#26 |
67-72 Addict!
Re: Drop Spindles Wont Align
I don't recall exactly what his problem was but it was something simple that affected his "alignment" that's why I suggested doing a search.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#27 |
![]() Join Date: Jan 2004
Are you having this problem with both sides or just one side? If it's just one side it may be a bad spindle. If the spindle itself or the tapered holes for the ball joints were machined out of location, this could cause the problem you are having. These are place in fixtures on machining centers and if the casting is slightly different, the alignment in the fixture could throw off the machining operations and thus throw off your alignment. Just an idea......
My Suburban Project 72 Suburban 68 SWB 57 Belair 55 Cameo 06 Chevy 1/2 ton crew 09 Suburban |
#28 |
Never Ending Projects
Are you using the correct ball joints for the spindles you have? If you have spindles with the tapered holes for the larger ball joints and you are using the pre '70 ball joints, it would allow enough slop to offset the spindle, even if the joint is tight.
Just an idea.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#29 |
Hollister Road Co.
Some of these frames have a problem with twisting inward at the top of the rail at the motor mount, A frame area. If you replaced your motor mounts brackets with something else or put V8 inplace of 6cyl. you may need to jack up the truck in the center of the cross member and loosen the upper bracket bolts and re-torque them so the frame moves back to the original postion. There is also a Moog "Problem Solver" upper A frame shaft kit that can get you extra camber adjustment without headache of changing the bolts. rockauto has them.
#30 | |
laying low
![]() Join Date: Mar 2001
If you like the drop you have now then maybe these offset upper control arm shafts are the answer.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#31 |
![]() Join Date: Jul 2004
Sounds to me like too tall of springs, new stock springs can be pretty tall. I assume the tires sit like this /....\ right ?? Thats how the tires sit with the engine out, either get shorter springs or drop in a big block to settle it down !!!
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
