Old 04-15-2008, 09:17 PM   #26
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Hacked Dash Option's?
Looks like a great plate. Yep, better anti-bling that with some flat black or something.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-16-2008, 12:29 AM   #27
jaros44sr
jaros44sr's Avatar
Originally Posted by vtblazer View Post
Pretty happy with it, might need to trim the tab some but it should work out good.
Going with aluminum rivets or some allen head screws for mounting.
(leaning towards the allen screws currently)
Scuff it up with steel wool, should get rid of glare. You could leave it shiny and signal me back at the campsite SS panhead allens for the bling factor...
Every thing you do comes out looking good, why should this project be any differant! Nice work, must feel good to be playing with your own stuff again
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-16-2008, 12:41 AM   #28
GRIMSS
GRIMSS's Avatar
Looks good. Just neet to knock the shine off.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 04-16-2008, 01:31 AM   #29
vtblazer
vtblazer's Avatar
Did a quickie install for the lights/switches and toggles, patch held in dash with duct tape.
Top toggle is my electric fan, push left and the green LED comes on telling me it's running at low speed...push right and the red one comes on saying it's running on high.
Toggle switch is a On/OFF/On - three position switch.
Interior winch switch is now alot easier to reach than before.
(found out one of my solenoids is bad playing with it today)
Even mounted the factory ACC-OFF-ON-START plate.
vtblazer is offline   Reply With Quote
Old 04-16-2008, 04:23 AM   #30
Big J
Its lookin' like a Blazer!
Big J's Avatar
Nice Job! Some stainless button head allen screws would finish that off nicely.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 04-16-2008, 04:53 AM   #31
Critter
Future TOTM Winner
Critter's Avatar
So, I guess I will ask a dumb question...are you going to put the radio back in it? I like the way it turned out so far!
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 04-16-2008, 12:09 PM   #32
vtblazer
vtblazer's Avatar
My thoughts exactly.
No radio for this ride, it's makes plenty of interesting sounds to listen to.
Old 04-16-2008, 07:12 PM   #33
jaros44sr
jaros44sr's Avatar
How about some nutserts, makes it real easy to drop the panel and track down a short...
I have to put one in my upper windshield post, as the PO thought a slip in sheet metal sert would work....NOT! Luckily the hole is just alittle small and be drilled out to 3/8"
Nice work so far, enjoy seeing your mods. Fitting for a 3X TOTM
SAFETY FIRST
AS usual, off topic
Jim
Old 04-21-2008, 10:01 PM   #34
vtblazer
vtblazer's Avatar
Installed and Working
Finished up the wiring, turns out I was able to shorten a few which for me almost never happens.
Decided to simply use some black self tap screws, always liked the look of em anyway.
I like these mods that are fairly quick, simple and make my life easier.
Old 04-22-2008, 12:02 AM   #35
MNorby
MNorby's Avatar
Re: Installed and Working
Maybe I should have same the ignition switch label thing. I broke mine off with a screwdriver so I could install my panel
MNorby is offline   Reply With Quote
Old 04-22-2008, 12:56 AM   #36
jaros44sr
jaros44sr's Avatar
Nice work as usual, no more ugly hole to look at
SAFETY FIRST
AS usual, off topic
Jim
Old 04-22-2008, 02:02 AM   #37
Big J
Big J's Avatar
Just noticed the rubber liner on the dash pad. Cool!
BAZINGA!
My Build
Old 04-22-2008, 02:37 AM   #38
vtblazer
vtblazer's Avatar
It's the roll bar tubing, the horizontal link between the front hoops.
Dash pad is right behind it, just can't see it.
Old 04-22-2008, 04:29 AM   #39
Big J
Big J's Avatar
Your right... Thats a thought though, I wonder how well it'd hold up... Rubber bed liner on a dash pad.... Hmmm......
BAZINGA!
My Build
Old 04-22-2008, 03:18 PM   #40
RAB38
Looks good VT. Have you thought about maounting some gauges in there as well?, it would look goos with aome autometers in there
72 Blazer CST 383 stroker roller, fuel inj, t350,NP205, D60 front, 14b rear, detroit locker, 38 x15.50 mtz's, welds, cross over steering, custom cage,Line X Spray in liner, House of Colors Tangelo Pearl Orange
RAB38 is offline   Reply With Quote
Old 04-22-2008, 03:30 PM   #41
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Looks really good Kurt!
Maybe you should start producing these for an after market part... Hmmm.
And BTW, Thanks.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 05-16-2008, 01:06 PM   #42
vtblazer
vtblazer's Avatar
Yeah, I agree, looks a little naked right now.
Just having the room to grow into is nice, opens up some gauge options for sure.
Old 05-16-2008, 01:28 PM   #43
jaros44sr
jaros44sr's Avatar
Would be nice to have a trans. temp. gauge. Always wanted one of those...JAT
SAFETY FIRST
AS usual, off topic
Jim
Old 05-16-2008, 01:39 PM   #44
vtblazer
vtblazer's Avatar
Not sure I really wanna know, sometimes ignorance is bliss.
Yeah, the trans gauge would be good to have in reality.
Old 05-16-2008, 01:43 PM   #45
jaros44sr
jaros44sr's Avatar
SAFETY FIRST
AS usual, off topic
Jim
Old 05-16-2008, 11:45 PM   #46
hotrodkev
Noob
When I restored my 69, I had a similar issue but I cut the piece I needed out of a donor truck and welded it in. I just love the original look with the factory style radio too much to have put a piece of aluminum in there. To each his own.
hotrodkev is offline   Reply With Quote
Old 05-17-2008, 10:23 AM   #47
vtblazer
vtblazer's Avatar
...hey hotrod, you have no idea the lengths I've gone to in order to keep an old chevy stock but your new here and you haven't a clue as to what I've done, so welcome to the site either way, enjoy the ride.
Take the time to start up a thread showing your truck, it looks good sitting on the trailer but I didn't see any interior or dash pics in your sale post.
Which leads me to the next question...if you have such a love for these old trucks, why ya sellin' it?
Old 05-17-2008, 03:56 PM   #48
hotrodkev
Noob
I'm tired of sinking money into it. I love the old school trucks but I signed up on this site to sell my truck. Just figured I would give you my .02 on your dash. I have the pics of my interior and dash...which look factory. NOT a huge plate of aluminum, which isn't my style. Once again, to each his own.
Old 05-25-2008, 02:14 AM   #49
vtblazer
vtblazer's Avatar
You still don't get it...
Old 05-25-2008, 04:34 AM   #50
hotrodkev
Noob
Your right....I don't get why in the hell someone would put a piece of aluminum plate to hold 2 toggle switches and a sticker. Just a little welding and paint could have looked so much better....
