09-20-2008, 01:17 PM | #26 |
Re: 57 build
the truck has kind of been sided for abit saved a 70 swb from the shreder, not like ineeded another project. Im also contemplating going with an s-10 chassis under the 57 to get it down the way i want and also mite be switching to a 307/350 thats in the 70 , then put the L6/pg in the 70 and make it a DD
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done... |
09-21-2008, 10:39 PM | #27 |
Re: 57 build
Hey pugs has any one ever dne an s-10 swap on a 55-59 truck before? I am curious...hope it work and post lots of pics!!! truck is coming along nicely! love the dash!
09-21-2008, 11:33 PM | #28 |
Re: 57 build
i never seen the s-10 swap done yet either but i have a few ideas in my head for cab mounts, and as for the bed i will cut down the s-10 bed so the floor and wheel tubs will fit the stock step side bed. the dash is coming along just need todo a;itt;e work onthe passengers side to make look more evenly to the drivers side
11-22-2008, 02:47 PM | #29 |
Re: 57 build
ok been awhile since i posted about the 57, i had metioned going to an s-10 chassis, well i snagged 1 up, just had to remove the m/t/t-case and a few oter parts for a buddy and the frame was mine i slide the cab on the chassis and somewhat hung the front sheet metal on it im liking it already one i get in the garage i will get pics of how im doing the cab mounts, i have a good fairly simple idea on im going to do it using exsisting s-10 mounts. any way here are a few teaser pics
11-22-2008, 04:33 PM | #30 |
Navy Radioman Veteran
Re: 57 build
Nice Thread!
I just love watching one of these trucks coming together. Mine is still in pieces in the garage. Nice progress. Ken
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside |
11-22-2008, 08:36 PM | #31 |
Re: 57 build
thanx 87, its gonna take aliitle longer now that im swapping chassis and that winter is setting in its gonna take alittle longer, plus i mite even do another dash change, found something else that mite better fit the look of the truck
11-23-2008, 10:31 PM | #32 |
Re: 57 build
did alittle messing around on the thuck today, got it inthe garage , pulled out the front diff and set the I6/pg in place, not real happy with it as the engine sits abit to high for me. the front of the cab does have to come up about1/2-3/4" tolevel it out and then slide forward about 1" then i can mark off where i need to trim the front horns off.
11-23-2008, 11:19 PM | #33 |
Re: 57 build
why the 4x4 frame? wouldn't a 4x2 frame be a better choice for what you are doing. you not making it a 4x4 are you. the t bar setup on the front of those s10 dosn't ride all that well i know from personal experence. i have had a couple of s10. with the engine you are putting in that the front end will want to wander and the extra weight will play hell on the front ball joints. all of my s10 4x4 i have replace the ball joints on at least every year to two years if i'm lucky. not to mention the pitman and idlers are known for lots of play with the 4.3 in them. my jimmy that i have now with only 84 thou when i bought it i had to put ball joints on it and that isn't the first set that was put on it. the pervious owner had two set on it already not including the factory riveted ones. just want to let you know what you are getting into.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
11-24-2008, 12:09 AM | #34 |
Re: 57 build
i went with the 4x for one the price real cheap and twp the track width is wider. there is no extra weight in the front the 250 I6 is lighted then the v8. i drove the s-10's myself i dont thing the handling is that bad
11-24-2008, 02:24 AM | #35 |
Re: 57 build
how much wider is the track width? i also have heard the negatives about the 4wd setups vs the 2wd. the one thing i can say is most of these trucks see "limited use" so if the ball joints need replacing at 75,000 miles (aka 10 years) buy napa parts because their lifetime warranty, they ask no questions. can't be that much weight difference in the 250 inline vs the 4.3 v6. keep the pic's coming.
