Old 07-11-2008, 08:41 PM   #26
Ford Assassin
Ford Assassin's Avatar
Re: Auto shift linkage in way of power brake booster
Originally Posted by Sport/Truck View Post
I think there too bulky. Plus all the extra lines that need to be run to the PS pump.
Agreed, Plus I already have my booster.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 07-11-2008, 08:45 PM   #27
Boog
laying low
Boog's Avatar
I'm with Larry in that I was just thinking of hydroboost as an alternative in this situation but I realize the OP already has a unit he wishes to use. I believe there are only two hydro lines to run from the power steering pump to the hydroboost. They work very well and are a smaller diameter package than the conventional vacumn boosters. More clearance for a big block.
If the OP is set on using the 73 up assembly he may be able to heat and bend the shifting linkage to gain some clearance. Or trade his unit for the corrrect one for his truck.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
