Old 04-21-2008, 04:10 PM   #26
Rokcrln
Rokcrln's Avatar
Re: Hey guys I need some help!
Originally Posted by corn View Post
Ah shoot, I thought you didnt have room for an adaptor...
It's not in yet but I have not seen one this short being sold anywere. If you know of one let me know because my sender bottoms out in this one just before being tight. So I tried to champher the end of the sender to allow it to tighten up only to find out their is a spring in the end of the sending unit
Back to the drawing board. Still waiting for the PM< to be returned from the guy who used to turn these down!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 04-21-2008, 04:23 PM   #27
jorgensensc
jorgensensc's Avatar
Can I make an off the wall suggestion. Why not get a T-stat housing that has the integrated spot for the temp switch. I know it's not quite as accurate as the head temp, but it is pretty close. Just an idea (I'm trying for a set of those plans!)
Would that work for you?
SHawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 04-21-2008, 05:34 PM   #28
Rokcrln
Rokcrln's Avatar
SHawn
If I did not have an LT1 than yes it would work but on the LT's the housing is under the front of the throutle body and no room for a sending unit. I have also looked into the kits that put the sender in the rad hose but they are also only for 3/8" not the 1/2" that I need.
Kevin
LFD Inc.
Old 04-22-2008, 12:27 AM   #29
Green Machine
Green Machine's Avatar
Could PM EROC and see if he would make up a few more, they are pretty handy if you don't have hole for the large thread. Worked good for me. Thanks again to EROC for his ingenuity.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
