06-23-2008, 01:56 AM | #26 |
KEEP ON TRUCKIN'
Re: exhaust exit preference???
Strait out the back
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
06-23-2008, 07:34 AM | #27 |
I perfer 45 degree exiting out the side behind the rear tires.
With straight out the back, if you have a cover or shell camper on the bed it can/will bring exhaust into it due to the vacuume created behind the truck. |
06-23-2008, 12:32 PM | #28 |
Mine exit out before the rear wheels and it looks fine but I'm going to pay the price to have it exit out the back. My reasons are #1) I think the sound is better out the back and, #2) I hate smelling the exhaust sitting at stop lights or idling. Granted, if I could ever get the carb tuned right it wouldn't smell so rich but I just like it out the back regardless. I do dread finding a shop to trust with this as it will be a challenge. There isn't much room back there....
07-26-2008, 04:39 PM | #29 |
Well I got it done.................18 inch Magnaflows.............2 1/2 inch tube in and out...exit in front of wheels......................sounds good runs good! I don't even hear them cruising..............but when i get on it..........it's got the sound!!!
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: |
07-26-2008, 04:47 PM | #30 |
Old Skool Club
Mine currently run at a 45-degree angle in front of the rear tires. That meant that the 40-series Flowmasters had to be beneath the cab floor. My wife hated the droning noise that is the result of that placement.
So, my plan now is for a pair of Cherry Bombs, under the front part of the bed, with tailpipes extending to the rear of the truck, exiting beneath the bumper. Now the question is whether to go with an old school look or to tuck them up behind he bumper corners. There was a truck that was done several years ago for the Texas Motor Speedway that had the tailpipes exiting behind the ends of the bumper....with just a little bit of the pipe showing. Then, there's the possibility of using T/A exhaust tips.....behind the rear tires, but centered between the wheel opening and the bumper.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
07-26-2008, 05:57 PM | #31 |
I like exhaust pipes all over the place.I mean,it depends on the vehicle,the look I`m going for,and/or performance.
I think on a longbed 4wd pickup that had nice wheels and paint I`d go with the stockish duals running out @ a 90 close behind the rear tires.That`s on a clean 4wd.Straight out under the bumper is nice,too,for a little hot rod touch.Mostly with a sport bumper.I think keeping them behind the wheels looks best with a step bumper.If the truck had a more off road look,like heavy bumpers,I`d run it out in front of the rear tires for a no b/s minimal damage exhaust.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 07-26-2008 at 05:59 PM. |
07-26-2008, 06:28 PM | #32 |
45 degree angle, dumping behind the rear wheels.... quieter and not as smelly as dumping in front of rear wheels.........
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
07-26-2008, 07:03 PM | #33 |
another vote for 45 degree's behind the rear tires.
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
07-27-2008, 01:49 AM | #34 |
Ive got glass pack out the back right know but im switching to flows and turned down out of the mufflers, it looks clean and sounds good to.
07-27-2008, 06:28 AM | #35 |
Tucked all the way to the back to be heard, not seen:
07-27-2008, 07:40 AM | #36 |
Project: years too late.
out the side befor rear wheels.
1971 C10 Stepper LSX 5.3/4L60E 3.73 12bolt posi. Father Son Project. In Memory of Bruce C. Shorten. Rest easy Dad. Ill take it fryom here. |
07-27-2008, 07:51 AM | #37 |
Old Skool Club
FrizzleFry...that's a clean setup.
07-27-2008, 09:59 AM | #38 |
I like to have mine behind the wheels on an angle leveled with the bottom of the bed when you look at the truck from the side you wont see it...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
07-27-2008, 02:28 PM | #39 |
67-72 Addict!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
07-27-2008, 03:21 PM | #40 |
Built 4 Speed
Well IMO your Exhaust is your Vehicles Fart tube and i like to hide them as much as i can so i have always been pretty big on dumping it Right behind the cab where no one sees it.and run 45*s out of the mufflers. Gives the truck alot more of a rumble bouncing from the truck to the cab. but in front of the tire looks decent also.
1969 C/10 Short Box: 496/T-56 in worx. "To Be Old And Wise, First You Must Be Young And Stupid" |
07-27-2008, 03:32 PM | #41 |
Well, Whoop-dee-do!
Funny nobody wants stacks?
Seems to be the in thing with the young crowd now, diesel or not. Nothing like a F150 with 8" stacks off a bull wagon
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
