Old 04-21-2008, 07:25 PM   #26
Lane
Re: Finally made a little progress - pics
I can confirm that the e-brake set-up for a 1966 will work with 1971-1972 e-brake cables as I have installed a rear axle out of a 71 into my 66. Have you tried removing the e-brake cables from the old rear and installing them on the newer axle?
I don't have the old rear, but I have thought about that. Wonder if the older, longer cable would work on the newer rear/brakes?
Lane is offline   Reply With Quote
Old 04-21-2008, 07:41 PM   #27
Lane
So a dual master like this - '69-'71:
could work with a prop valve like this - for an '85 truck?
Man, this threads branched off.. lol
Old 04-21-2008, 08:18 PM   #28
joe231
joe231's Avatar
here is a pic of what i used, I will have to look it up to get the exact year if you need me to. mine has power brakes, not sure about the non power brake rod. I assume it will work also...................................
and nevermind the hideous brake lines, haven't replaced them yet
i can get more pics if you need
Name:  power brakes 2.JPG
CHEVY ONLY
Old 04-21-2008, 08:31 PM   #29
joe231
joe231's Avatar
appears to fit all '67-'72 1/2 ton trucks master cylinder link
haven't been able to find my pro valve on the parts store web pages.
CHEVY ONLY
Old 04-22-2008, 01:00 AM   #30
wild one
Registered.........
wild one's Avatar
The master cylinder that I used was for a 1971-1972 C10, and the proportioning valve came off of a 1977 1/2 ton blazer. You can use the C10 master (looks just like joe231's) I purchased it new at my local parts store for less that $40.00 and a prop valve off of any 1/2 ton chevy truck from 1971-1987.
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 04-22-2008, 06:43 AM   #31
ElkyRacer
Looking good Lane! Im almost to the same point of stripping the frame down myself. I dont look forward to it, but in a way I do!
ElkyRacer is offline   Reply With Quote
