Old 11-03-2002, 02:03 AM   #26
neonlarry
neonlarry's Avatar
Where did you get that new bearing?
Try www.iedls.com
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 11-03-2002, 03:58 AM   #27
Va Longhorn
I had a similar promblem years ago on my 72 GMC Sierre Grande. The carrier bearing mount had actually stressed and snap. I paid an Exxon station in the area of my break down a 100 dollar bill to tow it in and weld it for me. 20 miles down the road on the way home , it breaks again above the new weld. After a long agrument with the station, they came and got it and welded it again. I think that one lasted 2 days. Disgusted, I called a buddy of mine that knew these trucks quite well. ( He has a 72 4X4 that he competes in truck pulls with) He brought up a drive shaft out of a 72 chevelle. Worked perfect ! We took out the carrier bearing and never had another promblem with. I pulled a 22 foot camper for two more seasons with before I sold it. Now keep in mind that this was a shortbed, but if you measure center of yoke to center of yoke, a good salvage yard should be able to hook ya up
Va Longhorn is offline   Reply With Quote
Old 11-03-2002, 08:06 PM   #28
useRc10
useRc10's Avatar
how much was that bearing...i want to put one of those aluminum shafts just for the shiney look
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 11-03-2002, 11:37 PM   #29
nroden
nroden's Avatar
I replaced mine a couple of weeks ago when rubber busted all up. It was $32 I think from NAPA. Took away some vibration I didn't even realize I had. Amazing when you replace something the small difference it makes. Not hard to replace. Did U- Joints also... .replaced all but the front one because it was greasable where the others were sealed. so just greased it.
Nick Rodenberg
72 Cheyenne 10 V8 350/TH350
white/ochre/white/ochre, ochre/saddle interior
Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!!
nroden is offline   Reply With Quote
Old 11-03-2002, 11:53 PM   #30
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
For a short bed with a small block in the proper location and a short shaft TH350, a one piece shaft is 4 foot 10 inches.
Old 11-04-2002, 12:20 AM   #31
neonlarry
neonlarry's Avatar
The bearing was about $75. It looks like it should last at least as long as 2 of the other ones though
Old 11-04-2002, 11:47 AM   #32
melloyello
melloyello's Avatar
Neonlarry
was it any harder to install? or did it mount as eazy as a standard carrier bearing? BTW that looks awsome (80ish moment)
67 C/20 camper special 350
melloyello is offline   Reply With Quote
Old 11-04-2002, 01:12 PM   #33
neonlarry
neonlarry's Avatar
I haven't gotten the bearing yet, but it should be just as easy to install as the normal kind. I also have to change the rear springs at the same time, because someone thought that front springs would do just as well on the back too, and I think that is a big part of the problem that makes them keep breaking.
Old 11-04-2002, 01:29 PM   #34
lux hauler
Psycho-billy Member
lux hauler's Avatar
It might be worth the extra money to get the shafts balanced while you have them out.
'72 C-10
350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers.
Support your community, support yourself. Buy local, buy American (or Canadian).
lux hauler is offline   Reply With Quote
Old 11-06-2002, 02:59 AM   #35
neonlarry
neonlarry's Avatar
Well, the new carrier bearing came in the mail today. It looks WAY better than the old one As soon as I can find a set of rear springs (instead of front ones lol) I am going to get it put in, and I will probably post a review of it in the proper place.
One thing I will say, the packing for the bearing was well, interesting. It is a good thing it is so strong I guess. You might want to remember that if you order anything from them.
