Old 10-07-2014, 02:25 PM   #26
Trap62
Trap62's Avatar
Re: tilt steering for our trucks, aftermarket or later model swap ins?
Originally Posted by mikke1 View Post
Was wondering if a 64 impala steering column will work on a 64 c10 pick up truck
Here's a thread showing a '64 Impala column going into a '66 -- might help...
http://67-72chevytrucks.com/vboard/s...64&postcount=8
Trap62 is offline   Reply With Quote
Old 10-07-2014, 10:15 PM   #27
wahl4m
i just installed a "flaming river" tilt in a 66 carryall ,nice unit,shifter dont have enough travel ,got a after makret linkage kit ,should work OK ? only thing that bothers me is the tilt should have 1 more upward tilt position ??? anybody notice that ? i used the uo joints with the column -BOY ARE THEY NICE AND HEAVY-DUTY !!
wahl4m is offline   Reply With Quote
Old 10-07-2014, 11:38 PM   #28
mikke1
Thanks....
mikke1 is offline   Reply With Quote
Old 10-08-2014, 12:22 AM   #29
ol_skool_chevy
ol_skool_chevy's Avatar
Anybody ever try a 73-78 tilt steering into a 64-66??
I want my key in the column and locking wheel....
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 10-08-2014, 05:32 AM   #30
pdxhall
pdxhall's Avatar
I'm in the process of putting a 71 Camaro floor shift tilt column in my truck right now. I does take a bit of fabricating to make it work especially since I am moving it back so I have a little more room for my big belly. I pie cut and bent the 71 mount to fit and I am in the process of cutting and fitting the original mount so I still have the emergency brake and stop light switch in the original location.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 10-08-2016, 10:46 AM   #31
Caraudiotekk
Caraudiotekk's Avatar
Finding van columns is a pretty hard task I'm finding..
Caraudiotekk is offline   Reply With Quote
Old 10-08-2016, 12:07 PM   #32
Chevy Fleetside
Chevy Fleetside's Avatar
Did you try Pick n Pull. I was lucky and got one on 25% off day and paid about $28 for it. It was a few years ago though.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 10-08-2016, 12:45 PM   #33
Caraudiotekk
Just on the web hunt... Viking is next for me... Thanks for the reply. Just trying to stop my hemorrhaging from this ls swap
Old 10-10-2016, 02:59 PM   #34
gnhuntin
Originally Posted by tincan1966 View Post
I have a '94 C1500 column in my '65. Not a bad swap, but does require a bit of fab work. I converted my wipers to the turn signal mounted switch for delay control.
The shift lever on the 88 and up columns is reversed from the older style, so I fabbed my own cable operated shifter for the TH350C trans.
As someone posted earlier, The 3 speed auto columns and 4 speed auto columns have different detent spacing, and do not normally line up correctly when trying to adjust linkage. It is possible to actually hurt the trans do to improper gear engagement from a mis-aligned linkage. If you cannot select all the gears, then it is not set up right.
Do you have wiper delay, if so, how did you accomplish it? I think I read somewhere the delay is built in the wiper motor.
gnhuntin is offline   Reply With Quote
Old 10-10-2016, 07:37 PM   #35
64shortbox
64shortbox's Avatar
I was able to get a 72 Van tilt for my 64 off eBay for around $119.00 with shipping. The seller had lousy pictures, I could tell the shift indicator needle was broken but it was otherwise complete. I bought the tilt specific needle for around $9.00 and a new P R N D 2 1 lens while I was at it. I did have to move the Neutral Safety switch further down the column towards the firewall but a pretty straight forward installation. I also slid the column down as close to the dash as I possibly could to gain a little more gut room. Unfortunately I just couldn't stop there I also had to add a 73 Power Disc brake pedal and a 72 suspended gas pedal after adding Power Disc Brakes. These things are NEVER done!
64shortbox is offline   Reply With Quote
Old 10-11-2016, 08:08 AM   #36
earl84
You may be able to find a tilt column out of an RV also. I found one that did not have the key on the column, so I could have a stock-ish look. Did the same things as 64shortbox and it is very comfortable to drive.
earl84 is offline   Reply With Quote
Old 10-12-2016, 01:52 AM   #37
Caraudiotekk
Beautiful job! Thanks for the reply and sharing your pictures.
Old 10-12-2016, 01:52 AM   #38
Caraudiotekk
Thank you
