 Shop truck Clipped and Snipped sold 1951 GMC Bagged and patina |
03-06-2008, 12:35 AM | #45 |
dave
Never Ever Low Enough Post Up The Pictures Already
check out my build "DIRTY BURB" |
03-06-2008, 12:44 AM | #46 |
Insert Title Here
i posted them already
03-06-2008, 01:41 AM | #47 |
You could bag it and drive it any height you want. You can never lower one too much. I am still trying to get mine lower w/out chopping the top. A chopped top on a 67-72 chevy truck really is an eye sore!!!!!! IMO
03-06-2008, 01:46 AM | #48 |
Insert Title Here
section the body
03-06-2008, 02:13 AM | #49 |
Sweet Yo ! Bad ass!
Yep I love fat chicks too! lol
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
03-06-2008, 02:14 AM | #50 |
1972 Chevrolet SWB
I have to agree 110% on that. There are just some body mods a 67-72 truck dont need in my opinion and a chopped top is one of them.
My New thread with pics (not my build thread yet.) http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
