Old 04-24-2008, 04:27 AM   #26
1956cameo
1956cameo's Avatar
Re: Duct Tape
As long as the rest of the cab is fairly decent just patch it. As long as its done properly it will be good to go indefinately. Doesnt look like it needs a whole roof. I have patched a couple of cabs with rust in small areas above the gutter, and no one can tell anything was ever replaced. Just get all the rust and weld in new metal. P.S. Yesterday I was replacing the hat channel of a 70 chevy truck and found about half of a sunday edition newspaper rolled up inside with bondo on the outer covering. I did the lazy thing and got rid of the bondo'd up newspaper and replaced it with a new metal hatchanel in about 30 minutes time.
1956cameo is offline   Reply With Quote
Old 04-24-2008, 07:12 PM   #27
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Duct Tape
Originally Posted by Richard H. View Post
I just saw this thread and if you want I will post up some pics for you. You will need to get a new header panel to do it right . Bad67-72 has been watchin my progress and will tell you it is very doable.
Yes please post the pictures. It will be interesting to see how its done.
VDOG is offline   Reply With Quote
Old 04-24-2008, 08:15 PM   #28
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
Re: Duct Tape
Originally Posted by chevguy7 View Post
Why not just do a convertable or sunroof?
haha, my cab became apparently useless after I sandblasted it. I have since decided to so what you suggested and make it a topless truck. It's killing me to not be able to use it to work when I need to. So I think I'm gonna just scab the floor and cut the top off until I can find another cab.
Vdog- have you looked in all the corners of your cab? the rear cab corners, rockers, cab supports and kickpanel?
I'd decide if it's worth patching or not depending on how much more work it needs, and might be worth finding a better cab if there's alot more rust..
Chances are you'd open that corner of the roof to patch it, only to find the whole inner roof needs some care.
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Mordachai is offline   Reply With Quote
Old 04-24-2008, 08:20 PM   #29
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Duct Tape
What makes me want to patch the cab is the prices I find for cabs. One guy wanted $700 just for the cab and when I saw the pictures it look as bad as mine. I did find a whole truck not running, for $300.00 but it was sold two days before I called. The point is, how long do I look for a cab or do I just start working on mine.
Old 04-25-2008, 12:54 AM   #30
B52fizzle
B52fizzle's Avatar
Re: Duct Tape
what was the date?
B52fizzle is offline   Reply With Quote
