#26 |
Re: How hot is too hot
Personally I removed the thermostat as I get nervous anything above 210 as it stays garaged below 40 in the winter. This is another reason not to bore a block where the water jackets are so thin. I like the added thickness on the block. I hear 50/60 over all the time, I cringe.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
#27 | |
Moderator
![]() Join Date: May 2007
#28 |
ive always been worried about this i run a 160 thermostat and no shroud and in traffic on an 80 degree day it get up to about 200. ive been thinking about goin to electric fans but will they help to keep it cold and can i still use my engine fan with them
#29 | |
There was just a big thread about this very subject about a week ago. |
#30 |
Moderator
A shroud is the best thing you can have to improve your cooling efficiency. You can have a powerful electric fan, but without a shroud to "force" the air through the radiator, it just takes the path of least resistance around the radiator.
#31 |
No, it will not fit, if you want elec. fans, build a shroud out of some sheet aluminum and a good fan, Spal, flex a lite, etc and it will stay cold. Make sure that it is spinning the right way, pulling if on the back of the engine, otherwise it will push the air coming in back out again. Early classic builds an electric fan kit for our trucks with the stock rad, so that is an option, too, and it has a pre-made shroud
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
#32 |
unless it is right up against the radiator
#33 |
I have duel electric puller fans that come on 50 % at 195 and 100 % at 210. they are sealed to the inside of the radiator. they also have two flap seals that will allow air through when you are moving. As to the T-stat my truck actually ran hotter with the 180 T-stat then the 195. I think because the high flow pump would pump the coolant to fast with the T-stat wide open and not allow it in the radiator long enough to cool.
69 Chevy 4x4 383 Power ![]() |
#34 |
Another consideration is how hot is the oil and at what temp does it break down. One of the claims for synthetic oils is that they can survive higher temps than conventional oils.
#35 |
Gone to greener pastures
It also puts a little back pressure on your water pump to keep the block full, preventing "hot spots."
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
#36 |
![]() Join Date: Dec 2006
Another factor in play here (that I always forget because I've only had manual transmissions for years) is that if you are running 250 deg. then your automatic transmission will also be running hotter and higher temperatures excellerate clutch,band,and seal deterioration.But with a stick,I don't worry.
Any of you guys running str8 water,or a weak dilution of antifreeze because of leaks or just cheapness,expect to have overheating probs,a rusted out engine,and failed water pumps as a result!
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
#37 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
#38 | |
![]() Join Date: Aug 2005
