07-20-2008, 09:28 PM | #26 | |
Re: Choosing a Distributor
The ALTERNATOR was getting red hot and transferring the heat thru the wire. I pulled the alternator and will have it tested tomorrow but other than that I am lost. |
07-20-2008, 09:40 PM | #27 |
the alt. itself might grounding internally......good chance thats it i recon. too bad you dont have a buddy same alt. you could try out.
07-21-2008, 09:03 AM | #28 |
Well the alternator tested "fine" it put out more than enough amps. Still wondering about any voltage regulator inside though.
Tell me, the current wiring setup that I had on my truck for the alternator was the main alternator red wire, the primary ignition wire from the fuse block and a red wire from the junction block all joined by a connector. |
07-21-2008, 03:10 PM | #29 |
07-22-2008, 05:53 PM | #30 |
I put on a reman alternator and a new thicker gauge (10) alternator wire just to double check and it would still overheat after a minute. I checked the pink ignition wire and didn't see any fraying or cracking. Again the distributor is the only difference in the equation here.
07-22-2008, 08:32 PM | #31 |
i have no clue