11-24-2008, 06:44 AM | #36 |
Re: 57 build
your right as far as the 250 vs 4.3 but i also have no transfer casr and no front diff in, and with that i can get t down alittle lower and still have plenty of clearence. believe it or not this truck still has the original reveted balljoints on yet. its no pro-touring truck and i driven worst around over the yrs. i will have to remeasure as i dont quite remember the track width off hand but i believe its like 6" total width vs the 2x
11-24-2008, 06:46 AM | #37 |
Re: 57 build
meant to say i can the engine down alitle lower and still have ground clearence
11-24-2008, 05:13 PM | #38 |
Re: 57 build
Pugs,
Been studying the hood and grille pics. What about a small center grille in the hood opening to match the floating grille in the front end? Just a thought - I am so OCD I would have to make the holes match. |
11-25-2008, 09:58 PM | #39 |
Re: 57 build
what kind of pieces are you going to make to simulate the half shafts in front? maybe just cut them off leaving the stub ends? they say the 4wd frame kicks up farther in the back and is wider. wish i had mine side by side to compare.
11-28-2008, 11:58 PM | #40 |
Re: 57 build
well been tinkering with the truck, got the m/t mounted where i need it at.instead of using the stock 4.3 block mounts i went to once from a 67 chevelle, now i did have to narrow and replate the mount that bolts to the frame for it all to work out, still need to drill a couple of hole to totally have them nice and tight
while walking the local u-pull today i seen this crossmember laying on the ground,no clue what its out of but it was the right length. i used the rear hole on drivers side to bolt it up andthen cut about 1.5 inches off the passenger side and the trans mount plate and welded them to the yard crossmember it worked perfect ineed to do alittle trimming onthe toeboard for more trans clearence and then start on the cab mounts. also while at the yard did alittle measuring on a 65 long stepper and i think now im going to pick a long bed up and then just shorten up the sides about 8-9"
11-29-2008, 01:33 AM | #41 |
Re: 57 build
looking great pugs, i like the s-10 frame swap idea, never would have thought of usinf a 4x4 frame, but use it if it works is the way to look at it, glad to see it coming along, great job, any pics of the 70?
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
11-29-2008, 01:50 AM | #42 |
Re: 57 build
thanx nuke its a slow process but its getting there. no recent pics of the 70 as its in pieces, but i have the cab about 2/3rds (inner rockers, supports, and corners) done and about all the parts to get it together but it mite be going bye bye as i need the cash will be laid off soon and gf had to have surgery this past week so i need to watch the cash
11-29-2008, 08:06 AM | #43 |
Re: 57 build
lookin good. i just got laid of too. got my steering mocked up. hope everything goes ok for your gf.
11-29-2008, 10:17 AM | #44 |
Re: 57 build
Pugs,
Im confused...you getting rid of the 57 or the 70?? If you get rid of the 57 I will never know how to do my other 56' truck...If you sell the 57' pm me first... |
11-29-2008, 11:36 AM | #45 |
Re: 57 build
i was looking to off the 57 a couple of months ago but since changed my mind and im offing the 70.
11-29-2008, 12:05 PM | #46 |
Re: 57 build
sorry to hear about your misfortunes, hope everything goes good for you
11-30-2008, 12:45 PM | #47 |
Re: 57 build
well i figured out what to use for front cab mounts, took a 1/8 th piece of flat stock about 2.25x2.5 cut a slotted hole and welded it to what was the radiator support mount trimmed down, will need to cut off what was the s-10 front cab mount. now i dont have them welded to the frame as of yet til i get the floor/toeboard trimmed out, front frames horns trimmed alittle more, and the rad support made up. also mocked up the frontend im using. rear cab mounts are going to be alittle tricky on account that the holes are right at the edge of the frame, but i kind of have that figured out with a piece of 2'square tubing
11-30-2008, 12:49 PM | #48 |
Re: 57 build
So you cut the front raditor/core support mounts of the frame and relocated them back behind the origonal front cab mounts and palted the top of the rad/core mount? Sorry,Im just really interested in how you are doing this!!
11-30-2008, 12:58 PM | #49 |
Re: 57 build
yup you got it right
11-30-2008, 01:44 PM | #50 |
Re: 57 build
Man that's a good looking truck you have there,
what did you end up doing with the hood with the hole in the front (i think it was a GMC hood.) what are your plans for the bed. thanks an keep the pic comeing. memo
Memo S. Retired US Marine Family Man |
