08-22-2008, 12:28 PM | #26 |
Re: Complete air suspension kit.... Help!
I just like the response I got from KP when I asked a ton of questions.
I tried like hell to save on my '69 while still running 8 valves. When it was all said and done I saved about $200 and it was NOT worth the hassle I went through. This time I am just going with the 8 valve KP setup and cal it a day. Hindsight is a *****.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
08-22-2008, 02:27 PM | #27 |
soon to be bagged64sub
Looks like something from AIM to me. But you could try it out and let us all know how it goes.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
02-21-2009, 09:32 PM | #28 |
Loading.....
So.... I guess I'm buying into the full kit rage. I think the self levelling aspect of these two is just too damn neat.
Price is the same, options are similar, but which is the best system? Accuair or RideTech or another one that I don't know of? I must be crazy thinking that 2k for this stuff is worth it.
-M7 '69 SWB GMC 5.7 EFI ‘69 C/10 SWB patina survivor ‘71 GMC K20 '72 K5 1-ton gear 468BB ‘86 K30 GMC High Sierra C&C Single Cab '96 SWB Single Cab 5.7 ‘99 SWB Z71 Single Cab '00 SWB Single Cab 5.3 '01 K2500 Yukon Safari 6.0 ‘06 2500HD Single Cab C&C Duramax 4x4 '08 1500 crew '11 2500HD Single Cab Duramax 4x4 |
02-22-2009, 04:35 PM | #29 |
I researched the last manifold and a red similar setup from e bay and found buyers replyed problems with machine fit and leaks also the supplyer has no serviceable parts so one silinode goes out your back to the wallet again!
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172 |
02-22-2009, 04:46 PM | #30 | |
I did research and now have $1194 in a four bag with 8x 3/8 valves 5 gal alum tank-hoses and fitting- The Auto-pilot controller just need to order compressor and dryer the alum tank could prevent rust in valves so spend a bit more now and save down the road
04-30-2009, 08:51 AM | #31 |
If it's ok to steal some action, I'd like to get my 86 c10 lwb in shape. Right now, it is stock. I was thinking of getting it lifted 4" so it would look cool and I could put bigger, wider wheels on it for look. Just because I would be putting that much money into the project already, (cheapest I have found for a good one is about $500 with shipping) I figured it wouldn't be that much more expensive to just bag it and have it raise up to 4" and drop down when I use it for work. I think I saw that there are bags for load leveling so they would work to keep my truck looking level when I tow a big load. I checked out suicide doors and like the price for their cheapest kit and bags but this may not fit my truck at all?
Either way, I figure a good tank and compressor will double for using air tools and if the controls can let me drop the front and back (preferred) or even each corner independently then it will be that much more of a cool ride. My hope is to install this with some buddies assuming that if I lift the frame up enough with my jack set and blocks, the suspension can be worked without any problems. Any suggestions are appreciated and please let me know if there is an especially worthwhile kit. I don't think I saw one with brackets to mount the bags so that may raise the part cost that much. I like the kit you have up on your last post mtm_steven. That looks great but its about double the size of my college kid budget... Maybe I can get about the same performance out of a simple toggle switch and some set heights in the suspension? I'm fine sacrificing smooth and good looking performance for the general height resetting from low to high in just front and rear. Feel free to send me an email: badassissimo@gmail.com. I'll be watching the thread and I'll let you know if I find a good looking kit mtm_steven. Thanks. |
