Old 06-13-2008, 04:08 PM   #26
Anthony Fremont
Anthony Fremont's Avatar
Re: 66 GMC Header Installation
Well, I went back to the supplier and swapped the late model (67-72) V8 engine perches for the correct ones that use the back two holes. Apparently, these are the same perches that most inline 6's used.
At any rate, they fit and my headers clear beautifully. Wow, what an experience....all I wanted to do was install some headers.
'66 GMC Custom Fenderside LWB
'90 IROC - L98
'97 1200C Sportster
Anthony Fremont is offline   Reply With Quote
Old 06-13-2008, 07:13 PM   #27
Chevy Fleetside
Chevy Fleetside's Avatar
They are the same as the 6 cly ones. On the 6's they have metal brackets that streach out to the perch.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-16-2008, 01:38 PM   #28
Anthony Fremont
That's what I was figuring. Got the engine buttoned up this weekend, put the radiator in that came with the truck. Fired it up yesterday long enough to open the thermostat, but I didn't want to bother the neighbors too much with my open headers. I didn't have enough advance at first and it would pop when you revved it up. Tweaked the timing up and it sounded vicious.
I can't believe the carb works as well as it does after sitting dry all these years. I scrubbed it with degreaser, hosed it off and let it dry. That's the extent of my work on it and I get a decent idle and throttle response. I haven't even put a timing light or vacuum gauge on it yet, gotta get some mufflers on it first.
'90 IROC - L98
'97 1200C Sportster
Old 06-17-2008, 05:33 PM   #29
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
I LIKE THE MEAT! Whens dinner? For real tho that is a good looking engine! Chris
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 06-17-2008, 06:07 PM   #30
ValveTubeHead
ValveTubeHead's Avatar
Originally Posted by Anthony Fremont View Post
.... Wow, what an experience....all I wanted to do was install some headers.
is there an echo in here? famous last words.
from a simple weekend project to 3mos overhaul in short order:
feb 9.
may24.
worth it
Matt
'65 LWB Fleetside
'63 SWB Fleetside
ValveTubeHead is offline   Reply With Quote
Old 06-17-2008, 06:25 PM   #31
62 short step
62 short step's Avatar
What time is dinner? I'll be there shortly!!
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 06-17-2008, 06:29 PM   #32
Anthony Fremont
Looks great, but don't toss your original valve covers. Those without brackets tack welded all over are hard to find.
It's a wonder any of these trucks have the heater boxes still attached; it was one of the first things to go on my truck.
What kind of intake are you running there? I wish I had a two barrel intake with the oil filler tube.
'90 IROC - L98
'97 1200C Sportster
Old 06-17-2008, 06:42 PM   #33
Anthony Fremont
If you liked that, you should see what I can do for a rib-eye. Pretty handy with a brisket too.
'90 IROC - L98
'97 1200C Sportster
Old 06-17-2008, 08:59 PM   #34
ValveTubeHead
Edelbrocks newish #2703...mine looks a tad different than the one on summit site; production changes isuppose.
Matt
'65 LWB Fleetside
'63 SWB Fleetside
