Old 03-26-2008, 07:10 PM   #26
collin86
Re: installing my first 4 link w/coilovers
Originally Posted by leftcoast66 View Post
Sorry my truck is in seattle and I screwed up on the 4 link so haha, means its backhalf time when school gets out and before my lease starts here in spokane for a house.
Lemme know I've got a really good document about building 4 links and such from over on another forum. In depth about the do's and don'ts and why of it all.
do you have a link to that document? i would like to see it.
how did you mess up your 4 link
1986 swb...soon to be some weird pro touring look..but better
92 jeep cherokee.... crawler
collin86 is offline   Reply With Quote
Old 03-26-2008, 10:56 PM   #27
GWEE
GWEE's Avatar
i to would like to read about biulding a 4-link.
1985 GMC ( future plan pro tour build for the wife )
Black 2013 GMC single cab 4/7 drop on 24'' Torque Thrust ST
rules
GWEE is offline   Reply With Quote
Old 03-27-2008, 04:25 AM   #28
collin86
airmale...what is the length of your 4 link bars
Old 03-27-2008, 05:16 AM   #29
56 3100
56 3100's Avatar
hey collin iam glad i found this post! air male good pics of alston suspension on your truck . i have the same set up i want to use on my 56 chev 3100.i seen chev truck build on chris alston site
56 3100 is offline   Reply With Quote
Old 03-27-2008, 06:43 AM   #30
leftcoast66
leftcoast66's Avatar
Mk, here's all the stuff. It was written by Max at Bio Kustoms I believe is the name. I got it from Twisted Minis over on streetsourcemag.
Here you go:
Why so much talk about rear suspension? It seems these days no self-respecting minitruck is show worthy without an attention commanding “Goldberg device” (look it up) hanging out of a cavernous hole in the bed. Most rear suspension designs are limited to certain confines that don’t create many severe affects, but there are major design considerations that should be taken in account. Regardless of how you lift the frame off of the rear end, the links that connect the rear end to the chassis are what affect the dynamic relationship of the vehicle to the road. Before we go into the actual suspension designs I think it would benefit us to define the affects.
Every suspension design has its benefits, even the tried-and-true 4-link has infinite design options to be an advantage in one area more than the other. The dynamics that are affected by the design, that are important to us here are…
- Roll-center
- Roll-steer
- Anti-squat
- Pinion angle
Also, before we even discuss these we need to define instantaneous center or instant center. What instant center is is a theoretical point in space that is used to calculate suspension affect. The way to find instant center is easy once you “get it.” When you have two or more, bars, arms or what ever you are working with, each part is only as long as a straight line drawn from pivot to pivot. If you were to extend the line drawn through those points into theoretical “space” and do the same through the pivots of the other related parts, hopefully, at some point, they will meet. The point at which they meet is the instant center. If this doesn’t make any sense keep thinking about it until it does. To continue reading without understanding instant center is not going to be as fruitful as it should be.
Now that you know what instant center is let’s talk about roll-center. Every suspension design sets a point at which the vehicle “rolls” from side-to-side. Most of the time the point moves around depending on where the suspension is in it’s travel, but it is still important. On a straight axle type rear suspension the roll-center is “set” by whatever is used to eliminate lateral movement (i.e. panhard bar or even a triangulated type link system.) What happens, is that the center of gravity acts upon the vehicle through its roll-center. The higher the roll-center the lower the vehicle feels in cornering. Don’t get greedy though, too high of a roll-center and the car will act odd. The chances of having a high roll-center at the front suspension is not good and the vehicle will act unbalanced. Any decent rear suspension design will have a roll center around the center of the rear end, which is fine.
Roll-steer is a little more important and could cause some really poor dynamic affects. Roll-steer also comes in flavors, roll-understeer and roll-oversteer. Every straight-axle rear suspension design, that actually affects performance, has roll-steer in some amount. Roll-steer is always measured when the car is leaning toward the outside of a corner. For example, if you were to turn left the vehicle would lean to the right, so with the right rear wheel being compressed and the left wheel in droop and geometry being what it is, the rear end would try to steer the vehicle into or out of the corner. The issue is caused when the rear end steers out of the corner causing roll-oversteer. What happens at the controls of the vehicle is once the corner is entered and the vehicle takes its “set” into the corner, the rear end suddenly steers the car further than initially anticipated. Now under normal driving conditions this is at best annoying, but really driving into a corner and having the rear end oversteer can put the car into a spin. In really severe conditions the vehicle would be extremely difficult to drive over 30mph, a small bump in the road would really upset the chassis and almost can’t be controlled. Again the confines of the typical minitruck doesn’t really leave much room for severe oversteer and severe understeer is hard to achieve.
