Old 01-24-2009, 12:29 PM   #26
VA72C10
VA72C10
VA72C10's Avatar
Re: 1970 VA Longbed Project
Originally Posted by 67_C-30 View Post
You could take pics of those super-cool billet knobs! Cool project!
Thanks! I will definitely have to take some pictures when I get my camera back....lent it to my sister in law.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-24-2009, 12:37 PM   #27
VA72C10
VA72C10
VA72C10's Avatar
I will be using Early Classic's Super trac bar kit. Recommended for any drop over 5" in the rear to help keep the rear end stable. http://www.earlyclassic.com/catalog.aspx
Old 01-24-2009, 12:45 PM   #28
VA72C10
VA72C10
VA72C10's Avatar
Found a front end kit that included 2 1/2" drop spindles, cross drilled rotors, calipers, stainless brake lines, brake pads, and all other needed parts for converting to disc brakes in the front. Still will need the newer style ball joints for this to work. Mine was a craigslist find that the guy hadn't used and isn't available any more. But Several vendors make them including ECE, CPP, and GMCpauls http://www.gmcpauls.com/67-72_d&s.htm GMCpauls seems to have the best deal...the picture is from ECE.
Old 01-24-2009, 12:57 PM   #29
VA72C10
VA72C10
VA72C10's Avatar
I am going to use the John Fabris Stake pocket gas fill mod. I was going to do the sidemarker light mod, but was worried as the nozzles have larger and larger rubber vapor catchers around them that eventually I'd have to fill up w/ a 5 gallon gas can Put pictures of the four main types of fills for others information...and I considered each of these at some point.
Stake Pocket http://67-72chevytrucks.com/vboard/s...t=stake+pocket
Taillight fill http://67-72chevytrucks.com/vboard/s...ht=tail+filler
Sidemarker Fill http://67-72chevytrucks.com/vboard/s...ad.php?t=77104
Bed Fill http://67-72chevytrucks.com/vboard/s...d.php?t=224662
Old 01-24-2009, 01:35 PM   #30
VA72C10
VA72C10
VA72C10's Avatar
I got Roddoors panels from Gcburdic and the 2001 chevy truck seats from Ebay. Here's a couple of pics of both installed for an idea of what it will look like. Also the red speaker box is inspiration to what I want to do in mine. Stole the black and blue rod doors pic from Danny Ewing's awesome truck I'm pulling a ton of inspiration from...http://67-72chevytrucks.com/vboard/s...d.php?t=197866
And a link to the rod doors site
http://www.roddoors.com/pages/chevtrk-6787.html
Old 01-24-2009, 01:44 PM   #31
VA72C10
VA72C10
VA72C10's Avatar
Also going to do the tailgate handle relocator mod. I purchased mine from Mark-K as they're a board vendor and I've read their kit is a little better than some others on the market. Here is LFD's post on that and a picture of a completed one http://67-72chevytrucks.com/vboard/s...t=tools+welded
Old 01-24-2009, 02:07 PM   #32
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looking good so far. Keep it up.
--Josh
Old 01-24-2009, 03:11 PM   #33
VA72C10
VA72C10
VA72C10's Avatar
Thanks for the encouragement....It will be a slow build, but will be worth it in the end. If I had moved faster on this, I wouldn't have gotten all the deals I have. If I had to buy everything at once, I would have had to pay retail. This way, I have run accross deals for the parts I know I want and bought them only on sale or used.
Old 02-12-2009, 02:11 AM   #34
VA72C10
VA72C10
VA72C10's Avatar
Quick update...old bed is off and sold...to a member...Porterhausen (Ben) Getting old brackets ground off and the frame cleaned up to paint. Mocked up the poly blazer tank, took some measurements for the speaker box behind the seats, got the supplies for the stake pocket bed fill, and planned out locations for air tank, compressors, air valves, & battery.
I love working on it and it kills me that it gets dark so soon and I am always on the road during the week and busy with family and church on the weekends....but I see some more opportunities upcoming to work on the truck a little more.
Hopefully will get some pictures next week when I get my camera back or I'm gonna have to buy another cheap digital.
Old 02-13-2009, 10:36 AM   #35
70k52wd
Blaze-Air
70k52wd's Avatar
The trucks you have picked for inspiration are spectacular. I like where you are going with your build. I love the leather seats, they look sooo comfy. Keep up the good work.
70k52wd is offline   Reply With Quote
Old 02-16-2009, 12:52 PM   #36
VA72C10
VA72C10
VA72C10's Avatar
Thanks, hopefully sometime by the end of the summer we'll be cruising with a bagged blazer and longbed
Haven't even seen the truck since my last post ...still buying up parts though ....waiting for taxes and will FINALLY be pulling the trigger on airbags and a air ride controller setup.
I did start organizing my garage and going through some parts to sell and found a few things I forgot I had already. Working really hard on getting some time in the next couple of months where I can work on this consistently.
Old 02-16-2009, 06:54 PM   #37
nuke1
nuke1's Avatar
you sure have to love how this site helps a person with inspiration, you have great idea on what you want. cannot wait to start seeing pictures.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-17-2009, 11:28 PM   #38
70k52wd
Blaze-Air
70k52wd's Avatar
Originally Posted by nuke1 View Post
you sure have to love how this site helps a person with inspiration.
Inspiration, Boy I'll agree with that...Maybe a little overly inspired in my case....But loving it.
Old 02-17-2009, 11:59 PM   #39
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
glad to see you're getting back to this project. Even if it is just doing some shopping for now, having those new parts in the garage is always a good motivator.
and yeah, this site does wonders for inspiration... without this site, I would have probably just cut the coils on my truck and drive it like that. There is so much to learn here it's ridiculous. Some very skilled people hang out here.
