Old 07-22-2008, 07:08 PM   #26
panhandler62
Java Mechanic
panhandler62's Avatar
Re: Need a new carb for my '70 cst/10
The best carb I ever had was a Holley Street Avenger. They all work well when set up properly though.
Q-Jets are the best all-around but you will get more grunt from an aftermarket carb, just decide what set of minor irratations bothers you the least. AFBs are easier to tune properly than Holley types, but they have more vapor problems.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 07-22-2008, 07:20 PM   #27
70rs/ss
70rs/ss's Avatar
I think the OP needed some help, since he bought a new edel already. The question is the throttle is too long and no vacuum port. First is the throttle a cable or a rod? if a rod, a new one may be needed or made or if a cable, it should have an adjustment, if not a new adjustable one may be needed. For the vacuum, the edel has the port on the front as well as a port on the rear, but it may have a black allen plug in it, pull the plug and get a threaded hose barb and you are good to go, hope that helps??
70rs/ss is offline   Reply With Quote
Old 07-22-2008, 09:58 PM   #28
t&tkennels
t&tkennels's Avatar
I assum you you have a throttle rod & , not a cable. if its a rod go to the hard ware store & buy a peice of threaded rod & cut it the length you need it & you will also have endless adjustment. ive seen this on a car before cant remember what carb it had.
t&tkennels is offline   Reply With Quote
Old 07-22-2008, 10:57 PM   #29
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Exclamation Re: Need a new carb for my '70 cst/10
Or the throttle rod from a 6cyl will work just fine in the v8's spot, used one on a buddy of mine's truck because of the same exact problem of it being too long and not having enough adjustment. As far as the port on the back of the carb, you may have to use the port in the manifold behind the carb for your hookup.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 07-23-2008, 08:30 AM   #30
mrein3
mrein3's Avatar
I know a lot of guys run without it but you should really get the throttle rod stud that Edlebrock sells. If you look back at the picture I posted on page 1 you'll see the piece I'm talking about. There is no chance of that rod stud binding while just pushing your throttle rod in the arm on the carb could bind. It would really suck if it binds at wide open throttle.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
