#26 |
![]() Join Date: Jan 2006
Re: Rustoleum?
I am currently in the process of spraying a couple of panels. I am using reustoleum high gloss black. I had solid panels to begin with so i scuffed up the old paint real good and applied a couple of coats of rustoleum primer....sanded the primer and then shot using a compressor and harbor freight gun. I am thinning the paint 30% with acetone, thats about double as reccomended on the label. I like to thin down to a Skim milk-like consistency. Also, I have learned that the spray pattern and quality of atomization of the paint is crucial in preventing orange peel. If this is your first time using a spray gun as it was mine...it's basically a trial and error deal in order to find your guns optimum spray pattern. I'll try to post some pics if i get a chance. Overall I am pleased with the result I am getting with rustoleum. If your truck is a daily driver or weekender like mine is I think you can't beat this paint for it's afordability and durability.
#27 |
![]() Join Date: Apr 2007
Re: Rustoleum?
I painted my 74 chevy van and my 61 chevy truck with rust oleum regal red over rusty metal primer ,worked good, faded after a while but red always does anyway. My other truck with forest green looked good too! Also I have been rusty metal priming and gloss blacking frames on my projects for better than 20 years,works great and still hanging on the frame of my 69 camaro 22 years so far.
#28 |
Re: Rustoleum?
ttt
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
#29 |
Re: Rustoleum?
I forget to mention you only need around 35 or 40 lbs of air presure to paint little compresers usually keep up just fine.
#30 | |
Re: Rustoleum?
When I started in on my truck cab I went to a paint house here in the Cities, near where I work. For primer he suggested PPG DP40LF. I walked out of there with a gallon of that epoxy primer, enough reducer for the whole gallon and $125-$130 lighter in my billfold. After I used that up I went to the paint guy in my town. He said use the PPG cheaper line. Epoxy but cheaper. I honestly couldn't tell the difference. After two years now there are no lift or bubble issues so I'll guess it works the same. And for that gallon with all the chemicals I needed in hand I got out of the store for less than $100. So now if you are looking to primer a whole vehicle I'm guessing 2 gallons will cover it. I believe the cheaper PPG epoxy I bought comes in white, gray and black. If you want the primer look, and you want it black, why not do it right the first time for under $200 or so? And you can still top coat it with automotive paint when you are done. BTW, I later bought and used PPG single stage top coat. Again less than $100/gallon with all the necessary chemicals to mix. I didn't like it. I had some left over DuPont single stage that went on very nice over the PPG epoxy. When I get to the box it will be cheapo PPG epoxy under DuPont single stage with hardner. After I get my box painted I'll have less than $500 into the whole truck in paint. And I'll have done it over 3-4 years. If you're putting gas in these trucks today you can afford one hundred bucks a year in paint supplies (I just filled both tanks on my rig for $110.)
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