IvelDesigns is offline   Reply With Quote
Old 03-29-2009, 05:59 PM   #40
VA72C10
VA72C10
VA72C10's Avatar
I should get some time near the end of this week to work on it and I will be getting some help with parts of this to get moving on my project...finally. Mainly bumping this up to motivate me to get moving on it
Old 06-21-2009, 12:11 AM   #41
VA72C10
VA72C10
VA72C10's Avatar
Thumbs up Re: 1970 VA Longbed Project
FINALLY progress
Plans have changed on the truck and now it will be more of a Rat Rod/Shop truck with a little bling
I'm going to have it painted a satin black and it will have chrome 20's, a 5/7 drop, and all new exterior chrome.
Plans changed again... ......full on show truck. Airbags,shaved almost everything, custom leather interior, 5 lug, 4 wheel cross drilled discs, smooth firewall, A/C etc....
I have given up on the idea of me doing all the work and have taken it to a local guy who I found on Craigslist. He works on projects and bikes on the side and does good work from what I've seen so far. Truck has been over at his house for just a few days and it's looking better already.
I've also been over working on taking off parts and getting things ready for body work/paint.
Here are a few pictures
When I brought her over
Door inside corner needing work
Door inside corner being worked on. Watched him make a template, cut it, bend it on the english wheel and weld it in. Cool process and good education for my next build. I will try to tackle more if time permits. Will take finished pictures the next time over.
Front side of door he already patched. Looked in the door and there is no other rust so that's a good thing.
Welded up holes for last mirrors
Welded up holes for original mirrors...thought PO had done that..but he'd put caulk in the hole then bondo'd over it
Old 06-21-2009, 12:15 AM   #42
VA72C10
VA72C10
VA72C10's Avatar
Work on the bed
Fender with emblem holes welded/sanded for paint
Door all welded and sanded
Bedside welded up old trim holes and old top rail holes. He sanded this down and it's like glass.
Old 06-21-2009, 12:18 AM   #43
VA72C10
VA72C10
VA72C10's Avatar
There's gonna be a lot of work to the rockers to get them to fit better (Fix the PO's work) and some floor patching in the cab, but honestly the truck is looking pretty darn good and will be rust free soon!!!
Old 06-21-2009, 11:05 AM   #44
bigguy69
dazed and confused
bigguy69's Avatar
looks to be in good hands.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 06-22-2009, 09:10 AM   #45
lks dcvn
lks dcvn's Avatar
Looks like you have made some nice progress - hopefully the CL connection will be educational as well so you can learn on this one and use it for your future projects...
My neighbor is teaching me body work - very time intensive to make it look perfect.
lks dcvn is offline   Reply With Quote
Old 06-22-2009, 09:30 AM   #46
VA72C10
VA72C10
VA72C10's Avatar
Definitely....he's a great guy and more than willing to share what he's doing and how he's doing it. Plus, he's the first to admit he's always learning so he has no problem answering my stupid questions
Between what I have learned on here and what I learned when I worked on a friend's 49 GMC and an 80Z28 I had, I know enough to be dangerous... But I'm continuing to learn
If I had more time I would tackle some of the work I'm having him do, but in honesty, I realized it's better for me and my family to have him do the work and let me take care of my family, work, and home. He's MUCH faster than me on a lot of this anyways so that helps as well...
Old 06-27-2009, 08:00 PM   #47
VA72C10
VA72C10
VA72C10's Avatar
Well, finally got over there again today to work on it myself...he's been finishing up some other projects to make room for the bed/hood/fenders/doors to be separated from the body so no work from him other than finishing up that one door patch.
I, however, got alot done today. Took off the cowl and cleaned the insides up and was SHOCKED to find NO RUST!!! I fully expected it since it was full of leaves. Then, pulled out the rear window, NO RUST, then, pulled the windshield....you guessed it.....NO RUST
I AM HAPPY
Old 06-27-2009, 08:02 PM   #48
VA72C10
VA72C10
VA72C10's Avatar
Got both doors completely stripped down (handles, locks, vent window, door glass, and window regulators (I'm replacing both)
I also have decided to go back to my original plan and finish it the way I want it.
So,......Air ride, 20's, relocated tank, and a bunch of custom ideas...some from here, some my own...
Old 06-27-2009, 08:03 PM   #49
VA72C10
VA72C10
VA72C10's Avatar
Also got a bunch of stuff off the engine to begin prepping that for paint. And undid the underhood wiring and finished stripping out the cab and cleaned it out.
Old 07-19-2009, 12:49 AM   #50
VA72C10
VA72C10
VA72C10's Avatar
Been buying more parts. Have 4 Slam RE-7 bags, chrome 5-gallon tank, 2" blocks with longer U-joints, rear shock relocators, one window regulator, chrome tilt column, chrome rear sport bumper, cab supports, the panels to shave the door handles, stake pockets, and gas cap.
Gas cap has been shaved already. The patch by infanti designs fits perfect with no work required..just tack it in, weld it up, and sand it smooth....
The guy helping me, Jason, is finishing up expanding his garage. As soon as it's done and the floor is epoxy'd, I will be going over to pull off the doors, hood, bed, and front clip. I'll be painting the frame, doing the cab supports, and getting it all prepped for paint. While the bed and front clip are off I'm going to install the airbags, drop spindles, etc. The engine/tranny will be pulled to get cleaned up and painted and then they'll be dressed up before being re-installed.
