Old 04-17-2008, 02:57 AM   #26
redhead69
fugedaboutit
redhead69's Avatar
Re: valve adjustment confusion
Man now Im worried!! lol, hey if this motor goes its only getting a bigger one!!
Currently truckless
redhead69 is offline   Reply With Quote
Old 04-17-2008, 04:35 AM   #27
crm318
Alright Alright Alright
crm318's Avatar
well. i thought i would take the most fundamental approach. i got it to TDC and i just adjusted the valves according to the firing order. it bumped right of and seems to run great. thanks so much for all the replies. yall have no idea how much i have learned on this website.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 04-17-2008, 05:42 AM   #28
Billla
Billla's Avatar
Can you explain more of what you did - I'm not sure I understand...
Billla is offline   Reply With Quote
Old 04-17-2008, 06:29 AM   #29
67_C-30
I have a radical idea!
67_C-30's Avatar
Originally Posted by Billla View Post
There's no reason to adjust the valves with the engine running IMHO.
I agree 1000% when talking about a new or rebuilt engine (meaning at least new cam and lifters).
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 04-17-2008, 07:15 AM   #30
1tigers
The valves should be adjusted warm just because the clearances change, but there is no "pump up" of the lifters. If you take a hydraulic lifter apart you'll see how that just isn't possible. With a spring pushing the cup up to the limit of it's travel, what exactly is going to "pump up"?
Look at what the race shops do - how many of those do you see adjusted running? Zero.
It's always a charged discussion
race engines use solid lifters not hydraulic
1tigers is offline   Reply With Quote
Old 04-17-2008, 10:15 PM   #31
Steelawork'n
Just hang'n around
Steelawork'n's Avatar
No charge here, just an open discussion. Some engines come assemble with the valves so tight the engine won't even run so adjusting them before start up is a good idea. I wish I had a set-up that allowed for me to tune the engine before installation, but my garage is too small for something fancy like that.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year.
Steelawork'n is offline   Reply With Quote
Old 04-18-2008, 05:33 AM   #32
crm318
crm318's Avatar
i meant that i had a buddy crank the motor over with a breaker bar while i put my finger over the spark plug hole to feel for each cylinders compression stroke. i went from each cylinder according to the firing order so i know that the valves were seated. it bumped of perfectly.
1972 Cheyenne
Old 04-18-2008, 06:51 AM   #33
Billla
Billla's Avatar
Hmmm...that's a new one on me, but it works!
Old 04-19-2008, 09:35 PM   #34
Steelawork'n
Just hang'n around
Red brings up another important item. If you are replacing the cam and lifters the lifters will need to be pumped up to get your proper valve adjustment. Running engine pumps them up. With the running adjusting method you near bouts can't get it wrong. Zero the lash and turn slowly up to one turn more. That's it, it's done, put the valve covers on it and wipe it down cause it's ready to roll out the door!
Actually, a good way to get it "pumped up" is to take an old distributor chaft, insert it and secure it down as if it were a functioning unit, then attach a cordless drill and spin it until your oil pressure reaches the proper level for your new engine. Then, start it up and adjust the valves.
This method is safely prelubes the engine w/o the need to fire it up. This method can be done with the engine in the truck or on the stand, you pick.
Old 09-06-2008, 01:41 PM   #35
spoon
Registered Penetrator
spoon's Avatar
Topic revival.
I adjusted my valves in my new motor while it was on the stand, "dry adjust", per the shop manual. The engine is now installed and running, but my valvetrain is noisy. This is the first time I've ever adjusted valves "by feel" and then "1/2 to 1 turn" down. It's hard to believe there's absolutely no tool/instrument out there that will assure a positively accurate valve adjustment on these engines, which frustrates me.
It is what it is though, and it's quite possible that I do not have the "touch" or the "feel" required to adjust valves in a SBC. Any tips?
"Some people wear Superman pajamas. Superman wears Chuck Norris pajamas."
"Chuck Norris is the only person on the planet that can kick you in the back of the face."
"Chuck Norris doesn't 'tea-bag'... he 'potato-sacks.'"
spoon is offline   Reply With Quote
Old 09-07-2008, 02:10 AM   #36
redhead69
fugedaboutit
redhead69's Avatar
I just installed some new lifters, pushrods, and rocker arms and followed these instructions
http://www.compcams.com/Technical/In.../COMP4-116.pdf
I previously used the method where you adjust half the valves on the 1 and the other half on the 6 position, as well as the running method. I always had clatter on the top end and just assumed it "is what it is". I am VERY pleased with the way the motor sounds now.. much quieter.
Currently truckless
Old 09-07-2008, 08:47 AM   #37
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
That's the way I did mine, but the directions were on the scorpion roller rocker site.
That makes the most sense to me and eliminates any valve overlap due to cam grinds.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 09-13-2008, 10:40 AM   #38
spoon
spoon's Avatar
Let me ask you fellas this then. With the motor running for about ten minutes, there are two or three pushrods that have yet to spit out oil. If I have a valve that's not oiling, could this be causing some valvetrain "ticking"?
Old 09-13-2008, 01:40 PM   #39
WIDESIDE72
WIDESIDE72's Avatar
I have an all steel street legal 79 Malibu with a 383, balanced, forged Eagle crank, Keith Black forged pistons, Brodix aluminum heads that has run 12.80 in the 1/4 mile. I bracket race with it and have defeated quite a few cars that were faster due to my consistency at the line. It has a hydraulic flat tappet cam (soon to be solid roller), but since it has hydraulic lifters, does that mean that it is not a "race engine" ?
WIDESIDE72 is offline   Reply With Quote
Old 09-13-2008, 03:35 PM   #40
spoon
spoon's Avatar
Originally Posted by WIDESIDE72 View Post
blah blah blah
Hmm, I give your hijack attempt a 6.5. Okay, a 7 since you added all the smileys!
Old 09-13-2008, 11:36 PM   #41
old Chevy guy
old Chevy guy's Avatar
I never had any race engines but I had more than a few fast cars with sbc moters and we always adjusted the valves running ,by ear as was learned from old school teachers and never had a problem or a cam failure or anything else. BUT my opinion is do what works best for you and what your comfy with no matter what anybody else thinks. Oh and I think the headers over heating is a timing issue too.
old Chevy guy is offline   Reply With Quote
Old 09-13-2008, 11:47 PM   #42
Jtrux
I'm a poor spectator
Jtrux's Avatar
Headers over heating IS a timing issue, it's too far retarded, advance it and the glowing red headers go away.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 09-14-2008, 12:55 AM   #43
bob1967
bob1967's Avatar
Originally Posted by Steelawork'n View Post
It's really not that hard. I did mine while it was idling. First you need to get some spray deflectors from NAPA to control oil spray from your lifters. Next, you loosen them carefully until they begin to rattle. Then, you tighten them slowly intil they stop being noisy. Then tighten them no more than one full turn. I do one side and put the valve cover on and then do the other side. There is no order, just one by one. Sometimes when you get a new engine, the first start is with the valves loose.
You more experienced guys might have special tools for this, but I've always done it and seen it done with the engine running. I have over 200k on my engine with no problems.
My friends dad tought me this one on my camaro, except we cut the top of valve covers out. Works great, he has been doing it this way for years. It's alot faster and works good.
bob1967 is offline   Reply With Quote
