Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 02-20-2016, 11:07 AM   #26
vin63
It's Better With Nitro
vin63's Avatar
Re: '60-'66: Do You Need an 0-90 ohm Sending Unit with Stock Gas Tank?
Saturday bump for the one sending unit left and feedback about making float arm stop adjustments for calibration since calibration between different gauges and brands vary slightly. I bench test each sending unit to an Autometer Ultra-Lite fuel level gauge:
Originally Posted by 64chevmn
I installed the fuel gauge over the past weekend. Prior to installing it, like your instructions mentioned the fuel gauge would not read full with the float all the way up against the stop. I trimmed the stop a bit until the fuel gauge reads FULL with the float against the stop. Thanks again for the help..
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-21-2016, 08:36 PM   #27
wizard3354
I'll take one sending unit if you still have it.
wizard3354 is offline   Reply With Quote
Old 03-18-2016, 05:11 PM   #28
gfogg
Vincent Mayeda (vin63) is a stand up guy. I ordered one of his sending unita. I don't use PayPal because they messed me up one time so I paid him by check. He didn't wait for the check to clear before he shipped the sender and he didn't even charge ,e for shipping, Way to go Vincent Thanks
gfogg is offline   Reply With Quote
Old 03-18-2016, 07:37 PM   #29
vin63
vin63's Avatar
You're very welcome! Let me know how it works with your fuel level gauge.
Old 02-13-2017, 10:26 PM   #30
1963Chevy!
I wanna buy one of these fuel sending units for my 1963 c10, you got any left??????? I emailed you....Need one asap!!! Thanks a lot!....I need the OEM style sending unit,that fits tank behind the seat.....
1963Chevy! is offline   Reply With Quote
Old 06-28-2017, 04:08 PM   #31
vin63
vin63's Avatar
Update: In the last two months, I've encountered the first issues in 20+ years with the sending units I build and a fuel level gauge interface. The most recent issue involved Stewart Warner gauges and a calibration variation. In each case that has been brought to my attention the last few weeks, the Stewart Warner gauge reads full at around the half-way or two-third before the float arm reaches the full position. Due to this significant calibration variation, I do not recommend using my sending unit in conjunction with Stewart Warner fuel level gauges.
* Note: the first case that was brought to my attention was a sending unit I built more than 7 years ago that was purchased second hand and showed some damage/modification.
