#26 |
Re: Off Frame?
FYI,
I know my cab is front heavy, the firewall shifts the CG a little forward.... Be sure to do a proper weight & balance Lee...Don't want a dynamic rollover do we? haha
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 04-28-2008 at 04:10 PM. |
#27 |
polishing a turd
Re: Off Frame?
yeah, i put the lift toward the front of the door opening
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
#28 |
polishing a turd
Re: Off Frame?
here's a quick how to:
-remove brake and clutch pedals by unbolting them from the linkage. -disconnect throttle linkage. -disconnect parking brake linkage rod. -remove starter pedal -remove steering column/box. unhook (or cut) any wires and the speedo cable. -unbolt the cab from the frame - it is four bolts. the rear unbolt from the bottom, the front you have to hold the nut on the bottom with a wrench while you remove the bolt from the top -remove the doors by unbolting them from the hinges (2 bolts per hinge) -slide in you lifting contraption and lift the cab off here's my lifting contraption: ![]() sliding it in: ![]() lifting (i should have centered it better so it would sit more level): ![]() ![]() ![]() set it down on a dolly to roll it round on: ![]() put it in the shop: ![]()
#29 |
![]() Join Date: Mar 2008
Re: Off Frame?
That looks like it works pretty slick.
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
#30 |
polishing a turd
Re: Off Frame?
it does. i did all that by myself! now if the cab was painted, i would consider having some helpers to guide it into place.
#31 |
Re: Off Frame?
Wow that's quite the lift setup there, and it seemed to balance out well, thanks for the pics and the run down. Nice cart too, I was considering building something for mine as well, but I'll probably set it on the trailer with the bed while I get the frame and drivetrain done. I may have to get some measurements from you 1-ton of fun on that cart, great idea.
Is the a 71 or 72 El Camino I see sitting in the driveway? Nice looking SS! Well, I just looked at your signature and it seems to be a Chevelle, nice. I'm looking for a 66 or 67 SS 138# Chevelle, they're getting way too expensive anymore. Hey Mike, I'll try to keep it in CG limits ![]() Last edited by Caveman49; 04-29-2008 at 01:32 AM. |
#32 |
polishing a turd
Re: Off Frame?
yeah, it is 71 chevelle ss 454. i am buying it from a buddy of mine for a very good price. the title just came in, so we should be able to finish the deal this week. it just needs some minor body work, new paint, and new front seats, but it does run. i have taken it for a couple short cruises, but the registration and inspection are expired by like 6 years, so i'm not driving it until i get the stickers. i am pretty excited about it, i posted some pics in another thread titled "the latest distraction from my truck" or something like that.
#33 |
Re: Off Frame?
Man wouldn't you know one body bolt just didn't want to cooperate, but the ole hammer and chissel did the trick. Anyway, I haven't lifted the body yet, but plan on using a 2X10X6, should do the trick, we'll see shortly.
Here's a pic of the wood with Eye-bolts! Will be using a cable to hook the two, lifting with JD, should be interesting..... ![]() pup is learning the ropes too. |
#34 |
Re: Off Frame?
nice shepherd... pure bred?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#35 |
Re: Off Frame?
Yes, we just sent in his AKC paperwork yesterday. We plan on getting a female shephard as well, would like to have some pups to tear up things....
He watches everything I do in the shop, gotta love that. He's also learning from our 13 yr old shephard as well, and hopefully will carry his spirit on... ![]() |
#36 | |
Re: Off Frame?
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
#37 |
Certified Car Nut
Re: Off Frame?
Did someone say Shepherd? Other than building cars dogs are my other passion.
These are my two boys, fully trained the dark one is a Dutch shepherd. They are very sweet dogs unless they are working. ![]() Protection dogs should be nice and sweet but when working you should get this. These are some pics of me decoying at a protection dog trial in Las Vegas. ![]() ![]() ![]() ![]() Last edited by Kabwe; 05-06-2008 at 07:03 PM. |
#38 |
Re: Off Frame?
Great looking Shepherds Kabwe! The only area my dogs work is in the yard, I've several acres fenced, they get plenty of exercise chasing whatever varment straggle in......it ain't healthy for people to come in if they're not invited, I can't guarantee their safety.
#39 |
Re: Off Frame?
Well I finally got a break and lifted the cab off, JD made it easy....
![]() ![]() Couldn't get it on the trailer at this time, so I set it on some jackstands and 2X6s, now I can get to the frame and drivetrain. ![]() |
