#26 |
Re: 1971 3/4 swap to 1/2 ton
Jeez, you still have snow??!!
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
#27 |
83 on Wednesday and snow of Thursday... Colorado weather is nuts
Charles 1971 3/4 ton 454 cu.in. ![]() 4 speed manual 1966 Thunderbird 390 cu.in. Airride Roadster |
#28 |
I went over a bump really fast the other day and now it is the full 5 inch rear drop. I will for sure need to have 20's in the rear and 18's of front to have a little rake.
Charles 1971 3/4 ton 454 cu.in. ![]() 4 speed manual 1966 Thunderbird 390 cu.in. Airride Roadster Last edited by Charlesdur; 05-06-2008 at 12:49 AM. |
#29 |
![]() Join Date: Oct 2006
Performance Online sells drop spindles for 3/4t trucks. One of the board members here did it. Looks AWESOME!
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
#30 |
![]() Join Date: May 2002
You may want to double check all the bolts, just to make sure that they are still tight. the 3.5" original drop may have had something in a bind that the speed bump jarred loose.
Still, looks good.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
#31 |
I may want to do this to my grandpa's truck, subscribed
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
#32 |
Just hang'n around
That is cool. You make it look simple. Mine has the Eaton rear-end. Sure would like a Dana for mine.
Can't wait to see the finish project. What else do you have planned?
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year. |
#33 |
I am waiting for the rear bed metal to replace the rusted out tool box. After a small break with the wife the truck is going the garage and getting torn apart for the new metal. The goal is to have it complete by late July or early August. This will not be a complete frame off, but everthing will come off except the cab to complete the body work. Going all black with all new chrome, real flames on the front, 18 inch rims up front, 20's in the back 3.73 gears in the read end, possibly swap out the tranny and new interior. I look at some of the trucks on here and get blown away with the work and time and want to save that stuff for my son when he is ready to get this truck given to him. I am hoping for some father son bonding like my dad did with me and his 53 5 window.
#34 |
Yeah I freaked out and went back over everything and all is good. I didn't replace the shocks though so I was wondering if that had something to do with it.
#35 |
I will be checking those out now. Thank you for the tip... this forum has been great and has helped out a bunch.
#36 |
I have spent less than $400.00 for the suspension and people are already turning their heads. Grandpa might not get it, but would laugh his arrrssss ![]()
#37 |
It is my dads, but my grandpa bought it new, and i'm gonna try to fix it up
#38 |
I was wondering what it would look like with white walls... so out came the sand paper to scuff it up a round template and some white spray paint. I also didn't like the stance so I cut one coil off of my 2" front drop springs and it lowered it two inches... the problem then was that it was bottoming out the A arm bumper stop "don't know the real name" so I took the angle grinder to it and removed the steel tower and the bumper.. 2 1/2" drop in front and it rides smooth and handles well still.
#39 |
Junior Member
Great looking truck, looks like good progress.
Don't mean to be a little off the thread but my son and I are converting a '67 long steeper 3/4 ton with a 4 speed to a '67 short steeper by using newer running gear and a swb frame. I think I need a cross joint u-joint to go from the 3/4 ton driveshaft to the 1/2 ton yoke on the rear-end. Can any one tell me where I can find one and what to ask for. Thank you. Danny |
#40 |
![]() Join Date: Nov 2007
Charlesdur,
Nice truck ! I like the lowering of that truck, it takes about 2500 pounds in my bed to make the rear that low ! At least I know how to lower my truck. I would keep it 8 lug if I was you. They can carry alot and the Dana 60 is a good axle from what I have been told. I have the same one and it can handle some burnouts ! I like that toolbox in the bed, it is a sweet option.
72 C20 Longbed 05 1500 Z71 |
#41 | |
To answer your question though........NAPA. They should be able to figure this out for you. |
#42 | |
#43 |
Should I relocate the rear shocks? I have it lowered 5 inches in the rear.
#44 |
You shouldn't have to. I actually dropped my the same way you did. I stuck with 8 lug and put street tires on. I took part of the leaf stack out and de-arched the springs. I lowered the who truck for less than 300, and that included shocks. I'm still considering putting drop spindles in the front. I went with 17" rims on all four. Tires I put 255 on the front and 275 60's on the back.
1972 c-20, 350/350, dana 60 w/456 gears(no Posi) |
#45 |
Your truck looks sweet. I have a 72 c20 and possible 1/2 ton rolling chasis for free and have been trying to decide whether to convert over to the 1/2 ton or stay the 3/4 ton. This helps me decide on staying to the 3/4 ton, dana 60 leafs set-up.
![]() ![]() 1972 C20 Custom Deluxe: Rebuilt 402 hopped up a bit, th400 with shift kit, Dana 60(wanna have posi), New solid, no cancer, cab. B & M Starshifter floor shifter. ![]() |
#46 |
Invest in Gold!
![]() Join Date: Sep 2007
Nice truck Charlesdur.
I was gonna do the 3/4 to 1/2 ton conversion, but now I am also thinking about keeping my truck as a 3/4 ton.... TotalChevy1, what kind of wheels are those?
John Gold 1970 Chevy LWB Fleet |
#47 | |
Charles 1971 3/4 ton 454 cu.in. ![]() 4 speed manual 1966 Thunderbird 390 cu.in. Airride Roadster Last edited by Charlesdur; 07-12-2008 at 08:26 PM. |
#48 |
Did you C-Notch the frame on the rear? and did you end up changing out the rearend?
#49 |
I did not C-notch the frame. I did put air shocks in the back since I have such big rear tires. I didn't change out the rear end either, it's a Dana 60. I kept it with an 8 lug set up. I'm from Patterson Ca near Modesto so this truck is unusual out here in Colorado, but since you are from merced I understand you style.
Charles 1971 3/4 ton 454 cu.in. ![]() 4 speed manual 1966 Thunderbird 390 cu.in. Airride Roadster Last edited by Charlesdur; 04-23-2009 at 10:05 AM. |
#50 |
Cool I know where Patterson is!! small world!! what size tires do you have?? I also plan on doing the paint on white walls!!