Anti-squat is really not a major concern, except that it should be at least taken into consideration while building a link system that is limited to short bars. Anti-squat also affects roll-steer and vise-versa (roll-center can also affect roll-steer, but isn’t a concern with a properly designed system.) What anti-squat does is fight the affect of weight transfer trying to “squat” the rear end while under acceleration. To create or eliminate anti-squat, you would design the link system to have the instant-center a certain height, related to the center of gravity. A higher instant-center has more anti-squat while a lower instant-center has less. At some point too high of an instant-center will actually lift the rear up as the vehicle accelerates. And too low will push the rear down (though a little tougher to achieve.)
Pinion angle is probably the one thing that most builders are completely aware of, but many are not sure how to set up properly. The pinion angle should be between 1 and 3 degrees pointed down. Most of us have already heard that, but the thing is that the major detail left out is that it should be 1 to 3 degrees pointed down from parallel to the transmission (or the front driveshaft on a 2 piece drive line.) What that means is the pinion could, under certain circumstances, point up. We don’t have near enough space here for me to explain how to design the suspension that you may desire, but give us some time we will get there.
Now that the boring part is over lets get to the subject at hand… Suspension design. I am going to describe the major benefits of each design. (None of this is my opinion (unless noted.) So don’t go and think that I am just bad-mouthing every body else’s ideas.) For a suspension design to be un-drivable, it would have to be really bad. Also if you just can’t quite fit the perfect design into your confines you will have to compromise. That’s part of what makes a good fabricator, the ability to adapt to their limitations. So here we go…
The ladder-bar and 2-link are both very similar. In fact a ladder bar is a type of 2-link, but not all 2-links could be considered ladder-bars. The ladder-bar design is great for high horse power, high traction cars that the owner doesn’t want to spend the hours or days it would take to tune a good 4-link for the track. The first major downfall of the 2-link is that it doesn’t allow much articulation (one wheel up and one wheel down.) The only way that the design can articulate is to flex a little bit of everything. NASCAR uses a 2-link rear suspension that is specially engineered to allow an acceptable amount flex in order to articulate. The second major issue is pinion angle. The 2-link by nature cannot keep the pinion parallel to the transmission so useable travel is limited to the acceptable amount of pinion change. On the other hand the 2-link is fairly easy to tune, to install, and to purchase. Anti-squat is easy to figure because the instant-center is the forward pivot. Roll-center and roll-steer aren’t really a concern because the suspension won’t articulate so on the same coin the need for a swaybar is just not there either. The 2-link will require a panhard bar, track locator or other similar lateral limiter.
The 4-link is separated into (3) major types
- Triangulated 4-link
- Parallel 4-link
- 3-link
Each of these designs have the same advantages and can be oriented as forward, reverse or “2-forward 2-reverse.” Initially I am only going to talk about the forward facing orientation. Once we have described the advantages of those, I will explain the downfall of each of the other orientations. The reason that the 3-link is categorized here is that just about every advantage and disadvantage is shared by all three of these systems. In fact the 3-link and parallel 4-link are identical except the missing link. It is a space saver, period.
The way that a link system of this type is drawn out is 1 dimensionally, from the side. From that view you cannot tell which design is used. The side view is how you would figure instant center, anti-squat, pinion angle and a potion of roll-steer. Because of the infinite possibilities of the 4-link, they are used on just about every straight axle rear suspension in the performance industry (factory or after market.) Good control of the pinion is possible (assuming the designer took it into consideration,) they also have infinite instant center options. As a matter of fact the drag race community has 4-links designs that allow tuning of the instant center separately from one side to the other. Again the confines and the fear of most builders to “step out of the box,” have limited our designs, but the limitations have been on the side of caution. Having an instant center around the front bumper or beyond has very little adverse effects. This how the manufactures set up their link systems.
The separation of each of these designs is from above. From this view you can see how each bar is run. The triangulated 4-link would be the most obvious and is what is most commonly used in the minitruck industry. The triangulated 4-link does not need a panhard bar or any other lateral limiter (the triangulation of the bars does the limiting for us.) This would be a god time to touch on the “wishbone” type 3-link. What this system does is bring the close end of the triangulated into each other, creating the wishbone. It acts exactly like the triangulated 4-link except that the single point of the wishbone is the roll-center. Minitrucks don’t really use this system because of space limitations. Early Cadillacs used this system and had a reputation of breaking the balljoint used at the single point. The overhead view also is another addition to the roll-steer picture. By pointing the bars towards the front or rear of the vehicle can change the roll-steer affect.
