Old 03-06-2009, 11:52 PM   #26
sailed2japan
Jonny
sailed2japan's Avatar
Re: 1964 C-10 with Cummins power
The motor will clear the cross member and stay inder the hood on a 2wd, but the same is not true for a 4x4, at least not on a 73-87, then you'll need a body lift or a custom cross member w/ a suspension lift.
I already have a 1983 c20, 6bt, slightly modded turbo, getrag, 2wd, 4.10's 14 bolt full floater (already killed 2 semi-floaters, those spider pins are WEAK!)
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
