03-07-2008, 08:47 AM | #26 |
A guy with a truck
Re: My weekend project
Are you just raising it 1"? I thought about doing a 1x3 rectangular tube frame, but decided that would be way too heavy.
My current idea is a little more "permanent". It involves cutting the bedside flanges off, turning them 180*, and reattaching them to the opposite bedside in the same position(albeit 3" higher) via plug welds- if that makes any sense. Same rules apply for the front panel. The rear stake pocket posts will have to be shortened 3". It's either that, or take the corner out of the floor, but then you lose the 4 bolts at the rear crossmember that keep the sides from bowing in. The tubs will need new holes drilled in the bedsides for the upper attachments, but bolt in the stock location on the floor. It's only metal- right Edit: The filler neck should not change. The tank and bedside will be in the same spacial relationship as before. I will need to figure out a new cover for the inside, as my Blazer filler cover won't fit anymore. Now I regret cutting the rear cross sill to fit it before...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 03-07-2008 at 08:51 AM. |
03-07-2008, 10:09 AM | #27 | ||||
03-08-2008, 02:53 AM | #28 | |
A guy with a truck
I thought about mounting the tank to the under side of the top of the framerail "C", which is what I'm assuming you did, but it would cause my filler tube to run uphill. I also thought about using a 73-87 Blazer tank(they are much shallower below the framerail), but I don't think I can make it work- there simply isn't enough room for it while keeping some sort of rear crossmember or towing hitch. I may try what I have planned for my Blazer, which involves a Jeep Wrangler tank(uses the same sending unit as the 73-87 Blazer) -we'll see how it goes...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
03-10-2008, 06:14 AM | #29 |
Do you happen to know the part number and manufacture of the bags you used. I have found the 1.5" blocks and C-notch at CPP and but I was curious about the bags. I have found what I think are basically the same at airbagit.com. Thanks for the help
Happy Truckin HP |
03-10-2008, 06:42 AM | #30 |
A guy with a truck
They are Slam Specialties RE200, 7" diameter. I have been getting them from *****************. Cheapest price and always good service...
03-10-2008, 08:15 AM | #31 | |
Go Firestones or Slams.
03-13-2008, 03:15 PM | #32 |
Looks good but I say just section out the bed and save weight. Yes it is a bit of work but it's not like you have anything else to be working on
Kevin LFD Inc. |
03-14-2008, 07:57 AM | #33 |
A guy with a truck
Riiiight... The other project is VERY lonely... I seriously contemplated using that method due to all the body lines staying true through the whelwells, but in the end I went with the easier way, that didn't require quite so much welding. 9-out-of-10 people won't even notice it. The other 10% are boardmembers. I'll have some semi-complete pics up tomorrow.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 03-14-2008 at 07:57 AM. |
