Old 05-07-2008, 01:48 AM   #26
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Re: Project... Tinker !!!
What's the groove leading out of the combustion chamber for?
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 05-07-2008, 02:22 AM   #27
BurnoutNova
BurnoutNova's Avatar
i assume to lower the compression a little, but ive never seen that before?
BurnoutNova is offline   Reply With Quote
Old 05-07-2008, 05:35 AM   #28
67_C-30
I have a radical idea!
67_C-30's Avatar
Yeah, do tell on the slot.
I don't understand the thinking because any sharp edges in the combustion chamber or quench area causes detonation. Those are #624 76cc smog heads, so lowering the compression shouldn't be the issue either?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 05-07-2008, 05:45 AM   #29
lukecp
Formerly yellow72custom
lukecp's Avatar
I was also wondering on the slots. I had a pair of those 624 heads on my truck with whopping 1.72/1.50 valves...it actually ran OK but when I put a pair of closed-chamber 2.02 heads on it it gave it a LOT more power. I don't think I'd run a pair on a 283 though because it would have really low compression.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 05-07-2008, 07:22 AM   #30
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
The heads were 58cc combustion chamber & they have 184 intake / 150 exhaust valves
After the mods I did to them they are now 60cc which is what the heads on my 283 were & they had 172 intake / 150 exhaust
What I did was, curve the casting so that it wasnt sharp ( as one of yall said, sharp edges make hot spots) it also makes less turbulence for the flame travel
The groove also aids in flame travel & I rounded it too, so its not a hot spot either
From what I have read, by doing the mods I did it should help me be able to run more compression on 87 octane crap gas
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 05-07-2008, 07:36 AM   #31
BurnoutNova
those sure dont look like 58cc combustion chambers, there way to big
Old 05-07-2008, 07:48 AM   #32
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Not when you CC them
Sinister
Killer
Old 05-07-2008, 08:48 AM   #33
HoupPhotography
It could be a few things...
The cam wasn't broken in properly (lubed & ran)
The valves weren't adjusted properly (to tight)
or you got a bad cam, it could be a cheap cam too.
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 05-07-2008, 10:05 AM   #34
BurnoutNova
do you have to take into account the thickness of the head gasket and the valve reliefs on the pistons?
they look like big open chambers, but im probly just not looking at them right?
what is the casting number?
Old 05-07-2008, 08:39 PM   #35
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
IDK what he did, but if I had to guess he just lubed & ran it, but again IDK
The cam was a Comp Cams 268H
Sinister
Killer
Old 05-07-2008, 08:41 PM   #36
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I have the casting numbers somewhere & I'll post em up for you, but I'm not looking for a pissing contest about my heads... I have em, I know what they are, & Im running them
Sinister
Killer
Old 05-07-2008, 10:02 PM   #37
HoupPhotography
Your right, it's hard to tell! The only sure thing is your getting a new one, with the head work you can put a nice thumper in it.
That truck is badass, if you ever want to sell it, let me know!!
Old 05-07-2008, 11:01 PM   #38
BurnoutNova
i wasnt trying to argue, just understand what you did. thats all.
sorry for the miscommunication
Old 05-08-2008, 04:39 AM   #39
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Thanks bro, I dont have any plans on selling it but I'll let you know
Its kool, thats one thing bout the internet, its always hard to tell what "tone" someone is using
The head number is 14014416
Sinister
Killer
Old 05-08-2008, 06:16 AM   #40
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
I have a comp cam that came out of wild mouse that has way more round lobes than yours !! I called them and they told me I must have installed wrong or improper break in !! Bulls@#t I will not use a comp cam again . Have too many friends that have had trouble with them getting flat lobes on em . I am sure someone will chime in and tell me they think they are great and it was my fault . I've been building motors for 20 yrs this was my first and last comp cam!!!! My 2 cents ! I think the cam you told me about will be great in your motor !! Later, Bob
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
Old 05-08-2008, 06:30 AM   #41
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
I was wondering why that cam sounded so healthy. Only 14 valves were opening
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 05-08-2008, 06:35 AM   #42
67_C-30
67_C-30's Avatar
I've been building engines with Comps for years with no problems, but that doesn't mean they didn't ship one out without it being case hardened. It happened to GM in late 60's, and it could have happened at Comp. Either way that sucks, and I hate to hear about that.
My trucks
Old 05-08-2008, 06:42 AM   #43
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
I'm not saying they make junk . I had a bad experience and I don't forgive real easy . I will choose not to run them in the future . I hope this doesn't happen to anyone else and i got all the bad luck !! Bob
Old 05-08-2008, 06:48 AM   #44
67_C-30
67_C-30's Avatar
I totally understand. If my first product from a manufacturer was bad, I sure wouldn't be in a hurry to buy from them again ESPECIALLY since customer service didn't help you out any.
My trucks
Old 05-08-2008, 06:54 AM   #45
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
Yup They acted like since I didn't have a shop with my name on it or I wasn't what they call a "professional" I must be a automatic retard !!! So I felt that people like that don't need my money!!! Bob
Old 05-08-2008, 07:56 AM   #46
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Bob, Im there with you
Its the only comp Ive ever ran & it sure doesnt make me want another one... Im not saying my brother couldnt have done something wrong, but I highly doubt it
I mean, hes about as picky / pefectionist as I am on engines & I dont think he would have just been a "Auto Retard"
I called Lunati & had a great experience with them... I called TALKED TO A PERSON, then that person tranfered me to ANOTHER PERSON !!!!
Great deal
I did call back later & the time between the first person & the second person was a lot longer than the INSTANT transfer I got the first time, but it sure beats the heck out of a lot of other companies that you have to have a user manual to get through the Auto system
BTW Bob, I showed you 2 cams... the 00017 & the 00010
Which one did you like better ???
Im thinking the 00010 even tho its prolly a lil big for my engine, it should be sweet
Sinister
Killer
Old 05-08-2008, 07:58 AM   #47
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I know right
The crazy thing is, it didnt run too bad
Sinister
Killer
Old 05-08-2008, 08:12 AM   #48
HoupPhotography
Everyone makes mistakes, even comp and especially folks that don't build motors for a living, even those that do make mistakes.
I'm sure what the comp guy was implying is that your not a "professional" builder, have a machine shop or install cams on a daily basis, it either came out wrong or was misinterprited. They would be around as long as they have if they built junk. (IMO)
Old 05-08-2008, 08:37 AM   #49
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I agree with that for the most part, but I also think it could be possible that they do occasionally send out some less than quality products
Sinister
Killer
Old 05-08-2008, 08:43 AM   #50
HoupPhotography
Absolutly, with what they produce per month, that is bound to happen.
