03-12-2008, 11:48 PM | #26 | |
Re: My DJM flip kit install pics
1 - The thickness of the DJM axle locator bracket is about 3/8". The height of the spring center bolt sticking thru the spring pack is about 1/2". If you do not remove and flip the spring center pin, then it will stick up thru the axle locating bracket. This may (or may not) cause interference with the axle tube. 2. Since the DJM axle locator bracket has an offset hole, the spring center bolt no longer lines up with the 'dip' that is in the stock spring plate. So the hole is needed to provide clearance. What kit have you used? I would certainly like know if there is an easier way.
- Greg |
03-13-2008, 12:28 AM | #27 |
Just thought I would throw these pics into this thread as well. These are the DJM 3" drop lower control arms. I have the upper A-arms too. Sorry I don't have pics of the install, but it is a pretty simple remove and replace.
I'm still a few weeks away from getting the truck running, much less drivable. So hang tight on seeing the finished stance.
- Greg |
03-14-2008, 12:07 AM | #28 |
Looks like your headers will be very near to the street!Mine hang very low too we bent them upwards a little to clear the flange from scraping!
I´m curious how low yours will sit!
My little US vehicle parts business: http://www.thegearheaddepot.com/ Come have a look! ´81 GMC C 10, Spanish Red |
03-14-2008, 12:54 AM | #29 | |
My vote is install the shock extenders and a decent set of stock shocks. |
03-14-2008, 02:59 AM | #30 | |
67-72 parts collector,…
03-14-2008, 04:25 AM | #31 |
Chris
I got a few questions...
how low do those front controal arms drop you up front? Stock springs with them? How much do they set ya back(cost) Looks to me like your headers will run right under the crossmember. So... What year is your truck because I wonder if my 84 is that way like yours because I wanna put on some long tubes but I'd hope the pipes could run straight back and not need bent. So is that stock crossmember? ANyone tell me if our 84 has same one, haven't climbed under there to check lately, and what headers do you have anyways?
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
03-14-2008, 09:15 AM | #32 | |
Control arms are advertised 3" drop. Yes, stock springs for a small block. I have swapped in a big block though, so I don't know the actual drop yet. Need to finish up the engine before I can measure. Cost?? I bought them years ago... but I know they are considerably more expensive than drop spindles. That is not the crossmember that came on this '86 truck. It's a double hump that I salvaged from my old '77 big block truck. The headers are Hedman Elites.
- Greg |
03-14-2008, 09:20 AM | #33 |
So you rotate the spring plate 90°?? I guess that would work as long as the U-bolts still go thru the holes.
- Greg |
03-14-2008, 03:10 PM | #34 |
No,... I just rotate the plate forwrd until the bolt falls in the "dip" of the factory u-bolt plate. The hole you drilled and the "dip" are only about an inch apart. Like I said,... what you did looks fine,.... I've just never had to do that. Keep the pics coming. And,... I like the big block!
03-15-2008, 03:01 AM | #35 |
i feel like an idiot all of a sudden when i installed my flip kit it didnt have directions and none us had ever put a kit on any truck before, looking at your truck i just relized what those to parts were for they were shock extenders (im an idiot). so now i knw what im doing this weekend putting on my shock extenders................ woooooooooo hoooooooooooo for double work.
04-22-2008, 06:39 AM | #36 |
lucky knuckles
thanks for updating the thread with the play by play 454HO.
i just ordered my parts, this thread is going to be very helpful with the install. |
05-24-2008, 09:23 PM | #37 |
that was some helpful info!!!!! keep it coming!
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks ) 54 caddy 62 series 4 door(younger sons ride, aka 54caddy ) 70 caddy 2 door, 89 chevy silverado stepside(older sons rides ) |
05-26-2008, 11:37 PM | #38 |
Any overall before and after pics? Looking good!
05-27-2008, 02:21 AM | #39 |
Sorry, not yet. I need to get some longer studs for the upper control arms.
- Greg |
05-27-2008, 07:58 AM | #40 |
I don't think these pills work
to SPR85GMC ha ha very funny good stuff. as far as flip kit i used the western and it comes with new plate with 2 holes drilled in it to locate the rear axle didnt have to remove or replace leaf spring bolt and no drilling.
SQUARE84 90 SUBURBAN |
05-28-2008, 10:22 PM | #41 |
Smok'em Roast'em Shift'em
Is the western chassis flip kit a good product? Im looking to get the 5/7 inch lowering kit from them.
05-29-2008, 01:29 AM | #42 |
westerns kit is real nice new spring plates, u bolts, washers, aircraft nuts, and spring perches. all coated so they dont rust and for 50 dollars extra they throw in shock extenders.
05-31-2008, 06:27 AM | #43 |
Finally got the truck out of the shop and took a decent after pic.
It looks a little deceiving 'cause the ground slopes down toward the front of the truck. But that's the best I can do at the moment. I added this pic to post 11 back on page 1 of this thread. You can see the before pics there too.
- Greg |
05-31-2008, 07:04 AM | #44 |
*NO REGRETS*
Looks Good!
06-01-2008, 01:47 AM | #45 |
It Is What It Is,,,,
Oh Yea!!!!
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den |
06-01-2008, 02:32 AM | #46 |
What size tire you running with that drop? They almost look like a 255/70/15 ? If so, that is perfect, since that is the size tire I was planning on running when I do my drop. Instead, I am only doing a 4'' rear drop (shackles and hangers) and 2.5'' spindles with possibly 1'' springs since I want more of a rake than your truck has, plus I don't want to notch my frame, like with the flip kit.
06-01-2008, 05:21 AM | #47 |
These tires are 275/60 x 15, and the rims are 8" wide with 4.5" backspace.
- Greg |
06-01-2008, 06:05 AM | #48 |
Very nice setup. I would like for mine to tuck the front tire some though.
I have a flip kit 2" front drop springs, and 3 inch spindles. I hope it tucks the front a bit. I really like how your truck sits.
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq |
07-03-2008, 02:19 PM | #49 |
Cool 454HO, why did you choose drop A-arms over drop spindles? Is there an advantage?
------------------------------- '66 GMC Custom Fenderside LWB '90 IROC - L98 '97 1200C Sportster |
07-03-2008, 03:47 PM | #50 | |
I installed a flipkit from belltech and had to discover that there were no shock extenders in their kit ??!! What should I do now ? Should I buy some of another brand ? Or what do you think ? I thought the stuff from the belltech guys should be pretty good and now this....? thanks for your opinions, Rob |
