Old 05-13-2008, 06:32 AM   #26
69face
69face's Avatar
Re: Static drop lowering-totally lost!
Originally Posted by C10 the GEM View Post
If you do a flip kit and flip the origianl leaf spring hangers how much will that drop?
a cnotch definitely and about 8 inches but it looks insane
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
Old 05-13-2008, 05:25 PM   #27
JCampbell
I don't remember the exact numbers, but it's low. Really low.
But it looks sweet.
JCampbell is offline   Reply With Quote
Old 05-14-2008, 03:03 AM   #28
C10 the GEM
Smok'em Roast'em Shift'em
C10 the GEM's Avatar
I plan on dropping the front 5 and the rear about 7. With a c-notch. If i go with the 7" drop in the rear will i need a big c-notch?
C10 the GEM is offline   Reply With Quote
Old 05-14-2008, 03:51 AM   #29
69face
69face's Avatar
you will need at least a three inch notch to be happy
I'M SO SO CAL!
Old 05-14-2008, 05:05 AM   #30
C10 the GEM
will the notch that comes in the sport truck direct kit enough?
5/7 drop
http://sporttruckdirect.com/C10_kits.html
Old 05-14-2008, 07:35 AM   #31
SCOTI
SCOTI's Avatar
5/7 drop
Yes, that notch will work w/a ~7" rear drop (flip kit on an 8-leaf HD spring pack + drop shackles).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-14-2008, 08:11 AM   #32
EN*PN78
EN*PN78's Avatar
my two bits.
I did my truck the cheap way cut coils on the front for about a year. Cool for a little while but 2.5 spindles 2inch or 3inch lowering springs the way to go. I still cut of 1 coil on the 2" springs to be crazy. But I like my stuff slammed.
The rear end for me, I use my truck daily and my work is welding. I need to haul weight if its engine or metal. I would C-notch for sure. I custom made mine. It was easy. I want the rear lower to level it out but Ill live with it. 6/6 drop.
EN*PN78 is offline   Reply With Quote
Old 05-22-2008, 05:43 AM   #33
C10 the GEM
do you have any pics of the process of lowering it such as your c-notch and your flip kit?
