07-06-2008, 12:59 PM | #26 |
Robert Olson Transport
Re: Frame rivets - easy ways to remove
the way i did it on my 81 was to take the dremel ( electric) with cutoff wheels and score the rivet heads every sixteenth of an inch which meant about eight cuts through the head of it and i got em down as close as i could to the frame without actually cutting into the frame then with a hammer and chisel i cut off what was left of them and used a punch to pop out the remainder of the rivet... if youre steady handed, you can use the dremel to cut off the pieces of rivet too but you have to be careful to not cut into the frame.. i used three or four cutoff wheels for each rivet.. it was time consuming but it worked
07-21-2008, 07:19 PM | #27 |
Java Mechanic
WHufff..... Angle grinder, air hammer, pry bar and BFH, and I have more to go.
They aren't doing much "jumping out of the holes." lol
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
07-21-2008, 07:22 PM | #28 |
07-22-2008, 12:08 AM | #29 |
Truck and auto performance nut
seems like to me that drilling through them before cutting them off was the easier route (came apart easier) but then I didn't do that many. when I get to my '68 frame that will be a different story.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
07-22-2008, 12:41 AM | #30 | |
CHEVY ONLY Last edited by joe231; 07-22-2008 at 12:42 AM. |
07-22-2008, 01:26 AM | #31 |
The best way I have found is to get a GOOD resin fiber disc and angle grinder to grind the heads completely off, somewhere around 24-36 grit. It only takes about 15-20 seconds to grind the entire head off with a good disc. I started off with x-cuts and an air chisel, but this was MUCH easier to do.
Then I used an air hammer with a punch to drive the rivets out. This works probably 90% of the time, but occasionally you'll need a monster hammer and punch to get some stubborn ones out instead of the air hammer.
1967 Chevy SWB 1972 Chevy SWB 1972 Chevy SWB K20 4x4 1991 Ford F-150 2013 Dodge Ram 1500 4x4 Last edited by lchall; 07-22-2008 at 01:28 AM. |
07-22-2008, 06:47 AM | #32 |
Java Mechanic
I did manage to get one crossmemebr out so far ... I guess it took about 90 minutes altogether.
I need to get one more out and then remove some of the smaller stuff before I can go about getting the frame stiffeners out. I'm hoping that I can get the bump-stop perches off from the backside so I don't have to go after the three rivet heads in their groove. I'm going to loose the small cross brace altogether because I want to tuck a gas tank up in there. As you can see here -- ignoring the rust in the stiffener would be a mistake. :P You can also get a pretty good look at what's left of the rivets here, even after all the gringing and chiseling.
01-16-2011, 12:08 AM | #33 |
But Found Her 25yrs Later!
Thanks for this thread.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
01-16-2011, 01:29 AM | #34 | |
"Once a Chief, always a Chief!" MCPO (ret) 03 2500HD- 'Daily driver' 67 Short Fleet- 'Drivable project!' 11 Malibu LTZ- 'The Wife's ride' |
01-16-2011, 01:23 PM | #35 |
A day should have 30 hours.
A way I found, grind the head flush with the metal. Then use a punch and a hammer.
Came out easy for me. |
01-16-2011, 11:31 PM | #36 |
I've found that my grinder is my best tool for this...preferably outfitted with a cutoff wheel. Then my air chisel setup with a punch to drive them thru.
