Old 09-09-2008, 10:21 PM   #26
rkyham
rkyham's Avatar
Re: What power steering gearbox are you using?
Planning this swap on my 68
On using later model boxes: Does it matter if the box is from a 2wd or 4wd?
--oOO-- (_)-- OOo--
1955 Chevy Bel Air 2 Dr Sedan
1968 Chevy C-10 LB Fleetside
1999 Chevy Malibu (daily driver)
rkyham is offline   Reply With Quote
Old 09-09-2008, 10:41 PM   #27
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
My '67 short-step had manual steering until I swapped it out with a power steering box out of a '85. Bolted right up and didn't have to modify anything. I'm not sure about the 2 wheel drive vs. 4 wheel drive. Just my two cents.
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 09-10-2008, 10:00 AM   #28
MotorSeven
Restoration Desperation
MotorSeven's Avatar
I got an OEM one off a '72 C-10 at a local bone yard. $50 & it bolted right up to my '68. If you are going the junk yard route, if the hydro lines have been removed make sure that NO WATER has gotten in the box. My first one blew because water had frozen inside & cracked the housing. If the fluid is milky, walk away.
RD
MotorSeven is offline   Reply With Quote
Old 09-10-2008, 12:44 PM   #29
WIDESIDE72
WIDESIDE72's Avatar
A few yrs ago, my brother and I bolted a PS box from a 76 1/2 ton directly on to a 72 1/2 ton to add PS. No hose adapters, no bashing. I forget but think it was a variable ratio. We also swapped the front sway bar from the same truck. That first drive after the swap was like night and day!
WIDESIDE72 is offline   Reply With Quote
Old 09-10-2008, 03:11 PM   #30
MotorSeven
MotorSeven's Avatar
The '72 donor i got the gearbox out of has a sway bar, i have to go back with a grinder & generator & get those honkin rivits out.
RD
Old 09-10-2008, 03:26 PM   #31
big_al_71
big_al_71's Avatar
I used one from a brand new pump for a 71c10 and it bolted right up I had to add one washer on one bolt....because of the march pulley bracket if I was using a factory bracket I would not had needed it.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-10-2008, 11:47 PM   #32
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
nice bling!
I have the same looking March setup w/o A/C and in the "Custom" finish, which is the silver powdercoat. (the cheap set )
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-11-2008, 04:51 PM   #33
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
90% of the 68 and 100% of the 69-72s do not require any alterations on the chassis. However we are talking 67s here. 100% of the 67s will require alterations. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 09-11-2008, 04:54 PM   #34
Classic Heartbeat
Wes, I remember you mentioning this before but I took my '77 gearbox and bolted it on to my '68, which has the indentations and raised mounting points and it's still twitchy. I'll have to double check to make sure that the steering wheel (or rather gearbox) is absolutely centered but I'm pretty sure it is and it's still twitchy. I just think that's the way these gearboxes are.
I would try a different steering gear. Quick ratio gears don't make things twitchy. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 10-04-2008, 07:17 PM   #35
msgross
msgross's Avatar
I just bought this bracket for my 68... it's actually made for 60-66 frames to accept newer gears... I'm still trying to figure out the right position though. Also, my gearbox is leaking so it sounds like I need to save $130 for NAPA and not try the $30 rebuild kit huh?
So a 76 will accept the same hose fittings as a 72? and it's variable ratio 4.5 turns? that sounds like the ticket for me, unless you guys recommenf the 3.5 turn gears..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-04-2008, 07:32 PM   #36
Brad
Out of the carpool lane.
Brad's Avatar
Yep, that'll work great, although I'd think that the rebuild kit would fix your leak issue.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 10-04-2008, 07:35 PM   #37
msgross
msgross's Avatar
It's leaking at the input shaft, of course that's because I blocked off the hoses and was turning it by hand. I have never had a pump on it so who knows....
I know there are dozens of ball bearings in these suckers and hate to waste my time and money....we'll see when the time comes I guess...
anyone tried to fix that seal? or a full rebuild?
The Garage:
Old 10-04-2008, 08:30 PM   #38
67dragtruck
67dragtruck's Avatar
I dented the frame on a 67 before. Wasn't too bad if you heated it with a torch.
Tom
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc.
My new build thread:
http://67-72chevytrucks.com/vboard/s...17#post2861817
Best pass with the old dragtruck:
5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003
Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup
5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004
67dragtruck is offline   Reply With Quote
