Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 05-17-2008, 09:04 AM   #26
IAFF2407
IAFF2407's Avatar
Re: Overhaulin' - Seattle style
Gear Vendors,
I have the HD model with a deep sump for towing. I don't know what the size difference is with the regular oil pan. We couldn't lower the engine in with the tranny, the GV would not fit over the tranny crossmember with an angle. Once we seperated the motor and tranny , the tranny and GV went in without a problem. Went with a one piece drive shaft, 56 1/2 inches ( with the 14 bolt rear)
the T400 mounted on the last bolt holes in the frame for the tranny crossmember and mounted the motor mounts accordingly. I was suprised on how easily the Caddy motor went in, fits very well. on the stand the caddy motor looks ugly with the dizzy and the a/c comp. on the front, but in the truck it looks great. like it belongs there.
following pics shows the clearance for the GV
2nd pic shows two fingers clearance
1972 GMC Sierra
1972 GMC Super Custom Suburban
IAFF2407 is offline   Reply With Quote
Old 05-17-2008, 09:08 AM   #27
IAFF2407
IAFF2407's Avatar
tranny hump, low versus high myth.
4th picture in the above post/repy shows the clearance of the T400 and a LOW hump. my guess is aprox. 1 1/2 ". Lots of clearance. I'm waiting for a warm day to see how hot it gets. with the caddy running between 200* and 210* (normal for the caddy) it might get to warm for my taste and then I'll put in the high hump.
1972 GMC Sierra
Old 05-17-2008, 09:13 AM   #28
IAFF2407
IAFF2407's Avatar
this will be the before pic, I'll post more pics when the 500 is in.
1972 GMC Sierra
Old 05-18-2008, 04:52 AM   #29
72 sub
72 sub's Avatar
That is sooo cool, ever thought of putting caddy emblems on it and passing it of as a old escalade ?
If you get lost, come back and tell me where you are. 72 Burb, 86 1 ton crew cab dually.
72 sub is offline   Reply With Quote
Old 05-18-2008, 05:56 AM   #30
IAFF2407
IAFF2407's Avatar
funny you should say that, I'm having one of my co-workers have his uncle make me a V8 - 500 out of billet for the fenders.
I've already started planning for some t-shirts to screen;
ie:
"size does matter"
"no replacement for displacement"
"It's big- it's bad- and powered by Cad"
etc...etc..
I was thinking of following CG's lead. I need a name for the Burb, so I'm offering a years subscription for this board for help in a name.
when it's completed it will have the caddy 500, caddy T400 and the 3 rows of seating (and console) from a '07 Escalade.
"Suville" is taken by another member. other possible names to come my way have been,....Burbalade, Burbillac, Subllac,
any ideas and help would be greatly appreciated.
1972 GMC Sierra
Old 05-18-2008, 09:26 AM   #31
Livrat
Member #1049
Livrat's Avatar
Al... your welcome for everything.. I had a great time!!
Just had to say the cowgirls miss you!! well maybe they miss your tips...
I discovered why your 350/350 was bleeding all over.. the crank bolts were loose and one had backed out so far it was pushing on the torq converter causing it to go off center and making the seal non functional.. plus not only one bolt was missing off the torq converter to flex plate.. the flex plate was also cracked..
Livrat is offline   Reply With Quote
Old 05-18-2008, 04:25 PM   #32
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
told you the caddy engines are the ****!
Looks good, and 15 MPG in a full grown burb is pretty nice huh?
Old 05-18-2008, 04:35 PM   #33
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Very cool build thread in sucha short time the gv has to be awesume on the hiway..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-18-2008, 10:02 PM   #34
Frizzle Fry
Frizzle Fry's Avatar
Cadillac Subville
Frizzle Fry is offline   Reply With Quote
Old 05-20-2008, 05:26 AM   #35
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 05-20-2008, 05:54 AM   #36
Longhorn Man
I am soooooo itchin to swap my burb over too.
Heck, i could sell the motor mounts and stands, and then the short water pump stuff, and more than finance the whole thing!
