07-12-2008, 10:52 PM | #26 |
Big Red & Mister Blue...
Re: 350 CID engine damper is pissing me off
Ok
K10 1967, SM420 & Rockwell T221 C1500 1991, 305 CID, Ext Cab, Full Size bed, everything original except air cleaner. |
07-13-2008, 12:08 AM | #27 |
I don't want to disilusion you but you can't just go done to auto-zone buy some bearings slap them in and hope the engine lives. I had to buy 3 sets and mix and match to get the clearances I wanted. If you don't have a good micrometer or know how to use it you should buy some plastigage and follow the instructions. Another thing I just bought a 290 hp 350 from Jegs and the end play on it was .003. 005 to .010 is a well used engine. Another thing is you should champher the back side of the bearing so it gets better oiling to the thrust surface.
69 Chevy 4x4 383 Power |
07-13-2008, 12:12 AM | #28 |
Nah, is was thinking on buying some federals; i guess we have the same engine then, so i can go by the same endplay clearance, hopefully theres a part number on them, so i can order.
07-13-2008, 12:19 AM | #29 | |
I also don't understand what you mean by chamfering the back of the bearings - I wouldn't do ANY prep on main bearings for installation. Sorry - maybe just a difference in experience. I do agree that someone that doesn't know which bearing is the thrust bearing shouldn't be making this change; Killer - you really need to get someone else to tackle this IMHO, maybe pay the shop to do it. Sorry again - but that'd be my recommendation. Last edited by Billla; 07-13-2008 at 12:20 AM. |
07-13-2008, 12:30 AM | #30 | |
Well i see it as a OEM replacement work, just swap a bearing for another identical, but new. But is a good advice; now that u say that, i think he had some serious problems with his crank, maybe the bearing got worn out and there was metal to metal friction against the main; or is one of those that has tappered journals. Is all about the money, i dont have the money and the means to get the engine to the shop, and dont have the means to pay them either.
07-13-2008, 12:34 AM | #31 | |
07-13-2008, 12:37 AM | #32 |
Again, just differing experiences - I've never run into that problem (never) and so offered my experience.
07-13-2008, 12:39 AM | #33 |
All i need right now is a long screw driver, maybe 2, to properly remove the cam and crank gears and the propper endplay clearance. Im a novice, but i dont want to go to mech school empty handed
07-13-2008, 12:49 AM | #34 | |
I have a radical idea!
I totally agree. If you're having to do all that then either your rods/mains are out of spec or the crankshaft is. You can get away with mixing and matching shells on a street engine, but they will never live on a high peformance or heavy towing engine (meaning like a 1 ton or medium duty hauling truly heavy loads, not a 1/2 ton pulling a trailer) . Mixed shells may make your tolerances right, but the ID bearings are not truly round. If it wasn't the crank (and it usually is) I'd have the block aligned honed or have the rods machined to correct the problem, but that's just me. On 99% of motor machine work, +/-.001" is plenty suffice, and compared to the kind of machine work I do everyday, a .001" tolerance is a mile. I mean that's a Stevie Wonder with a file tolerance there!! Also, I don't know the problems on the GM crate engines, but I can also tell you that on a high RPM high performance engine, .003" is on the tight on end play. .002" - .006" is the production range, but with HP race engines, you have to shoot for the high side. I've always liked at least .006" and up .008" on circle track engines. The same thing applies to rod side clearance. If run production specs on a substained high RPM engine, they will rub. I've also ran a minimum of .015" clearance on those. I know this may not apply here, but these are common problems with severe duty engines.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
07-13-2008, 12:50 AM | #35 |
The crank gears have nothing to do with it. You have to have the rear main cap loose engine for the rear thrust bearing to move.
07-13-2008, 12:54 AM | #36 |
According to Chevy High Performance 0.0020 - 0.0025 is the ideal clearance
07-13-2008, 01:04 AM | #37 |
According to GM, .002 - .006 is the tolerance. As I said, .002 will live on street engine, but it will not a performance engine. This is from someone has been building engines for 15 years and race engines for 12 of them. If I were you I would not touch the bottom end of that engine until you check the end play now and put a torque wrench on it as Billla said, and see how many ft lbs it takes to turn it over. If you can turn it by the flywheel, I bet its not even hurt. There have been 1000's (probably 100's of 1,000's) of Old timers and shade tree mechanics that have beat balancers on SBC's. It's actually more likely that is OK than not...
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 07-13-2008 at 01:05 AM. |
07-13-2008, 01:12 AM | #38 | |
Ok, wilco, now my question is Billa said 40f/p or so, but whats the actual range that a new engine, never used the crank should turn?
