04-04-2008, 08:25 PM | #26 |
Re: MPG. I need some more Brains to help me out.
but that fan has enough power to keep my engine cool? Would i have to make a new shroud or just pop the new one in there with no shroud?
JG If you can't find it at the junk yard you don't need it. Last edited by Rooster's82; 04-04-2008 at 08:25 PM. |
04-04-2008, 09:30 PM | #27 |
Arrived on a Pale Horse
http://www.electricfanengineering.com/over-the.htm Has some info you might find useful.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
04-05-2008, 03:23 AM | #28 | |
Parts and more parts
I mounted my fans up close to my radiators, by using aluminum strapping from my local hardware store and the fans stand up to just about anything that I do. The extra room in the engine bay is also a big plus. (the stock fan shroud is tossed). I control them so that only one turns on, unless the temps go high, then the second cycles on to support the first. I have yet to get to the second fan and use it. |
04-05-2008, 04:01 PM | #29 |
Rock and roll.
JG If you can't find it at the junk yard you don't need it. |
04-05-2008, 04:41 PM | #30 |
Phone's ringin Dude.
Here's a link on how to install a late-model jeep fan into your factory shroud. This is for install on a 67-72, but the shroud openings should be similar. The fan itself only runs about $70. In a follow up, one member reported gaining 3mpg with a 250L6! This is defenetly on my to-do list!
http://67-72chevytrucks.com/vboard/s...d.php?t=254617
I pitty the fool with only two headlights!! 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
