#26 |
Re: PCV vs. Breather.....
Somebody gets to eat crow......
Toys/projects Many toys, not enough time to play! My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I’m back!!! ![]() |
#27 |
Good question. Youd have to find the baffle, then the block has to have a knock out in the proper location. Newer blocks dont have it. Intake has to have the tube in front for air in
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#28 | |
Young gun
67 SWB Custom "JANE" http://67-72chevytrucks.com/vboard/s...d.php?t=554024 Northwest C10's http://www.facebook.com/#!/groups/Norhtwestc10s/ Cameron sparks |
#29 | |
You still need filtered air in to the crankcase, since the pcv is sucking it out
#30 | |
![]() Join Date: Aug 2011
Thanks Joe Hester |
#31 | ||
"I ain't nobody, dork."
A lot of cats using the old closed style covers will drill a hole in the back of the cover that faces the firewall to get a PCV system hooked up..
Unless you have an old block with provisions for a road draft tube. You WILL have to drill holes in the old style covers to make them work properly on a newer block. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#32 |
![]() Join Date: Dec 2012
I have yet to see pics of one, but my 67 283 has a PCV valve with the in-to-carb-base end threaded, and the other end with a 1/2" hose barb for the hose from the crancase. It should have had a hole in the block directly behind the distributor, but a PO put a later block in. It came to me with later valve covers with holes in them. I plan to put an NPT threaded port just in front of the distributor and baffle it some way. Of course, it will have to retain the filtered oil cap on top of the oil fill tube in front of the radiator hose neck. I understand there are two types of screw-in pcv valves---one screws into the crankcase air-outlet hole. The other is like mine and screws into the vacuum source (carb base plate). That would mean they are designed to flow opposite of each other, so you would have to be sure you have the right one for how you are using it. Mine has an arrow stamped into it. I just went to AutoZone and asked for a PCV valve for a 67 C10 with a 283, and thats what they handed me. I have seen both types in Classic Industries catalog. Go to the catalog on their site and search PCV for various 62-67 models (impalas, Novas, etc) and you will see the "road draft" style vent tubes, as well as the tube for a closed system. I think the Nova catalog shows that. But remember, for any one of those, it would have to be a block with the provision for that end of the ventilation system. BTW--someone please correct any part of this, so I can get mine right too!
JK |
#33 |
Isaw a guy on here that was real creative with a block of aluminum, mounted on the back of the vc as gary said. Cant remember which section it was in....might have been the engine section. Someone else might know of it, it was pretty slick, and not difficult to make
#34 |
This is how it was on vehicles with no holes in the valve cover, and a closed PCV system. The first pic is the PCV valve on a 67 C10, the second is the fitting in the back of the block for the other end of the hose. The third and fourth pics are of the same setup, but on a 67 327 Camaro block. Not shown, but absolutely necessary, is the oil fill tube pressed into the front of the intake with a filtered oil cap. (that is, if you arent going to have breathers in the valve covers. Besides having to let air into the crankcase, you'd have to be able to put oil in somewhere anyway)
JK |
#35 | |
JK |
#36 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=366853 |