K10 1967, SM420 & Rockwell T221 C1500 1991, 305 CID, Ext Cab, Full Size bed, everything original except air cleaner. Last edited by killer_mike; 07-13-2008 at 01:12 AM. |
07-13-2008, 01:17 AM | #39 |
I knew i was missing something thats why i checked again; so i dont need to take all that stuff off, even better; but i will do the check with the torque wrench tomorrow, im done today, getting that trannie assembled kicked my butt. Is heavy as hell. In case is bad, it shouldnt be that bad, i wasnt using a sledge hammer
K10 1967, SM420 & Rockwell T221 C1500 1991, 305 CID, Ext Cab, Full Size bed, everything original except air cleaner. Last edited by killer_mike; 07-13-2008 at 01:34 AM. |
07-13-2008, 01:46 AM | #40 |
Beating on the harmonic balancer is wrong? Wish someone would have told me that before doing it to every motor I have ever worked on.
07-13-2008, 01:47 AM | #41 |
Thats the purpose and the why i started this thread
07-13-2008, 10:26 AM | #42 |
Coming down to brass tacks, I agree completely that folks have been pounding these things on for a long time - I still have little piece of oak 2x4 that I used to use for this along with my small sledge "Mini Marge" (daughter of Large Marge) just in case anyone thinks I'm coming off as "holier than thou"
Today, there's no reason to, and good reasons not to - mostly about the experience of the person doing the beating. First, if you miss and hit the ring it's very easy to break the bond between the hub and ring - and that's going to have catastrophic results. Second, the problems I've seen with bearing damage have come from two things - hitting the balancer off-center, and beating the living daylights out of it. And I have pulled down engines that have gone bad due to these. Using the right tool eliminates these risks - especially for someone that doesn't do a lot of engines. Given the price of these things, why risk it? Smooth, easy and predictable. Killer, I have to tell you (again) you're setting yourself up for trouble - your posts cause concern for anyone experienced in engine building because they show a lack of experience and knowledge. I'm not trying to be a d*ck, but at the same time it's hard for me to see someone heading for a cliff and not say something. It gets me in a fair bit of trouble here - but so be it. Take the thing to a shop or get an experienced engine builder to see if the balancer is on all the way - and then just leave the thing alone. |
07-13-2008, 11:04 AM | #43 |
mini truck racer
There have been 1000's (probably 100's of 1,000's) of Old timers and shade tree mechanics that have beat balancers on SBC's. It's actually more likely that is OK than not... X2 on both of these .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
07-13-2008, 04:26 PM | #44 |
FWIW, I talked with my Level 4 machine shop guy today about something else and asked him about this. He stated that bearing manufacturing tolerance is typically .0003. If you assume that both bearing shells were out by max allowable, this makes for a .0006 clearance...which is why we might very, VERY rarely end up swapping in 1/2 a .001 bearing shell to take up .0005 clearance. We're typically shooting for .002 - .0035 main clearance for warm street engines...so you can do the math on how far off a bearing set (or journal diameter) would need to be.
07-13-2008, 04:31 PM | #45 |
Ok, ft/lbs 40-45; end play: clockwise rotation 0.206" & counter clockwise rotation 0.209"; i used a jimmy bar to pull it back a little on clockwise rotation and it gave me 0.209 from 0.206, on counter clockwise rotation game me 0.209 1/2 from 0.209.
The measurement was from the block to the crankshaft, and the difference is a nifty 0.003. So spparently the engine is good Billa, i dont have my head up my ass, i do listen to ppl that know about this more than me, so dont think ur advise is going to deaf ears. But like i said, money constraints, but i will look if theres an engine builder nice enough to come to my house and check it out, if i get lucky.
K10 1967, SM420 & Rockwell T221 C1500 1991, 305 CID, Ext Cab, Full Size bed, everything original except air cleaner. Last edited by killer_mike; 07-13-2008 at 04:36 PM. |
07-13-2008, 04:44 PM | #46 | |
Never said you did, and I understand the budget issue (trust me) - you're the one that said you wanted to inspect. But if you're going about this the way you are them I'm not adding anything useful and I'll sign off. Good luck! |
07-13-2008, 04:47 PM | #47 | |
I didnt mean to be a dick, when i said i dont have my head up my ass, i meant to say that i listen to advice.
I will take a pic how i meassured. Quote:
07-14-2008, 03:53 AM | #48 |
Hope no one has hard feelings, im not in the practice of being a dick.
Was reading the Hynes book about my truck and stumbled with the crankshaft section, it gave me an alternative to the dial gauge, feeler gauges, i had a Kobalt set, brand new, so they are not warped due to usage and the clearance is the magic 0.002-0.003. Just gotta keep in mind to put some grease on the rotating assy of the engine stand, first time i used it and a little warning when ordering bolts from Jegs other than ARP, THEY BREAK, i got one stuck on my old block and it seems my first mission after im done is get that thing out, the bolt was for the engine stand and they are too long for my stand so i had to go to Home Depot and find some bolts, lucky me, i found grade 10s; and finally i got a hold of the break-in procedures specifically for my engine from gmperformance.com. I keep u guys posted in case theres something else going on, thanks everyone for the help.
