#26 |
Re: brand new HEI chevy distributor $42.95???
The coolest thing in his ebay store he sells small cap HEI dizzys. They look like the stock points type, but are HEI. You have to use an external coil with them, but that's cool. He's also got one made specifically to hook up to a MSD 6A or 6AL. And the prices are right. Sweet...
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
#27 |
Will that tall cap fit in my 72 with 402? I converted to HEI with a 78 SBC GM dizzy, and I think this cap is taller than what I used.
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
#28 |
![]() Join Date: Dec 2006
I got a $46 "HEI" type distr. from Skip White and it wouldn't spark AT ALL. Wasted a lot of time with that thing,but when I called him about it with the ohm readings etc.he sent me another unit Next Day. Now that's how to do business. Second one has been perfect.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
#29 |
Engine n00b
$101 added to excel spreadsheet in the "purchased" column.
#30 |
I have the ProComp 9000 - got it from Ebay new in the box.
Worked great for about a month, then no spark. Replaced the ignition module with the Niehoff DR400CS from Kragen and it fired back up. I also added a ground wire from the corner of the coil that goes to the firewall. Read about that on a racing car website. Not sure if that will prevent modules going out, but we will see. As a side note, the coil I bought for troubleshooting was a Niehoff DR184CS - I am glad the ProComp one worked, since the Niehoff had real thin wires going to the terminals. At least compared to the ProComp. We will see how long the 19.99 module lasts. The ProComp has Australia written on the top, and the Niehoff said 'Hecho in Taiwan'.
1971 GMC 1 Ton Custom Camper - I think.... Last edited by bill_in_sd; 04-28-2008 at 05:32 AM. |
#31 |
for what it's worth, the skip white distributor is made in australia (i think), not china
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
#32 |
I bought a few of those dizzys. I think they are pretty good. I had one that had a random no start problem (hot or cold) But I called him up and he had one at my house fedex the next day. Threw it on and it worked fine. i would definately buy from him again.
SHawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