The 3-link and parallel 4-link need a lateral limiter of some sort, which would be viewed from the rear (in most cases.) A panhard bar, track-locater (viewed from above,) Watts-link… There are many different ways to limit lateral movement and all have their advantages and disadvantages. But that’s for another day…
Forward, reverse, what’s the difference? A forward facing 4-link transfers energy to the chassis planting the rearend under power, a small amount of anti-dive under braking and can be tuned infinitely for a specific purpose. A reverse 4-link on the other hand should only be used as a compromise. I know that there are a whole bunch of you that have reverse 4-links and think they work great. I’m sure they do. They will drive fine and turn corners and stop the car without too much upset, but again as I’ve stated several times before, “The confines of the minitruck do not leave much room for dangerous designs.” On top of that, I’m sure not many of you have bucket loads of horsepower and if you do it’s not getting to the ground. I’m sure there are more than a few of you that noticed that once you had the reverse 4-link installed it got easier to do a burn out. Another saving grace of the reverse orientation is that roll-steer is almost always roll-understeer making the truck feel stable in corners. Also the pinion angle, when properly designed, is kept well within working limits. The point is, the reverse 4-link works. It holds the truck off of the ground and keeps the rearend under the truck.
The 2-forward 2-reverse works because it does nothing, it doesn’t help, it doesn’t hurt… nothing. The biggest issue with the 2-forward 2-reverse is pinion-angle. It’s a little tough to calculate and doesn’t offer much travel because of it. On an odd note, this system doesn’t move much front to rear, as it runs through its travel.
I have never seen the reverse 4-link or the 2-forward 2-reverse type 4-link used anywhere else except the minitruckin industry. Bob Grant called me the other day and challenged me to figure out how to build a rear suspension that doesn’t move front to back in the wheel-well. I immediately thought “A-arm” then he clarified “straight axle.” I then promptly said that it couldn’t be done. Then he told me his idea, it would work, but if the rearend doesn’t follow a set point in space (instant center) it will not add or subtract anything to the cause of traction.
I hope you were able to get through this and decipher the cryptic writings about the black magic of link-type suspension.
leftcoast66 is offline   Reply With Quote
Old 03-27-2008, 06:45 AM   #31
leftcoast66
And I just am not happy w/ the looks and the way my suspension looks just doing a notch w/ 4 link. So its comin apart to get a backhalf so I don't have the tabs and braces for the 4 link looking like they were added to the suspension. They will look more belonging there. Thankfully i don't have to drive my truck daily so I can be a perfectionist about it all.
Old 03-27-2008, 09:36 PM   #32
collin86
here are a couple pics
my 4 link kit
a few parts a i have been collecting for my 9"
diagnol link
billet yoke
set up kit
4.10 gears
daytona pinion support
40 spline spool
9" housing
Old 03-28-2008, 08:34 PM   #33
collin86
by the way that was a good article leftcoast66
Old 03-29-2008, 12:46 AM   #34
leftcoast66
Glad you liked it. I've still gotta read it thru completely, but skimming it and talking w/ the guy who wrote it, gained a ton of good info.
Old 04-05-2008, 05:17 AM   #35
chevy72blu
chevy72blu's Avatar
Sad to see you abandoned your previous direction, I really wanted to see some pics of it- im debating between a trailing arm setup/parrallel 4 link for my street/strip project.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 04-05-2008, 05:22 AM   #36
collin86
i would do a 4 link. thats just my opinion though, they are hard to beat once you get them adjusted right they are awesome
Old 04-10-2008, 11:48 PM   #37
prostreet1967
prostreet1967's Avatar
i have 170 springs on my truck and its too stiff. i called s&w race cars and they recommend 130-150 for full size pickups. just fyi im no expert though
prostreet1967 is offline   Reply With Quote
Old 04-11-2008, 03:49 AM   #38
collin86
i will keep that in mind i have a buddy with a few different spring rates so im gonna experiment a little
Old 04-16-2008, 06:48 AM   #39
leftcoast66
Hows progress goin? I'm stoked to see the coilovers in the back for something different on a c10.
Old 04-16-2008, 09:30 PM   #40
collin86
progress is coming ok...havent had a lot of time latley though. i will see if i can get some pictures up soon
Old 04-16-2008, 10:12 PM   #41
leftcoast66
Badass, lemme know if u need help w/ any of it.
