04-13-2008, 06:22 AM | #26 | |
Phone's ringin Dude.
Re: Coolest shop couch ever(to me)
I pitty the fool with only two headlights!! 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL Last edited by dieselarmy13; 04-13-2008 at 06:24 AM. |
04-13-2008, 06:24 AM | #27 | |
1986 Chevy 3/4 Ton 4X4 |
04-13-2008, 01:54 PM | #28 |
too far north
No it's over on "the dark side" its the more adult side of the board. They discontinude giving acsess until further notice (whice has been at least as long as i've been on the board) a lot of us can't view it. later, and red, welcome to the board, and cool bench
2008 Chevy Silverado 1500 2008 Jayco Jay Feather 17c (Guest House) 2008 HHR 1974 Yamaha 500 Gas saver Last edited by gdhall_1999; 04-13-2008 at 01:55 PM. |
04-13-2008, 03:47 PM | #29 |
Thanks gdhhall!
04-13-2008, 03:50 PM | #30 |
that is very cool.
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
04-13-2008, 04:31 PM | #31 |
great southern land
thats awsome , and welcome to the board...
rod 86 chevy c10 silverado |
04-13-2008, 04:42 PM | #32 |
Like a Rock!
Red 69- that is so cool!
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! |
04-13-2008, 07:24 PM | #33 |
Yes please tips, tricks, show us how you put it together.....
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
04-13-2008, 08:59 PM | #34 |
Well, here goes. First use a chalkline or straightedge to mark a line about a quarter inch in front of the vertical box braces across the bed. Cut the floor and the underlying braces by any means neccessary. I used a cutoff wheel and a sawzall. After you get through the floor, start cutting the bedside about a quarter inch in front of the vertical bed brace from the inside of the box.
Go across the bedrail, then straight down the bedside all the way to the bottom. Now remove the bulkhead bolts and break the spotwelds. You'll need to trim the top rail of the bulkhead a little bit to fit nicely to the portion of the bed you just cut off. Bolt the bulkhead to the vertical box braces using the bolts you just took out of it. Now here's where I screwed up the first time. I reinforced the back (wallside) of the bulkhead and drilled it on 16" centers to use like 16 or 20 big lag bolts. While this is fine to do, the weight of whatever is on the tailgate pulls on the vertical box braces. The thing to do is use the lag bolts in the bulkhead but ALSO drill a hole near the top of the stake pocket and use a good size lag bolt in each. They will obviously have to go in at an angle, but that's where the weight hangs from. There were no studs behind my box braces so I had to cut drywall and put in blocking. I plan on fixing it when I redo the shop. When it comes to lighting it up, I hid an outlet behind the bumper. For the taillights, I gutted the taillight housings and screwed in one of those 4 bulb Christmas light strings in each one. For my tailgate lights and license plate light, I'm running them off a puck lighting transformer. If you have any more questions, let me know.
04-13-2008, 09:06 PM | #35 |
PROJECT 7DEUCE
Very cool....
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-14-2008, 04:27 AM | #36 |
Tot Roddin'
That is sweet!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
