Old 03-05-2008, 08:48 PM   #26
sleepyboy
'69 Step
Re: Butt Welding help?
I use 030 wire. My instructor always said it should sound like frying bacon if the heat is set correctly. Popping is from dirty material. Burn through is often from too hot of a heat setting; need faster wire speed, and move faster. I like to spot weld counting to 3-4 seconds per trigger pull. After that time, it is time to stop, or move to another spot. Moving around minimizes distortion and always have water and a rag handy.
It's my truck, and Yes, I CUT the dash, so what??
sleepyboy is offline   Reply With Quote
Old 03-05-2008, 09:19 PM   #27
BustedTruck
BustedTruck's Avatar
Ok I got this welder dialed in today. I love this thing. It rocks. Shifty I have already purchased the same clips. The gauge metal I was practicing on was like 20 gauge. Once I got the welder settings right I was able without burning through at all. Thanks for all you help.
BustedTruck is offline   Reply With Quote
Old 03-05-2008, 09:23 PM   #28
shifty
Questionable
shifty's Avatar
Perfect, now make the hour drive down here to my place and teach me how to weld
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-05-2008, 09:45 PM   #29
Number98
Prestige Worldwide
Number98's Avatar
Also remember the gaps... The thinner materials will need a bit thinner gap or it will also cause more burn through.
Number98 is offline   Reply With Quote
Old 03-05-2008, 11:50 PM   #30
BustedTruck
Thats more like a 2 hour drive, but I have been wanting to come check out that truck of yours anyway. Your truck is in all pieces and it is still furthur along than mine.
Old 03-06-2008, 12:01 AM   #31
shifty
Questionable
shifty's Avatar
The powdercoating shop I'm dragging it to is about halfway between my place and yours. It's been a while since I've been up your way, but rest assured, I plan on doing some weekend cruises to meet some of my fellow GA board members when it's rolling on its own. Maybe I can chat with "SeeTen" and organize a cruise or something
Old 03-06-2008, 01:30 AM   #32
BustedTruck
I would be up for that. Who is your powder coater? I want a few things done. If there is any way I can help you with anything let me know. Its because of you & this board I decided to go the gen III route with my 71. Thanks.
Old 03-06-2008, 05:00 PM   #33
Number98
Prestige Worldwide
Number98's Avatar
I have used Performance Coatings over near Jonesboro for years and they do a great job, not bad on the prices either...
Old 03-07-2008, 09:59 AM   #34
67L30WGN
67L30WGN's Avatar
For sheet metal tack welds, I use .023 Wire. You want a small gap, about the width of a thin cut-off wheel, between the edges. Tack at even intervals along the seam to hold the gap or else the pieces will suck together.
You have to feel out your own welder as each is a little different. For mine, when I'm tacking two pieces of sheet metal, the welder acts cold, so I have to step up my power and wire speed to the next higher setting compared with laying a bead (chart inside welder). Actually, as mentioned above, I step up the wire speed even a little more. I also find if I give a quick snap of the trigger and then a slightly longer one, I can get the tack to grab the metal better. The first one heats the edge and the second lays down most of the material. If my gap is a little wide, I sometimes have better luck with the first pull at a slight angle so as to catch the two edges rather than send the wire between the panels. This works well when filling holes.
I prefer to tack and cool, tack and cool entire panels, alternating to cool areas as I go, rather than run beads. Beads shouldn't be any longer than 3/8 - 3/4" or you will get warpage. When required, I can metal finish both sides of the panel so that it looks like it came that way from the factory, such as when filling trim holes that can be seen from inside a trunk. Good luck. I'm self taught, but happy with my results. You can be too.
1972 Cheyenne Super 10 LWB
1965 Nova SS Evening Orchid
1967 Nova Wagon Factory Disc (1 of 565), 327/PG
1964 Ford Fairlane 500 HT
1962 Nash Metropolitan Convertible (Wife's car)
67L30WGN is offline   Reply With Quote
Old 03-07-2008, 10:05 AM   #35
David Flores
David Flores's Avatar
That sure is purrdy!!!
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 03-07-2008, 10:14 AM   #36
67L30WGN
67L30WGN's Avatar
Thanks, man. It weren't pretty. Ended up rebuilding the entire A-pillar and corner of cowl!
This is what it looked like with the windshield in place. Who knew?
