03-12-2008, 08:37 PM | #26 |
Re: ART StrongArms, $639/set
yea, thats what I figured. Who wants overhead.
03-13-2008, 11:53 PM | #27 |
Questionable
For anyone wondering -
The ART arms came in today. The box weighs nearly 100lbs, and is 24" x 24" x 24" in size, approximately. So, IMHO, $65 is not an excessive amount for shipping. And yes - the coupon above obviously works
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
03-14-2008, 07:15 AM | #28 |
Guest
Posts: n/a
sweet! i'll be ordering a set soon.
03-14-2008, 07:21 AM | #29 |
1972 Chevrolet SWB
Awesome deal shifty.
I sure was wrong in my thinking that such a large place would be drop shipping items like Stylin. I stand corrected. Maybe I should call about renting some of their empty warehouse space.LOL
My New thread with pics (not my build thread yet.) http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
03-14-2008, 08:14 AM | #30 |
A guy with a truck
Gangster! Where's the mock-up pics? Get to work already
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
03-14-2008, 08:44 AM | #31 |
Questionable
Man, I have way too much else to do. I got the rear of the frame taken care of, gotta weld in the notch, gotta finish welding up unnecessary holes which means I gotta mock up the drivetrain this weekend to figure out which of my tranny xmember holes I can delete, and then gotta decide what other holes I'll keep. You know, I'd hoped to have it coated already, figured that woulda been first to get done, but all these junkyard runs and parts runs and other BS have set me back!
The whole reason for tearing this thing down was to change the quick connect fitting on my T56! WHAT HAPPENED?!!
03-20-2008, 04:02 AM | #32 |
hey i order mine with bags ,shock ,upper arm, lower arms 885 ship to my door what a deal. 999 without the discount thanks alot
03-20-2008, 07:21 AM | #33 |
Questionable
Glad it helped someone out! Don't forget to post pictures once you get em installed!!
04-02-2008, 06:50 AM | #34 |
Thanks Shifty. Just ordered the full coolride with upper and lower arms and a musclebar.
I can't decide if you saved me $260 or cost me $1100+???
Richard 1970 Chevy (growing pile of parts) 2003 Silverado SS |
04-26-2008, 06:20 PM | #35 |
Shifty,
If I order the 73+ arms, then I can just use the 73+ drop spindles for a set of 73+ brakes with my current crossmember, correct? Then all I need is the tie rod adapter to stick with the stock steering linkage until I go to the rack setup. I will be using a dropmember once my motor is built, but I want to get the arms/discs/bags in now. I used the cheater disc kit last time and paid way too much for ball joints and tie rod ends. I will convert the rear to 5 lug discs when I put the kp notches in.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
04-26-2008, 07:30 PM | #36 | |
Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
04-26-2008, 08:00 PM | #37 | |
I want to run a dropmember, but I won't be pulling the engine for at least a few months. My goal is to swap out the control arms, brakes, and install the bags. Then once my motor is done, pull the gasser, install the dropmember, then install a 6.2 turbo diesel. I hope to start a build thread soon. The '66 will pick up where the '69 left off.
08-01-2008, 11:17 PM | #38 |
wanna be 67
is this still good? any pics of items?