Old 05-20-2008, 05:15 PM   #37
IAFF2407
IAFF2407's Avatar
Hey Andy, I'll have a 425 available within a month, all it will need is the pulleys and a carb, it has the rear sump and rwd exhaust manifolds, (albeit a small crack in one) runs smooth as silk.
maybe a round trip roadtrip coming up eh!
jeffspower; this will definitely be t-shirt material
Al
1972 GMC Sierra
Old 05-21-2008, 10:12 PM   #38
suville
suville's Avatar
How bout "sub deville", thot about that one myself but too many letters for plates I think you can only have seven so I went with "suville"
suville is offline   Reply With Quote
Old 05-21-2008, 10:48 PM   #39
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Subdvil?
MylilBowTie is offline   Reply With Quote
Old 05-22-2008, 05:48 AM   #40
suville
suville's Avatar
Duh why didnt I think of that ?????????? That'll work!
Old 05-22-2008, 03:37 PM   #41
MylilBowTie
Right turn Clyde
That will be $5.00 haha j/k
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
Old 05-23-2008, 03:41 AM   #42
67_C20Pres
New Member
67_C20Pres's Avatar
Yep, a Cadillac big block will start the giddy feelings. We used to refer to the 68' DeVille convertible as our "S U D" (Sport Utility DeVille).
How about Sub for the Burb!
Steve
67' C20 - Newest - My junkyard dog and work in progress
67_C20Pres is offline   Reply With Quote
Old 05-23-2008, 03:53 AM   #43
IAFF2407
IAFF2407's Avatar
finally back on the site, been really busy. Subdvil is great, up here we only have 6 digits on our plates, I'd have to use "Subdvl".
any other suggestions guys,
and thx for the help.
Hey CG, I finally have the buddy buckets done. can you say "redneck". black leather and green/black snakeskin. I'll post pics on the truck site in a couple of days.
Al.
1972 GMC Sierra
Old 05-23-2008, 05:21 AM   #44
CG
BlahBlahBlah
Al.
You have some cowboy boots made to match the seats?
Sounds cool Al, I can hardly wait to see the pics.
Old 05-23-2008, 06:26 AM   #45
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I'd never heard of Cowgirl Coffee until I read this thread yesterday, then last night they were on the news. Someone's trying to get them shut down for wearing pasties. I say if you don't like it, don't go there.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 05-23-2008, 07:29 AM   #46
IAFF2407
IAFF2407's Avatar
Damn I never saw any "pasties" only underwear. That's too bad, ask Livrat, it was far nicer having a smiling girl (working for tips) with pleasent "conversation" than an old miserable battle axe ... or worse yet..... a cowBoy. those girls can make a $200 - $300 a day in tips, 7 hour shift. who do you think is the smart one is!
1972 GMC Sierra
Old 06-22-2008, 12:52 PM   #47
IAFF2407
IAFF2407's Avatar
I've installed the front seats now. The seats are from a '07 escalade. All that was needed to to was drill 4 holes each, no shimming needed as they sit perfectly on the floor pan perches. I hot wired them temporarily to see how for forward/back they would go. These seats are perfect for the 'Burb, they raise you up a little and are nice and firm.
1972 GMC Sierra
Old 06-22-2008, 12:56 PM   #48
IAFF2407
IAFF2407's Avatar
I'm leaving the stock seat belts in because I haven't found replacements for the new seats yet. Seats are bolted down with large washers underneath. The nuts and washers will be welded to the pan later.
1972 GMC Sierra
Old 06-22-2008, 01:04 PM   #49
IAFF2407
IAFF2407's Avatar
I'm working on what to do with the middle row today. It is really tight for room, definitly won't be able to use the 'power fold up seat' option. I may use the 3rd row seats only. After the seats are in, I'm hoping to get this complete and installed next week. Hey Mark, are you ready for another visit?
1972 GMC Sierra
Old 06-23-2008, 01:07 AM   #50
CG
BlahBlahBlah
Coming along nicely Al. Those seats look real comfy.
