#26 | |
Re: Drive Shaft Center Support Bearing
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 ![]() |
#27 |
The oddest Todd around
When I did mine, the u-joints were shot as well. I had to have all 3 replaced as well as the carrier bearing.
It was actually cheaper to have the 1 piece driveshaft made and put in than it was to have the 3 u-joints and carrier bearing replaced. Both prices were having them do all the work. I drove in, got 2 quotes, and went with the more awesome of the two choices. I didn't have to do any grinding or anything to fit the longer driveshaft in there. Just took out the carrier bearing and done.
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
#28 | |
my carrier bearing and u-joints were all replaced in 2007 (less than 20k miles ago). so hopefully I can just do the center support bearing and be done with it!
#29 |
Put center support bearing on driveshaft, fit yoke in place and used yoke center bolt to "press" bearing home. I lubricated bolt to ensure I did not damage the threads. Once bearing was seated, I backed out bolt, flatten washer a bit, cleaned grease off threads (bolt and bore) and used blue Loctite on the bolt. At least that is how I remembered doing it.
#30 |
#31 |
I recently replaced
mine with a nolathane bush and alloy housing unit i think around $120 which should last very easy job i also replaced the u joints no need to balance drive shaft all you need is a vice and some 1/2 inch sockets if get stuck a workshop manual is very helpfull
"I ain't got no time for side tracks!" 69 R/T Charger 72 C10 Chevrolet 85 302 Jaguar 99 955 Daytona 10 1050 Speed Triple |
#32 |
If all you are doing is replacing the hanger bearing there is no need for a re-balance. If you are running a lot of power I would give inland empire a call. They aren't cheap but there are guys running 10 's with 2 piece drive shafts
#33 |
the boat guy
"Nothing was changed" I've balanced thousands of multiple piece drivelines. You can take a balanced shaft from the balancer, mark everything, change a carrier bearing or ujoint, put it back together using the marks, and the balance WILL change. It doesn't have to make sense to you for it to be true.
These light duty carriers can't handle any vibration, the brace will break.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, Last edited by brad_man_72; 04-25-2015 at 08:42 AM. |
#34 | |
the boat guy
You did have a slip and stub installed in the rear shaft right? The billet carrier doesn't allow for any movement forward and back like the old carrier, somethings got to move when that suspension goes up and down. There's a reason that every other vehicle made 73+ that has a 2 piece driveshaft has a slip in the rear shaft.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, Last edited by brad_man_72; 04-25-2015 at 08:43 AM. |
#35 | |
the only thing I didn't like was when they balanced it weight was 180 degrees from old weight (still on) I'm not far from you so prices should be similar Old school mechanic in my area (the one I really trust) says he takes driveshafts to driveline shop for u joint replacement. If he does it, I think I better |
#36 |
#37 |
![]() Join Date: Jan 2012
My son was driving my '67 and the carrier{center brg} brg went. I used this thread for inspiration.
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS ![]() |
#38 |
The harbor freight ball joint tool is way cool and cheap.The trans slip yoke I ordered from Dennys Driveshafts. The guy I talked to after the shop closed gave me a number for the slip yoke 2-3-4911-x to order. Said this will fit the original is no longer produced. hopefully be hear Monday, The gu at Dennysdriveshafts was very knowledgeable!The reason for replacement,big grooves in the yoke
#39 |
I've replaced mine twice in the last 24 years. The first time was kinda tough, because the only thing I knew was what I learned from watching my dad replace one on his truck, when I was a kid. A lot of patience and finesse is needed to get the original bearing to come loose. After you get it loose it's an easy task. (The second time I did it was to replace a cheap Chinese bearing that failed in less than a year. It's replacement has been working for about 12000 trouble free miles) While I do agree, wholeheartedly, that it's best to take it to a professional, if the budget doesn't allow, you CAN do it yourself. Holler at me if you need anything more.
