Old 06-12-2008, 09:13 PM   #26
El Jay
Gone to greener pastures
Re: Rust Removal by Electrolysis
Originally Posted by ERASER5 View Post
rickf used bakingsoda . See post #4. This why I used baking soda. I know that bakingsoda is less powerful than soda ash, but it should still work. My ratios may just be off.
I been running my setup for about 4 hour now (runnig the reversed polarity). Lots of rust has been blown off, but new rust is forming on the formerly clean surfaces. Still the parts are cleaner than before.
My bad.
I didn't reread the entire thread.
I read through it all when it was new, but not this time.
And the other procedure that I saw was after riveted1's original; And I just happened to remember the washing soda.
Have yourself a great weekend.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 06-12-2008, 09:19 PM   #27
jorgensensc
jorgensensc's Avatar
I don't think your mesh is working correctly as the (anode). When I do this I use a piece of scrap steel and it always bubbles at the scrap steel. Try it with a peice of scrap steel in the corner. The stainless might be messing with something.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 06-12-2008, 09:27 PM   #28
Riveted1
Tasty Cakes!
Riveted1's Avatar
Originally Posted by El Jay View Post
I think you have the recipe wrong.
The original recipe here called for soda ash (anhydrous sodium carbonate).
I have also seen the same procedure using "cleaning soda" (Sal Soda; hydrated sodium carbonate)
I have not seen it using baking soda (sodium bicarbonate)
To put into technical terms; them extra carbonate salt thingies, attached to the sodium widgets could be messin' with your chemical reaction.
Some notes:
El Jay is correct. I've heard that regular baking soda will work, but takes much longer, and the results may be lackluster. That is because sodium bicarbonate is less basic than sodium carbonate.
The negative terminal has to be on the parts you are cleaning, otherwise the reaction occurs in reverse. So you are currently adding material to your parts!
You also don't want to use Stainless Steel! The process will create toxic fumes and is dangerous. If you have a section of pipe or something laying around, use that. It will be much safer.
Just my .02
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 06-12-2008, 09:39 PM   #29
chipflyer
chipflyer's Avatar
Been doing it for years to clean up old tractor parts. I have found that the best stuff to use is Arm and Hammer Washing powder. I do like to use a piece of Stainless steel to use as the anode (red lead) as it will not get eaten up like a piece of steel will and if you do much of this you will realize how fast you eat the anode up. Here is a pic of a 1929 John Deere D wheel that I did, had to flip it but it really turned out nice. Don't hook it up backwards, it will actually eat up the part you want to de-rust. THE BLACK LEAD goes on the part you are trying to remove rust from!
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 06-12-2008, 09:48 PM   #30
shifty
Questionable
shifty's Avatar
hmmmm, i wonder how well this would work on some steelies (wheels)?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-12-2008, 09:57 PM   #31
chipflyer
chipflyer's Avatar
It would work good Shifty, not as quick as blasting them though. If you add a little red devil lye It will completely strip paint and leave a nice black coating on the wheels.
Jeff
Old 06-12-2008, 11:07 PM   #32
ERASER5
ERASER5's Avatar
So where would I find soda ash?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 06-12-2008, 11:15 PM   #33
shifty
Questionable
shifty's Avatar
i just want to save myself the effort of trying to get sandpaper down in the cracks, nooks and crannies and was thinking about putting naval jelly on it.
Old 06-13-2008, 12:14 AM   #34
El Jay
I would think that any place that sells swimming pool supplies would have it.
It's not really all that exotic.
Old 06-13-2008, 03:01 AM   #35
Riveted1
Tasty Cakes!
Riveted1's Avatar
Originally Posted by Riveted1 View Post
I went to the local pool supply and picked up some Soda Ash, aka sodium carbonate.
Aha!
