Old 05-09-2008, 10:26 PM   #26
BowTieOgre
Re: Lowering springs
I would be tempted to leave the back as is and lower the front 2-4".
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 05-09-2008, 10:31 PM   #27
Rooster's82
Rooster's82's Avatar
I think the angle of the picture and the slop of the parking spot is playing tricks....the rear is higher. The suspension is totally stock, the leaf spring my be tired...but they still hold the rear high.
JG
If you can't find it at the junk yard you don't need it.
Rooster's82 is offline   Reply With Quote
Old 05-09-2008, 10:33 PM   #28
Rooster's82
this is the only pic from the side i have....(also that isn't my bike, i ride a Honda CBR600F4i)
JG
Old 05-10-2008, 04:12 AM   #29
Square84
I don't think these pills work
Square84's Avatar
not computer savvy enough to put big pic on page but my avatar is my 84 lwb 3/6
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 05-10-2008, 05:03 PM   #30
Rooster's82
hmmm...that is pretty low.
Does anyone have a 2/4 drop they want to share?
JG
Old 05-11-2008, 12:27 AM   #31
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Roost-
To help figure out your clearance, you could load your truck with your bikes/passengers and take a measurement to see how much clearance you have between the framerail and the axle. Then, post the measurements and go from there. Also, if your set on those wheels, check to see how close they sit to the fenderlip to avoid any rubbing when you do lower it.
When I get a chance later on, I'll post a ~2-4 drop of your truck.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 05-11-2008, 07:07 AM   #32
boxrodz
boxrodz's Avatar
Roost-
I decided to go with a 2.5/4 chop drop (drop spindles,hangers/shackles). The shot is somewhat deceiving since the bike is loading down the back a bit in the original pic.
boxRODz
Old 05-11-2008, 08:39 AM   #33
flamingbig10
6.0 powered square
flamingbig10's Avatar
2insh/4ish weak coil springs with one coil cut off, and the back has drop shackels and 3 leafs no over load
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 05-12-2008, 09:04 AM   #34
Square84
Square84's Avatar
Hey Flame Really Nice Truck. Not Much For Shortbeds But Yours Looks Good
SQUARE84
90 SUBURBAN
Old 05-13-2008, 04:25 PM   #35
Rooster's82
Boxrodz,
Thanks! that looks nice...Im definitely sticking with my rims and tries. Next time i have the bikes in the back i will do some measuring.
Here are some better side shots with no load....
JG
Old 05-14-2008, 11:33 PM   #36
78BO
78BO's Avatar
Good thread, I was going to end up asking the same thing. Looks like I will be doing a 2/4 drop.
78BO is offline   Reply With Quote
Old 05-20-2008, 01:40 AM   #37
boxrodz
boxrodz's Avatar
Boxrodz,
You're welcome.
Quick work on the primer.
Fresh paint on it should look good.
Here's another p'chop using your latest pics. Your truck should almost sit level with a 2.5"-4" drop.
boxRODz
Old 05-20-2008, 04:55 PM   #38
Rooster's82
HA! that is SWEET! man...i almost want that logo! Thanks BoxRodz!
JG
Old 10-15-2008, 01:44 AM   #39
flamingbig10
6.0 powered square
thanks square didn't see that you complimented on my truck until now, was going through some old threads to see what I posted in the past
Aaron
Old 10-15-2008, 07:01 PM   #40
Square84
Square84's Avatar
no problems i do that to sometimes.
SQUARE84
90 SUBURBAN
