Old 04-20-2008, 04:53 PM   #26
EFI70Blazer
Active Member
EFI70Blazer's Avatar
Re: 1970 K5 Bumpers/ Stock or ?
Seen this truck on Ebay with a similar setup as Kurt's.
http://cgi.ebay.com/ebaymotors/Chevr...spagenameZWDVW
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
Old 04-28-2008, 07:13 PM   #27
swyfor5
swyfor5's Avatar
I really like the look of that kmt bumper on that white k5. My concern is can I mount the right winch on it, without moving the bumper forward, like Burt's? Could use some feedback, and or pic's of this type of setup. Thank's.
swyfor5 is offline   Reply With Quote
Old 05-01-2008, 03:12 AM   #28
swyfor5
swyfor5's Avatar
I really like the looks of that kmta wincher on that white 1st. gen. My main concern is that I don't want to modify my brand new grille setup to fit up the winch. Could move it forward like Burt4x4's, but would take away from the tucked in look. Guess I'll try my luck getting a hold of kmta and see what they can do for me. Sure no one has any pic's or etc., of this on a first gen?
Old 05-01-2008, 04:53 PM   #29
Burt4x4
Burt4x4's Avatar
I mounted mine high & tight(without cutting the egg crate part of the grill)
I did need to cut the bottom of my grill, the chrome part that is normally tucked behind the stock bumper. The is a ^ groove on the bottom of the crome suround:
can't find a good pic of the cut I made
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 05-01-2008, 04:55 PM   #30
Burt4x4
Burt4x4's Avatar
This one they put below that lip I cut off....
See how mine is closer to the headlights.
I wanted mine high for approch angle, I use the two vertical brackets under my bumper as rock sliders hahahaa
Old 05-03-2008, 04:11 AM   #31
swyfor5
swyfor5's Avatar
Thank's Burt. I like your bumper setup. I am now rethinking my plans. I like the way that wincher looks tucked back in under those cut fenders, but I don't want to modify my outer or inner grille assy. I also was wondering if I went with the bumper tucked under like that if I might be very limited to what winch might fit there. Thinking it might be better to go with a setup like your's, and get the best of both worlds?
Old 05-03-2008, 05:38 PM   #32
Burt4x4
Burt4x4's Avatar
With a setup like the white one you would need to run a winch and has no silly packs mounted to it, see how my winch has the top piece mounted to it poking out above the bumper...A Ramsey or even a Warn with a remote silly pack would be needed to keep the winch below the top of the bumper...untimitlay it comes down to are you doing it for looks or function? If your gonna wheel alot and plan on actually using the winch lean towards function vs. beauty
Old 05-04-2008, 02:53 AM   #33
swyfor5
swyfor5's Avatar
Thank's, Burt4x4. I knew this would be a problem area. Any ideas of what winch would be a good fit for that bumper and still be good for "function"? Really would like to hide the winch as much as possible, but don't want to give away usefulness just to look pretty! Thank's for all your help, Bryan.
Old 05-11-2008, 01:34 AM   #34
swyfor5
swyfor5's Avatar
Anybody else dealt with Kennesaw mt.? I don't have a problem waiting for a custom ordered one, but I do want to get what I order. I am concerned that with the bumper mounted back that far, the winch install may be a problem. Any other venders out there you guy's have dealt with in this area?
Old 05-11-2008, 03:51 AM   #35
Burt4x4
Burt4x4's Avatar
I would look local to were you are for a welder/fabracator type shop. With the truck present could come up with a sweet solution..
Warn or Ramsey are my choices at least 9500.
Old 05-12-2008, 05:56 PM   #36
swyfor5
swyfor5's Avatar
Thank's, Burt 4x4. I think I know what I want now. Just need the funds to follow thru with my plans! Anybody else got ideas?
