08-18-2008, 01:56 AM | #26 |
Re: so lets build a truck/my '52 chevy
maybe you can get a universal one for hot rods they are small. you will need air down here if you plan on driving it much.
1971 Corvette convertible 454@ 525 hp 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
08-18-2008, 11:03 PM | #27 |
I really dont use the air in any of my dads cars when I cruise them. thats why i chose no air. I will probably add air later on though, no heater or defrost, just air.
08-18-2008, 11:15 PM | #28 |
more line....been drilling and tapping holes like crazy. The airlines are basically done. The brake lines are 95%. The fuel lines are just started and run over the notch. Need to figure out how Im going to connect them to the tank and how I will finish them to the engine. the pics are confusing so bare with me.
08-25-2008, 07:55 AM | #29 |
you mentioned that you put dodge brakes on the 12 bolt, what dodge has the correct bolt pattern. like the under dash brake setup and impala wheel. reall great looking project and keep the pic's coming.
08-29-2008, 11:37 AM | #30 | |
so everyone run out to your nearest news stand and pickup the copy of superchevy with the baddd nova on the cover. Our wagon got a 4 page spread and this truck got a sentence in there, LOL. but as some of you know we have a hurricane coming so we'll see what happens. |
08-29-2008, 12:52 PM | #31 |
Great job! You're making miss my 48...........
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-04-2008, 11:25 PM | #32 |
well my truck survived the storm. But because of the storm my wiring harness and everything to do my trans is not going to come in for a while. boo
11-21-2008, 08:27 PM | #33 |
any updates?
11-22-2008, 07:41 PM | #34 | |
I don't know if you can see this one but it is in a Speed 33 and has a brake/M/C AND A/C under the passenger side.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
11-23-2008, 09:08 PM | #35 |
I should have an update wednesday. Im at school(LSU) right now but I go home for thanksgiving. Im planning to rip apart my t-56, cut it up, and when reassembled the shifter will be about 10" forward of where it is now.
11-28-2008, 02:07 PM | #36 |
ok, this is freaky. you built the almost the exact truck i have been thinking up for my 49 forever. same color and everything. dont know what ls series motor that is, but i was gunna use an ls7, and same 6-speed tranny, bags and everything. weird....
love it though! looks awesome. u do really nice professional work.
__________________________________________ -1949 GMC 100 longbed -1972 chevy c/20 suburban -1982 chevy k-5 blazer |
11-28-2008, 02:07 PM | #37 |
but ive since decided to keep my rust, so you dont have to worry bout havin a clone lol.
11-29-2008, 12:16 AM | #38 |
lol, yeah weird.
Im currently waist deep in modding my t56 for center shift and it sucks. Very bad. And that is just a regular ls1, for now. But I thinking ~1.5 liters more displacement and twin hairdryers would make it move nicely. Not sure how crazy I want to go yet. either way for now its just an ls1, and I have a wild cam to put it in. |
11-29-2008, 01:39 AM | #39 |
WOW, that is some nice work you have goin on there, talk about having to run some lines that is do darn tedious, great job
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
12-16-2008, 01:47 AM | #40 |
gettin back to work.
bolted the IAT in the air filter and it hit the TPS, so I worked on that tonight. how it looked... inside view which raises the concern I had of drilling through that lip and not having the bit walk. in the drill press.. shot of the hole and the bit I used.. back cut the lip... tapped assembled IAT and new blue plug... |
12-16-2008, 02:03 AM | #41 |
very nice build you have there, nice and clean and i will agree with you on the color choice, it can be heck to spray, but a beautiful color, hardlines are ran real nice.
12-17-2008, 03:16 AM | #42 |
we had an s-10 in the shop that is a total so I took the PCM mount out of it.
air filter mounted...also see the steam line I ran in the water pump... fan controller... started to run the vacuum line for the booster... and started to section the dip stick... cut... in pieces... I was going to weld it all back up and section the actual dip stick tonight when I got home but its like 1:20am and I want to go to sleep. will update tomorrow. Last edited by cajundragger; 12-17-2008 at 03:16 AM. |
12-17-2008, 07:47 AM | #43 |
looks good, I like the hard lines, Spal makes good stuff, I have their dual fans on my vette but they had troubles with the electronic controller. it had a high failure rate. they even quit selling it at one time. they were having it made by someone else. mine use a simple temp probe and a relay to turn them on like this
http://www.speedwaymotors.com/SPAL-F...NSOR,5350.html if they are selling them again they might have the problem fixed. just wanted to give you a heads up.
12-17-2008, 09:59 AM | #44 |
well I picked mine up something like a year ago. We'll see...
12-18-2008, 12:59 AM | #45 |
pcm mounted...
spot the battery... just a reg napa...no real power demands in this truck so I really dont feel a super duper optima or the like is worth it. preweld fit of the dipstick tube... to shorten the actual dipstick I first drilled a new roll pin hole then drove the tiny tiny roll pin out and took the handle off... trimmed it and reassembled... took like 7" out of it... whole thing... |
12-18-2008, 01:00 AM | #46 |
took the water pump off and popped the fittings out...
then tapped them for pipe thread so they can be plugged... that stuff and a few other things were all for today. Tomorrow the wiring that controls the engine will be finished. Which means Im waiting on a bunch of fittings that I ordered tonight and to tune my computer and she should run. |
12-23-2008, 12:13 AM | #47 |
dip stick..
connected rear fuel lines to tank... every mans dream...lol fuel lines to engine... fuel pressure... plug wires.. lots of wiring... |
12-23-2008, 12:13 AM | #48 |
just waiting to get my computer tuned and I can start it up. Got to get a few more parts to get but should be ready to drive soon. |
12-23-2008, 12:35 AM | #49 |
making progress, looks good. where did you get your motor mounts?
12-23-2008, 12:59 AM | #50 |
they are stock vette mount uppers with like a universal rubber biscuits and lower mount to the frame.
